#51
![]() "Happy Dog" wrote in message m... "Dave Stadt" wrote One might say that the fatal accident rate seems disproportionate (50% of the SR20, 25% for the SR22 versus 10% for the 172 and 20% for the 182), but at the sample sizes present, there's absolutely no reasonable way to draw any valid statistical conclusion (and note that for the SR22 and the 182, the rates are actually similar). Apples and oranges. The 182 fleet is many times larger than the SR22 fleet. And the 172 fleet is near infinite compared to the Cirrus fleet. The numbers look pretty bad for Cirrus. Did you adjust for the kind of flying done by each? No, you didn't. The flights all involve an equal number of takeoffs and landings only some are more successfull in the landing department than others. Unless you wish to redefine "flight" , no, they don't. Are circuits "flights"? I suspect so. Unless one just motors around on the ground in a big rectangle. Which would be redefining "circuits". So the flights don't "all involve an equal number of takeoffs and landings". They most certainly do. How can one make one takeoff and less than or more than one associated landing, excluding the occasional bounce. Your desire to engage in semantics aside, Cirruses are not training aircraft. Why not. I suspect with the insurance requirements involved they are used quite frequently in a training environment. So a direct comparison of "numbers" is really telling us enough about the safety of each plane. Either way. moo |
#52
Peter,
It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'd say so. But mind you, saying so already made me an "apologist" here. Which brings me to another reason for the increase, with regard to the pilot community, not the media: the introduction of gasp "something new" (tm). -- Thomas Borchert (EDDH) |
#53
"Jose"
Which would be redefining "circuits". So the flights don't "all involve an equal number of takeoffs and landings". How so? Is there an accumulation of aircraft in the sky (or on the ground) when one does circuits? When I do them, the number of takeoffs does in fact equal the number of landings. I just do more of them. But every takeoff and landing isn't a separate flight. m |
#54
an equal number of takeoffs and landings". How so? Is there an accumulation of aircraft in the sky (or on the ground) when one does circuits? When I do them, the number of takeoffs does in fact equal the number of landings. I just do more of them. But every takeoff and landing isn't a separate flight. It could be. But even if not, for every landing that is not "the end of the flight" there is a takeoff that is not "the beginning of the flight". They will still equal. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#55
inconsistancy of small samples have simply increased the hype factor. I'd say so. But mind you, saying so already made me an "apologist" here. Which brings me to another reason for the increase, with regard to the pilot community, not the media: the introduction of gasp "something new" (tm). That's a really good point, and the specter of being thought of as an apologist for an airplane that I really don't like does hang over me quite heavily. ;- I suppose that I should be grateful that the safety record is approximately average instead of demonstrably above average, just to avoid the apologist label, but I'm not. I'm just not sold on the lack of demonstrated spin recovery (with the chute as a backup) and the controls felt awkward and possibly tiring when I sat in one on static display. |
#56
Peter Dohm wrote:
From this data, I don't think the Cirrus rate stands out excessively. Dick Collins did the same analysis for new 182s and Cirrus. Same result. It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'm sure that is the case. Then again, if a chute equipped airplane has the same accident rate as a traditional design, I think one must question the value of having the chute and its associated cost and weight. Matt |
#57
"Matt Whiting" wrote in message
Peter Dohm wrote: From this data, I don't think the Cirrus rate stands out excessively. Dick Collins did the same analysis for new 182s and Cirrus. Same result. It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'm sure that is the case. Then again, if a chute equipped airplane has the same accident rate as a traditional design, I think one must question the value of having the chute and its associated cost and weight. It makes the pax happy. I have one in my ultralight and I've always thought that the odds of it being the right choice in an emergency are very slim. Of course, the people saved by them would probably install one again at twice the cost... moo |
#58
... It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'm sure that is the case. Then again, if a chute equipped airplane has the same accident rate as a traditional design, I think one must question the value of having the chute and its associated cost and weight. Given that the types of accidents that the parachute is intended to address are exceedingly rare even in non-equipped airplanes, I would find it VERY surprising if the overall accident rate was noticeably affected by the presence of the parachute. In fact, it is the rarity of those accidents itself that in my opinion calls into question the value of having the parachute and its added cost and weight, rather than the lack of a change in accident rate. Pete |
#59
Peter Duniho wrote:
"Matt Whiting" wrote in message ... It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'm sure that is the case. Then again, if a chute equipped airplane has the same accident rate as a traditional design, I think one must question the value of having the chute and its associated cost and weight. Given that the types of accidents that the parachute is intended to address are exceedingly rare even in non-equipped airplanes, I would find it VERY surprising if the overall accident rate was noticeably affected by the presence of the parachute. In fact, it is the rarity of those accidents itself that in my opinion calls into question the value of having the parachute and its added cost and weight, rather than the lack of a change in accident rate. I think this is just two different ways of saying the same thing! :-) Matt |
#60
![]() Although the SR-22 is fixed gear wouldn't it be more appropriate to compare them to other planes of similar performance and wing loading? Then remove the "gear up" incidents for the final comparison? When it comes to performance and handeling the SR-22 is about as far from a 172 as you can get. I don't know of any "every day" retracts like the Bo, or Mooney with near the wing loading of the SR-22 and the 172 can be over 26% less than those at a tad over 14# per sq ft. Actually both the Mooney and Bo are far easier to slow down even with the tendency to float by the Mooney and they have roughly 30% less wing loading than the SR-22. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Trip report: Cirrus SR-22 demo flight | Jose | Piloting | 13 | September 22nd 06 11:08 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
