Light twins not using contra-rotating propellers
Old December 2nd 06, 12:19 AM posted to rec.aviation.piloting
Steve Foley[_2_]
Default MXX Light twins not using contra-rotating propellers
"Mxsmanic" wrote in message
Newps writes:
A used Baron can be had for a wide variety of prices.
Oh. I forgot that some people buy used.
And others buy make-believe.
  #52
Old December 2nd 06, 12:21 AM posted to rec.aviation.piloting
N2310D
Default MXX - Light twins not using contra-rotating propellers
Newps writes:
One has nothing to do with the other. The rider is solely responsible
for keeping it upright.
It will stay up by itself as long as it has traction and power (or
momentum).
So, according to your statement above, if I stand off to the side, give it a
good hard shove, and let go of it, the bicycle won't fall over until it
comes to a stop.
You lost the argument a long time ago so now all you have left is to display
your moronity.
Try this one: While riding a bicycle on a flat, level surface which way do
you move the right handle bar to initiate a left turn?
  #53
Old December 2nd 06, 12:25 AM posted to rec.aviation.piloting
Steve Foley[_2_]
"N2310D" wrote in message
news:zG3ch.52$Qa7.13@trnddc03...
Newps writes:
momentum).
a good hard shove, and let go of it, the bicycle won't fall over until it
comes to a stop.
display your moronity.
I was fourty years old before I learned that one. (Motorcycle Safety
Foundation Rider's Class)
  #54
Old December 2nd 06, 12:27 AM posted to rec.aviation.piloting
Steve Foley[_2_]
Steve Foley writes:
Well, that sounds like your definintion if design flaw. It falls down
due
to a loss of traction.
Yes.
Are there any machines without design flaws?
  #55
Old December 2nd 06, 12:56 AM posted to rec.aviation.piloting
Mxsmanic
N2310D writes:
comes to a stop.
Correct, as long as the wheels don't slip.
your moronity.
I stand on the shoulders of giants.
The handlebars must be turned slightly to the right.
  #56
Old December 2nd 06, 12:57 AM posted to rec.aviation.piloting
Mxsmanic
Default Light twins not using contra-rotating propellers
karl gruber writes:
Every crosswind takeoff with wind from the right.............is one
But the wind is blowing from the right only half the time. What
happens when it is blowing from the left?
  #57
Old December 2nd 06, 12:59 AM posted to rec.aviation.piloting
Roy Smith
Mxsmanic wrote:
karl gruber writes:
Take off in the other direction.
  #58
Old December 2nd 06, 01:04 AM posted to rec.aviation.piloting
Mxsmanic
Roy Smith writes:
OK. What if it is blowing parallel to the runway?
  #59
Old December 2nd 06, 01:13 AM posted to rec.aviation.piloting
Newps
Mxsmanic wrote:
Newps writes:
momentum).
No, it will not. That's ridiculous.
  #60
Old December 2nd 06, 01:14 AM posted to rec.aviation.piloting
Newps
Mxsmanic wrote:
Newps writes:
It most certainly can.
No, it can't. Watch closely. The bicycle always falls because the
tires slip or because it comes to a stop.
Ridiculous assertion.
Light twins not using contra-rotating propellers RomeoMike Piloting 6 December 2nd 06 01:47 AM
Light twins not using contra-rotating propellers Newps Piloting 0 November 30th 06 07:40 PM
Light twins not using contra-rotating propellers Greg Farris Piloting 0 November 30th 06 07:25 PM
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 05:39 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
