Consider the following FARs,
§ 91.126 Operating on or in the vicinity of an airport in Class G airspace. b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace- (1) Each pilot of an airplane must make all turns of that airplane to the left .... AND 91.129 Operations in Class D airspace. (a) General. ... each person operating an aircraft in Class D airspace must comply with ... §§91.126 and 91.127. The question could be asked, how do you join the pattern, since when attempting same you are obviously "approaching to land at an airport" Now, AIM 4-3-3. Traffic Patterns Provides some recommendations: http://www.faa.gov/atpubs/aim/Chap4/4-3-1 with "(See FIG 4-3-2)". Now interestingly, this figure shows a 45 degree right turn to join the downwind, with the example stating: "Enter pattern in level flight, abeam the midpoint of the runway." However, and this is the quandary, the AIM example recommends a procedure that seems to be against the FAR about left turns when "approaching to land". Can it be that joining the pattern is not considered as "approaching to land", and hence, mandatory left turns are not required? Because if so, a pilot can be on a RIGHT base, thus join the circuit turning to final, and thus avoid the whole idea of a left traffic pattern, and the "all turns to the left when approaching to land" FAR. Loopholes, anyone? Stan |
Don't forget Advisory Circular 90-66A when collecting information.
At a Class D airport, you will follow the controller's instructions....might be right base, might be left base, might be straight in to the downwind...only the controller knows for sure, and you can always question his/her instructions and get something you want instead of what they want, consistent with safety. So quoting regs with regard to Class D is an exercise in futility. And you ignored that part of 91.126 relating to visual markings and right turns...that's cheating on your part. I'm sure that there are "joining the pattern" incidents somewhere in the US every day, but for most of us it is not a quandary. Bob Gardner wrote in message ... Consider the following FARs, § 91.126 Operating on or in the vicinity of an airport in Class G airspace. b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace- (1) Each pilot of an airplane must make all turns of that airplane to the left .... AND 91.129 Operations in Class D airspace. (a) General. ... each person operating an aircraft in Class D airspace must comply with ... §§91.126 and 91.127. The question could be asked, how do you join the pattern, since when attempting same you are obviously "approaching to land at an airport" Now, AIM 4-3-3. Traffic Patterns Provides some recommendations: http://www.faa.gov/atpubs/aim/Chap4/4-3-1 with "(See FIG 4-3-2)". Now interestingly, this figure shows a 45 degree right turn to join the downwind, with the example stating: "Enter pattern in level flight, abeam the midpoint of the runway." However, and this is the quandary, the AIM example recommends a procedure that seems to be against the FAR about left turns when "approaching to land". Can it be that joining the pattern is not considered as "approaching to land", and hence, mandatory left turns are not required? Because if so, a pilot can be on a RIGHT base, thus join the circuit turning to final, and thus avoid the whole idea of a left traffic pattern, and the "all turns to the left when approaching to land" FAR. Loopholes, anyone? Stan |
Bob, is AC 90-66a available on line? As it is "advisory", I take it
that it is similar to the aim recommended procedures, but not regulatory as in FARs? I was referring to non towered, and where pattern direction was clear, I'm assuming left for simplicity. The quandary is, the aim recommends a 45 degree RIGHT turn to join the pattern, whereas the fars say all turns to the LEFT when approaching to land. If it is argued that joining the circuit via the RIGHT turn is approaching to land, then the AIM is in conflict with the FARs. If it is argued that joining the circuit via the RIGHT turn is NOT approaching to land, then is should be permissable to join short final via a RIGHT turn also. And hence a Right base where left pattern is in effect would be permissible. Thus the quandary Stan On Mon, 3 Jan 2005 16:18:58 -0800, "Bob Gardner" wrote: Don't forget Advisory Circular 90-66A when collecting information. At a Class D airport, you will follow the controller's instructions....might utility. And you ignored that part of 91.126 relating to visual markings and right turns...that's cheating on your part. Bob Gardner wrote in message .. . Consider the following FARs, § 91.126 Operating on or in the vicinity of an airport in Class G airspace. b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace- (1) Each pilot of an airplane must make all turns of that airplane to the left .... AND 91.129 Operations in Class D airspace. (a) General. ... each person operating an aircraft in Class D airspace must comply with ... §§91.126 and 91.127. The question could be asked, how do you join the pattern, since when attempting same you are obviously "approaching to land at an airport" Now, AIM 4-3-3. Traffic Patterns Provides some recommendations: http://www.faa.gov/atpubs/aim/Chap4/4-3-1 with "(See FIG 4-3-2)". Now interestingly, this figure shows a 45 degree right turn to join the downwind, with the example stating: "Enter pattern in level flight, abeam the midpoint of the runway." However, and this is the quandary, the AIM example recommends a procedure that seems to be against the FAR about left turns when "approaching to land". Can it be that joining the pattern is not considered as "approaching to land", and hence, mandatory left turns are not required? Because if so, a pilot can be on a RIGHT base, thus join the circuit turning to final, and thus avoid the whole idea of a left traffic pattern, and the "all turns to the left when approaching to land" FAR. Loopholes, anyone? Stan |
I think the whole question is a tempest in a teapot. Who is going to cite
the "offending" pilot for making a right turn to enter left traffic from the 45? Bob Gardner wrote in message ... Bob, is AC 90-66a available on line? As it is "advisory", I take it that it is similar to the aim recommended procedures, but not regulatory as in FARs? I was referring to non towered, and where pattern direction was clear, I'm assuming left for simplicity. The quandary is, the aim recommends a 45 degree RIGHT turn to join the pattern, whereas the fars say all turns to the LEFT when approaching to land. If it is argued that joining the circuit via the RIGHT turn is approaching to land, then the AIM is in conflict with the FARs. If it is argued that joining the circuit via the RIGHT turn is NOT approaching to land, then is should be permissable to join short final via a RIGHT turn also. And hence a Right base where left pattern is in effect would be permissible. Thus the quandary Stan On Mon, 3 Jan 2005 16:18:58 -0800, "Bob Gardner" wrote: Don't forget Advisory Circular 90-66A when collecting information. At a Class D airport, you will follow the controller's instructions....might utility. And you ignored that part of 91.126 relating to visual markings and right turns...that's cheating on your part. Bob Gardner wrote in message . .. Consider the following FARs, § 91.126 Operating on or in the vicinity of an airport in Class G airspace. b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace- (1) Each pilot of an airplane must make all turns of that airplane to the left .... AND 91.129 Operations in Class D airspace. (a) General. ... each person operating an aircraft in Class D airspace must comply with ... §§91.126 and 91.127. The question could be asked, how do you join the pattern, since when attempting same you are obviously "approaching to land at an airport" Now, AIM 4-3-3. Traffic Patterns Provides some recommendations: http://www.faa.gov/atpubs/aim/Chap4/4-3-1 with "(See FIG 4-3-2)". Now interestingly, this figure shows a 45 degree right turn to join the downwind, with the example stating: "Enter pattern in level flight, abeam the midpoint of the runway." However, and this is the quandary, the AIM example recommends a procedure that seems to be against the FAR about left turns when "approaching to land". Can it be that joining the pattern is not considered as "approaching to land", and hence, mandatory left turns are not required? Because if so, a pilot can be on a RIGHT base, thus join the circuit turning to final, and thus avoid the whole idea of a left traffic pattern, and the "all turns to the left when approaching to land" FAR. Loopholes, anyone? Stan |
![]() "Bob Gardner" wrote in message ... I think the whole question is a tempest in a teapot. Who is going to cite the "offending" pilot for making a right turn to enter left traffic from the 45? Nobody. |
Bob Gardner wrote:
I'm sure that there are "joining the pattern" incidents somewhere in the US every day, but for most of us it is not a quandary. Oddly enough, joining on downwind, by whatever method rarely leads to accidents. Most midairs in the patter occur on final. |
Hi Matt.
John Deakin's Pelican article you brought up had just the point I was considering, Here's a snip "In fact, I can make a very good case that the classic 45-degree entry is itself a violation of the FARs, since it is ALWAYS in the opposite direction to the established flow of traffic. Since it is the final turn onto the downwind leg, it must certainly be in the "vicinity" of the airport, and therefore covered by the above regs" thus, even the 45 degree right turn on downwind should be considered a violation of the FARs Stan Of course there's always the 45-degree zealots http://www.avweb.com/news/columns/182100-1.html |
Thanks, Roy
As I've just posted to Bob, if "approaching to land" means "already in the pattern", then I could do a 90 degree right turn onto short final, where left pattern is in effect. So if a RIGHT turn is permitted by the FARs onto downwind, then so must a RIGHT turn onto final (where left traffic in effect). Hence the quandary StanOn Mon, 03 Jan 2005 19:26:27 -0500, Roy Smith wrote: In article , wrote: Consider the following FARs, § 91.126 Operating on or in the vicinity of an airport in Class G airspace. b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace- (1) Each pilot of an airplane must make all turns of that airplane to the left .... This is one of those perennial questions. If you take the regulation at face value, it is nonsensical. I think the only way to have it make sense is to interpret "approaching to land" as "already in the pattern". Of course you're going to make a right turn onto downwind in a left pattern if you're approaching on the 45. I think all they're really trying to say is "If there's no published pattern direction for the airport, use left traffic. If there is, do what's published." Since you posted this to r.a.ifr, I guess it's fair game to consider circling approaches. If the weather is good enough that there might be VFR traffic, obey the published VFR traffic pattern. If the SIAP contains circling limitations, obey those. Above all, use common sense and keep a good traffic watch. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
AOPA and ATC Privatization | Chip Jones | Instrument Flight Rules | 139 | November 12th 03 08:26 PM |
Requirement to fly departure procedures | [email protected] | Instrument Flight Rules | 77 | October 15th 03 06:39 PM |
Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 04:02 AM |
