#51
On 6 Jan 2005 23:06:12 -0600, Andrew Sarangan
wrote: I wonder how often that really happens. I know of only one case when a Seattle pilot hung on a wire. I would imagine that the chance of hitting a wire and hanging upside down is just as remote as surviving a midair collision. I could be wrong though. Not related to the original "descent below minimums"-question, but anyway: A couple of years ago our club lost an Archer. It ran out of gas about 20 miles from the destination, but just over a glider airfield with plenty of runway available. The pilot misjudged the gliding capability and flew a too-wide traffic pattern. The airfield was located on a plateau, and about half a mile before the threshold there was a powerline crossing the approach path at about field elevation. Our poor plane ended up dangling in that powerline and its occupants had to be freed by the local fire brigade. One of them spent a few nights in hospital, but nothing really serious. Tobias |
#52
#53
On Sat, 08 Jan 2005 07:10:00 GMT, Carlos Villalpando
wrote: In article , says... Like I said, if you can see the runway, there ain;t no hill between you and it. http://www.aopa.org/pilot/never_again/2002/na0204.html --Carlos V. Nothing in this article that contradicts this statement: If you can see the runway, there ain't no hill between you and it. |
#54
Nothing in this article that contradicts this statement: If you can see the runway, there ain't no hill between you and it. Not true. What =is= true is "If you can see the runway, there ain't no hill between your eyeballs and it." However, there is more "you" below your eyeballs. So your statement (which you keep repeating on technical grounds) is incorrect - on technical grounds. Further, as has already been pointed out, there is a lot of airplane below your eyeballs which can run into the hill your eyeballs just missed. This is the point of disagreeing with your statement. It implies safety, and delivers the opposite. Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
#55
On Sat, 08 Jan 2005 15:36:51 GMT, Jose
wrote: Further, as has already been pointed out, there is a lot of airplane below your eyeballs which can run into the hill your eyeballs just missed Not with about 6 ft of visibility or more. Of course, with 6 ft of visibility, you probably ain't seeing the runway either. |
#56
#57
On Sat, 08 Jan 2005 11:06:33 -0500, Roy Smith wrote:
If you get too low, the (displaced) threshold lights just suddenly wink out for no apparent reason. No apparent reason? The obvious reason is, you are getting too low. |
#58
Gentlemen:
The idea that 'if I can see the runway then there is nothing between me and it' is both true and deadly, especially at night. It presumes that your flight path is the same as your line of sight, and this is not always so. Pick up ASF's video package on Controlled Flight into Terrain, and pay close attention to the section on the Black Hole Approach. Many a pilot has made the mistake of depending on the 'I can see the threshold cue,' when in fact they are executing what is technically called a 'constant visual angle' approach. The trees suddenly fill the windscreen, and by the time they see it it is usually too late to initiate a successful go around. Typically, if the pilots survive to be interviewed, they were convinced they were on a normal glide path right up until the moment before impact. Gene |
#59
![]() wrote in message oups.com... Pick up ASF's video package on Controlled Flight into Terrain, and pay close attention to the section on the Black Hole Approach. Many a pilot has made the mistake of depending on the 'I can see the threshold cue,' when in fact they are executing what is technically called a 'constant visual angle' approach. The trees suddenly fill the windscreen, and by the time they see it it is usually too late to initiate a successful go around. When it happened to me (black hole illusion), I became aware of the treetops that I was descending into only when they were illuminated by the wingtip strobe lights. If I had not had strobes, I would have dragged the gear into the trees without ever losing sight of the runway (until impact). |
#60
It presumes that if one ALWAYS sees the target, there will be nothing
between the aircraft and the target. .... and that presumption is deadly false. There may be nothing between the eyeball and the target, but the aircraft dangles below. Furher, there can be invisible barriers between the aircraft and the target - wires come to mind, especially at night. True, wires aren't a hill, but neither are tree branches, both of which could spoil your day. If one lost the target 5 seconds ago on a descent, one can regain the target and clear it by returning to the altitude he was at 5 seconds ago, and remaining level. In that time you are moving forward. The object that caused you to lose sight of the target may well be wrapped around you by then. "If you never hit anything, you won't crash." Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
Are pilots really good or just lucky??? | Icebound | Instrument Flight Rules | 68 | December 9th 04 01:53 PM |
Canadian departure minimums? | Derrick Early | Instrument Flight Rules | 3 | August 9th 04 01:43 PM |
Can ATC assign an airway if filed direct? | Andrew Sarangan | Instrument Flight Rules | 26 | March 4th 04 12:23 AM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
CAT II Minimums on a CAT I Approach | Giwi | Instrument Flight Rules | 11 | July 24th 03 07:46 AM |
