Air buss loss at Paris Airshow?
Old December 10th 06, 10:19 PM posted to rec.aviation.piloting
Danny Dot
Default Air buss loss at Paris Airshow?
In about 1990 Airbus did low pass at the Paris airshow and lost the plane.
I recall it had something to do with the throttle software thinking the
pilots were in landing mode and "refused" to go to high power for the
go-around.
Anyone remember the details???
Danny Dot
Old December 10th 06, 10:54 PM posted to rec.aviation.piloting
BT
http://www.linienmc.dk/video/crashpl...sh%20A320.mpeg
"Danny Dot" wrote in message
go-around.
Danny Dot
Old December 10th 06, 10:56 PM posted to rec.aviation.piloting
BT
May 1998
go-around.
Danny Dot
Old December 10th 06, 11:06 PM posted to rec.aviation.piloting
Mxsmanic
Danny Dot writes:
go-around.
Probably this one: http://en.wikipedia.org/wiki/Air_France_Flight_296
It cast considerable doubt on the airworthiness of the Airbus and its
fly-by-wire systems, especially since the flight recorders were
spirited away and tampered with before they were officially examined.
Old December 11th 06, 08:56 AM posted to rec.aviation.piloting
Thomas Borchert
Danny,
go-around.
Details? How about we get the general picture right? ;-)
It was not in Paris, it was in Mulhouse. It was in 1988. The official
accident report blamed the pilot for flying too low and too slow, basically a
classic "Hey, watch this!" accident.
If you are into conspiracies, there are other explanations (by the pilot, for
example - hardly surprising), but even they don't mention any "landing mode",
whatever that may be. You may confuse that part with the case of a Japan
Airlines flight, where the crew put the plane in TOGA mode without noticing
and fought the autopilot all the way into a stall.
Thomas Borchert (EDDH)
Old December 11th 06, 06:51 PM posted to rec.aviation.piloting
Jon Woellhaf
What's TOGA mode?
Old December 11th 06, 07:43 PM posted to rec.aviation.piloting
James Robinson
"Jon Woellhaf" wrote:
What's TOGA mode?
Take Off / Go Around
Old December 11th 06, 09:20 PM posted to rec.aviation.piloting
Thomas Borchert
Jon,
As James says. A one-button-push to set the plane up for go around with
max power.
Old December 12th 06, 06:03 AM posted to rec.aviation.piloting
Greg Farris
says...
FROM AIRLINERS.NET :
The Air France A320 that was written off at Habsheim was being operated on a
public transport flight by Air France at the time of the crash. The aircraft
had been used in flight testing, but had been delivered to Air France several
days before the accident, and was involved in a promotional flight when it
crashed. The A320 was in service operating revenue flights at the time of the
accident, F-CFKC was in fact Air France's 3rd A320.
Most importantly, the fly-by-wire did not "lock up" - and the plane did not
"think" it was landing and prevent the application of TOGA power. The
accident was classic pilot error, no fault was found with the FBW system...
Some findings of the accident investigation:
• The captain had participated as Air France's technical pilot in
developmental test flying on the A320, during which manoeuvres were carried
out beyond the normal operational limitations. This could have lead to
overconfidence in the systems of the new aircraft.
• The flight had only been briefly prepared, without real consultation
between the departments (of Air France) concerned, or with the crew.
• Descent was started 5.5nm from the aerodrome. Throughout the descent, the
engines were throttled back to flight idle with the airspeed reducing.
• At 1000ft AGL the rate of descent was still ~600fpm.
• The captain levelled off at a height of ~30ft, engines at flight idle,
pitch attitude increasing. He did not have time to stabilise the angle of
attack at the maximum value he had selected.
• Full-power was rapidly applied when the angle of attack was 15° and the
airspeed 122kt.
• The response of the engines was normal, and in compliance with their
certification.
The cause:
• The accident resulted from a combination of the following;
• Flyover height lower than surrounding obstacles (Flown at 30ft against the
planned 100ft)
• Slow speed, reducing to reach maximum angle of attack
• Engines at flight idle
• Late application of go-around power
In summary the crew flew the aircraft onto the wrong side of the drag curve
in a critical situation overflying a very small grass strip with trees above
the height of the aircraft off the end of the runway, the aircraft was low,
slow and at a high angle of attack - there was no residual energy to get them
out of trouble. It's a basic lesson in flying, and the A320 was found to have
actually exceeded it's certified performance once TOGA power was selected.
The crew had been briefed to overfly the concrerte runway 02/20 at 100ft, but
unknown to them the airshow was alligned along grass strip runway 16/34. The
crew were unaware of this until descending through 200ft, 24 seconds before
the accident, at which time they had to chose to reposition the aircraft to
conduct an overflight they had not briefed for over runway 16/34 as the
height decayed to 30ft and the airspeed to 122kt...
If you want some information on some of the conflicting theories, you can
find it here : http://en.wikipedia.org/wiki/Conspiracy_theory
Old December 12th 06, 12:37 AM posted to rec.aviation.piloting
Mxsmanic
Greg Farris writes:
Since the flight recorders were tampered with, all conclusions
concerning that flight are suspect.
Furthermore, if the FBW system were truly as reliable as Airbus
claims, the aircraft would never have crashed--the computers would
have prevented it. Airbus aircraft don't allow pilots to override the
computers, which means that this crash must have been a
computer-generated crash no matter how you look at it.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Paris Airshow - Helimat HELIMAT Rotorcraft 0 June 14th 05 06:42 AM
paris airshow 2003 / Le bourget / photo album hugo36 Aerobatics 0 July 8th 03 11:01 PM
