When does IFR begin in VFR?
Old February 7th 05, 01:36 AM
Wizard of Draws
Default When does IFR begin in VFR?
I took a short XC today after a layoff of a few months due to real life
constraints and weather. I filed IFR even though it was VFR because I wanted
to get back into the groove of communicating with ATC.
I filed for 5000 going east. On the ground, they told me it would be faster
if I took off VFR and opened my plan in the air, so I did.
I was at 5500 when I finally got through since I was VFR, but all I was
given initially was a squawk code with no altitude assignment or clearance.
I assumed that I was IFR at this point so I began to descend to 5000 per my
flight plan. As I did I asked ATC if he had an altitude assignment, and he
came back with 6000, cleared direct. No problem, I pull back up and fly as
I'm told.
So, was I IFR as soon as I was given a squawk and required to fly my flight
plan, or should I have waited to change from a VFR altitude to an IFR
altitude until I was given specific instructions?
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
Old February 7th 05, 01:58 AM
Stan Prevost
Hi, Jeff -
You are not under IFR until you have received an IFR clearance including the
words "cleared to". If you departed VFR (without an IFR clearance and
release), you are not IFR and must obey VF Rules. Once airborne, you
contact ATC with something like "ABC Approach (or center), N1234 off Podunk
Field, IFR to Niceville, request clearance." They will assign you a squawk
code, wait to identify you on radar, then give you your clearance and
instructions (inlcuding altitude). Until then, you maintain VFR, including
altitude.
But see http://www.avweb.com/news/columns/189034-1.html .
Stan
"Wizard of Draws" wrote in message
news:BE2C303C.4C813%jeffbTAKEOUTALLCAPS@wizardofdr aws.com...
wanted
faster
clearance.
my
I'm told.
flight
Old February 7th 05, 02:11 AM
Ron Rosenfeld
On Sun, 06 Feb 2005 20:36:12 -0500, Wizard of Draws
The salient items of a clearance that tell you you are operating under IFR
a
1. Clearance Limit
2. Route (which could be "as filed")
3. Altitude
You did state that the plan was to "open your flight plan in the air".
If your only conversation with ATC went as you report:
Jeff: XYZ approach, N123WD
ATC: N123WD, squawk 5547
Then at the time you were given a squawk code, you were still operating
under VFR. You had not received any clearance from ATC.
Old February 7th 05, 02:46 AM
Roy Smith
I'm told.
You're IFR when you hear the magic words "cleared to". When the controller
first gave you squawk code, you were still VFR. He wanted to get you in
radar contact before issuing your clearance (so he didn't have to apply
non-radar separation rules). I assume when you wrote, "6000, cleared
direct", it really sounded more like, "Cleared to the XYZ airport, via
direct, maintain 6000". Clearance limit, Route, Altitude, always in that
order (followed by Frequency and Transponder code, giving the popular CRAFT
acronym).
What confuses me is, "given a squawk and required to fly my flight plan".
In what way were you required to fly your flight plan? Until you are IFR,
the controller can't really require you to do much of anything (assuming
class E airspace).
Old February 7th 05, 02:08 PM
I could argue that "cleared to" is by itself insufficent. Even more significant
is to hear "maintain XXXXX altitude."
I'm told.
acronym).
class E airspace).
Old February 11th 05, 07:37 PM
Robert M. Gary
True, but the "magic" for IFR students to listen to is the "cleared
to". The rest could happen when VFR. A lot of students have a hard time
understanding the difference between radar services for instrument
approaches (practice approaches) and IFR approaches. Its easier to
train students to listen for the magic "cleared to " (the smart guys
will ask, "What about 'cleared to Land'").
BTW: Ron, will I see you in Mexico weekend after next with the rest of
us in the Mooney group? We're going down to pet grey whales.
-Robert, CFI
Old February 8th 05, 03:19 AM
Wizard of Draws
On 2/6/05 9:46 PM, in article ,
I'm told.
acronym).
class E airspace).
Thanks for answering.
Craft is not exactly correct since I got the transponder code first. It was
a monkey wrench that I didn't really expect since I normally get clearance
on the ground in CRAFT order. It's been quite a while since I opened a plan
in the air and 3 months since I've flown at all. A lot of rust to work off.
I suppose I should have used the word 'expected' instead of required.
How to use Lycoming remote filter Evan Carew Home Built 0 September 30th 04 11:43 PM
Copyright Š2004-2025 AviationBanter.
