#51
Many of the ex-ULs, now Light-Sport Aircraft have a handle over head to
operate the flaps Seems fairly common. The new Cessna looks great but that heavy engine is stealing useful payload. Have a good day and stay out of the trees! See ya on Sport Aircraft group http://groups.yahoo.com/group/Sport_Aircraft/ "buttman" wrote : Well I've never flown any of those planes. All the high wings I've ever flown have always had electrical flaps, and the only mechanical flapped plane I've flown was a low wing. I didn't think it was possible to have a cable or a shaft go through the floor, up the sides of the door, then across the roof. I do know of one high wing mechanical flap airplane, but it had a hand crank coming down from the roof. I think it was the Aeronca, but I could be wrong. |
#52
Jim Stewart wrote:
Gig 601XL Builder wrote: It runs at ~5800 rpm which is about 3000 rpm faster than the O-200. It can run at 5800 rpm, but it depends on your prop pitch. My CTSW never exceeds 5100-5200 on full throttle climbout and cruises just wonderfully at 90-95 knots and 4200 rpm or so. The prop pitch can be twicked on an O-200 as well. |
#53
Gilan wrote:
Many of the ex-ULs, now Light-Sport Aircraft have a handle over head to operate the flaps Seems fairly common. The new Cessna looks great but that heavy engine is stealing useful payload. It ism't just the engine that is heavy. That plane is at least 100 lbs over weight and that ain't all engine. The all glass panel should have produced some weight savings. But it looks like they spent that to. |
#54
![]() "Phil" wrote I don't know what the firewall-forward weights would be, but the basic dry weight of the Rotax is 132 lbs versus 170 lbs for the Continental. I would think the Rotax would have to give back at least 15 or 20 pounds, for the cooling system and coolant. -- Jim in NC |
#55
Phil wrote:
On Jul 23, 7:13 pm, "Morgans" wrote: "Scott Skylane" wrote Don't knock the O-200 quite so fast. The 162 is getting the "D" model engine, the Type Spec of which hasn't even been issued, yet. I would be surprised if Continental doesn't incorporate some improvements to the cylinder design. As a rugged, easy-to-maintain light aircraft powerplant, I personally think they made a good choice. I agree, most completely! The fact that it has the O-200 would make me buy it, rather than the Rotax powered LSA's. Anyone know what a weight comparison would be for a firewall forward installation of a 200 vs. a 912? -- Jim in NC I don't know what the firewall-forward weights would be, but the basic dry weight of the Rotax is 132 lbs versus 170 lbs for the Continental. It is pretty disingenuous to compare the dry weight of a liquid cooled engine against an air cooled engine. What is the operational weight of the Rotax? Matt |
#56
#58
![]() "Jim Stewart" wrote It can run at 5800 rpm, but it depends on your prop pitch. My CTSW never exceeds 5100-5200 on full throttle climbout and cruises just wonderfully at 90-95 knots and 4200 rpm or so. It just sounds wrong to me, to hear an engine running a sustained 5800 RPM. I do want to go 120 knots though, so if that means it has to run 5800 RPM, it is a big turn-off for me. You know how sometimes people have a hang-up, for no good reason, but there is a reason? That is me and Rotax. We had a SeaDoo that had a rotax (I forgot now) I think around 600 cc engine. It was a piece of crap, from start to end. You fix one thing, and there was another problem. Lots of money flushed down into that hole in the water. Ended up getting a new short block. Ran it for about a year, with some improvement in reliability, but not much. I got it running fairly good and sold it. I told the new buyers about its questionable reliability (so I could sleep nights), but they still wanted it. It was a deal. Now, I KNOW that the 912 is a completely different beast than that 586 (or whatever) 2 stroke, but I can never imagine getting into a plane with an engine that is made by the same company. Not logical, but just the same, my mind is over ruling my brain! or something like that -- Jim in NC |
#59
On 2007-07-24 10:50:48 -0700, Jim Stewart said:
C J Campbell wrote: On 2007-07-23 07:31:11 -0700, Phil said: On Jul 23, 4:00 am, Thomas Borchert wrote: Phil, I'm sorry, but SkyCatcher?? I think they should have just stuck with Cessna 162 and left it at that. You seem to forget that the other Cessnas all have silly names, too. -- Thomas Borchert (EDDH) No, I knew that. But in silliness, this one goes to eleven. It sounds like a name an eight year old would pick for the airplane he just made out of scrap wood. I don't think it is as bad as 'Stationair.' Sounds like something slow and ugly, which it is, but they didn't need to call it that . :-) You could argue that any technical field that uses terms like flapperon, gascolator, stabilator and elevon shouldn't have an issue with a marginal aircraft name (: Hey. The C-130 had grasshopper arms and 19 lb. steel balls. -- Waddling Eagle World Famous Flight Instructor |
#60
![]() "Matt Whiting" wrote in message ... Phil wrote: On Jul 23, 7:13 pm, "Morgans" wrote: "Scott Skylane" wrote Don't knock the O-200 quite so fast. The 162 is getting the "D" model engine, the Type Spec of which hasn't even been issued, yet. I would be surprised if Continental doesn't incorporate some improvements to the cylinder design. As a rugged, easy-to-maintain light aircraft powerplant, I personally think they made a good choice. I agree, most completely! The fact that it has the O-200 would make me buy it, rather than the Rotax powered LSA's. Anyone know what a weight comparison would be for a firewall forward installation of a 200 vs. a 912? -- Jim in NC I don't know what the firewall-forward weights would be, but the basic dry weight of the Rotax is 132 lbs versus 170 lbs for the Continental. It is pretty disingenuous to compare the dry weight of a liquid cooled engine against an air cooled engine. What is the operational weight of the Rotax? And the O-200 model "D" should have "at least a 25 pound weight reduction" over previous models. |
Cessna's new LSA: "Skycatcher" | Jim Logajan | Piloting | 107 | September 23rd 07 01:18 AM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
More on Cessna's new "Cirrus Killer" | [email protected] | Piloting | 49 | November 13th 05 02:29 PM |
