VOR approach SMO
Old July 24th 07, 12:47 AM posted to rec.aviation.piloting,rec.aviation.ifr
B
Default VOR approach SMO
karl gruber wrote:
The MDA is 1120 unless you have DME. If you have DME then the MDA is 680
once you pass CULVE. You cannot descend below 1120 prior to CULVE even if
you see the runway unless you either cancel, get a contact approach, or a
visual approach.
If you have DME, IFRGPS, or ATC Radar, you can descend to 680 past
BEVEY............that is simply what that chart reads.
Karl
I can see how you could take the NACO chart that way, lacking an
understanding of what the line below 1120 means, and failing to
reference the asterik to the note "When tower closed, DME required."
If you look at the Jeppesen chart you cannot reach that erroneous
conculsion.
  #52
Doug Semler
On Jul 23, 7:43 pm, Doug Semler wrote:
If there was a lower crossing restriction
if DME equipped, I would have expected the footnote to reference the
lower altitude that would be allowed (and i could have sworn I have
seen this before, but of course I wouldn't be able to remember where/
if/when I saw this
OK. DTW's approach plates have alot of 5000 crossing restrictions
that are footnoted 4000 when directed by ATC.
I would expect the same footnote to apply to SMO's approach plate if
that were the case.
  #53
Old July 24th 07, 12:49 AM posted to rec.aviation.piloting,rec.aviation.ifr
Doug Semler
On Jul 23, 7:43 pm, B wrote:
Doug Semler wrote:
On Jul 23, 5:43 pm, "karl gruber" wrote:
Correct. That's why there's a little * next to the 1120*.
Unless they changed the rules of footnoting on me, the only thing the
little * next to 1120 tells me is that DME is required when the tower
is closed. Presumably to identify CULVE.
Correct, but the note is a bit ambiguous. DME is not required when the
tower is closed unless you want to identify CULVE and use the lower MDA.
You know, I kinda figured this; otherwise it would have been a VOR/DME
appch, right?
  #54
Old July 24th 07, 12:56 AM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
Correct. When DME etc. equipped, and descending to 680 after BEVEY,
identifying CULVE does you no good, other than for situational awareness.
Karl
So what does really identifying CULVE do for you if you are
already down to 680 by the the time you identify it?
SDF Public Access UNIX System -
http://sdf.lonestar.org
  #55
Old July 24th 07, 01:05 AM posted to rec.aviation.piloting,rec.aviation.ifr
Hamish Reid
Roy Smith wrote:
In article
Hamish Reid wrote:
The other point is that you're on an approach with a lot of faster
aircraft behind you, and I'm sure the temptation is to keep going like a
bat out of hell right up until the MDA, at which point you don't have a
lot of time and space to slow down. That hasn't happened to me, but I
can understand why it might. I was asked for best forward speed all the
way from somewhere out near OHIGH to CULVE.
You worry about flying the approach and let ATC worry about the aircraft
behind you. If you're not comfortable flying it any faster than 90 kts,
when they ask you for best speed, just tell them 90 kts IS your best speed.
They'll deal with it.
Well, yes. I wasn't suggesting I had any problems with this at all, just
that I can understand how someone unfamiliar with the approach and the
area might botch things under the pressure, assuming they had more time
to slow down than they really did... I actually enjoyed the experience.
Hamish
  #56
Old July 24th 07, 01:06 AM posted to rec.aviation.piloting,rec.aviation.ifr
Hamish Reid
No.
You can be 6.7 miles out at 680/DME.
Maybe I'm just thick, but that's not how I read the chart.
After DARTS, you can descend to 2600. After BEVEY, you can descend to
1120. What happens after that depends on whether you can identify CULVE or
not. If you can identify CULVE, once you reach it, you can descend to 680.
Without CULVE, you have to stay at 1120 until you have the runway in sight.
That's my understanding as well -- the chart isn't particularly
ambiguous on this, either...
Look at the plan view. There's a 863 tower at what looks like about 1/2
mile right of the FAC. I'm sure that's the controlling terrain for the
1120 MDA between BEVEY and CULVE.
Indeed. Having briefly worked in the building that that obstruction
represents, I hope there aren't too many pilots out there in IMC
dropping below 1120 before they're at least abeam that point...
Hamish
  #57
Old July 24th 07, 01:11 AM posted to rec.aviation.piloting,rec.aviation.ifr
Hamish Reid
"pgbnh" wrote:
I think all but one of the posters have missed the fact that the MDA is not
1120 but 680.
Assuming radar or DME, yes.
If indeed the vis was 3 miles, then the runway should have
been in sight from the MDA of 680 feet about a mile OUTSIDE of Culve.
But you can't go below 1120 until CULVE unless you're on the visual. The
chart's not particularly ambiguous about this...
(Remember what you can do once you have the runway in sight????)
You generally have to be below the ceiling before the runway's in
sight... At 1120, with 800/3, you're presumably still in the stratus.
At which
point it's not a particularly big deal to lose 500 feet to land on the
numbers. Maybe even crossing Culve at 3-400 feet agl.
Having done the approach for real, I didn't find the descents
particularly challenging, but they do require a bit of forethought,
that's for sure. The hardest part was being dumped inside DARTS at
6,000'....
Hamish
"Hamish Reid" wrote in message
I see no problem with the weather 800/3 as you point out. Inside BEVEY
drive
down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet
will do that all day long.
So you'd drop below 1120 *outside* CULVE? Even if you were just cutting
things a little fine, the 2.4 miles from CULVE is from the *far end* of
the runway you're landing on... and if you were descending below 1120
just inside BEVEY in IMC, you might be in more trouble than you'd like.
Hamish
  #58
Old July 24th 07, 01:12 AM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
OK, you're right............I'm totally wrong. I just broke out my Jepps,
and it is clear from them that 680 is after CULVE, not BEVEY.
A sincere apology to the people I was trashing. Now I'm going out in the
yard and kill more weeds.
Karl
"Curator"
Remind me to take recurrent on NACO
"B" wrote in message ...
if you see the runway unless you either cancel, get a contact approach,
or a visual approach.
Karl
understanding of what the line below 1120 means, and failing to reference
conculsion.
  #59
Old July 24th 07, 01:16 AM posted to rec.aviation.piloting,rec.aviation.ifr
Hamish Reid
Damn. That's no good -- aren't we supposed to bicker on endlessly for at
least another few days?! :-).
Hamish
  #60
Old July 24th 07, 01:22 AM posted to rec.aviation.piloting,rec.aviation.ifr
Robert M. Gary
visual approach.
Karl
I'm still a bit confused. When I first looked at the chart I assumed
that you had to have 1120 at CULVE and could go down to 680 after
CULVE. Then looking at it again, it seemed that you could go to 680 at
BEVEY since the 680 is modifying the restriction of 1120 at CULVE
(very, very, scarry with those buildings around). However, looking at
it again, I'm not sure what purpose CULVE would serve if that was the
case. I wonder if this chart meets the FAA requirements because it
seems to be a bit ambiguous. I can't honestly believe that the FAA
would want airplanes at 680 from BEVEY (or anyone who has seen the
approach VFR would want to do that IMC).
-Robert
VOR approach SMO Robert M. Gary Piloting 124 August 3rd 07 02:17 AM
first approach in IMC G. Sylvester Instrument Flight Rules 10 July 12th 05 02:14 AM
No FAF on an ILS approach...? John Harper Instrument Flight Rules 7 December 24th 03 03:54 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
Brief an approach Ditch Instrument Flight Rules 11 October 14th 03 12:10 AM
