#51
Bill Daniels wrote:
"Martin Gregorie" wrote: I tried it enough times when I was pre-solo, thanks, in both ASK-21 and Puchacz. Didn't work with them. The only effect I remember it having was breaking a weak link with the Puchacz in a gust. I did experience a small speed drop today, also in the Puchacz as it happens, but from the rate and amount of the decrease that was the driver adjusting the power by making a small reduction at around 500 ft. After that the remainder of the launch was smack on Vwinch (59 kts) until he chopped power at the top and we floated off at 55 kts. We have two Supacats. One has a 240 hp Deutz aircooled diesel V8 industrial engine and the second a big diesel straight six, probably around 180 hp: I think we were using the straight six winch today. Both winches drive the drums with a custom gearbox, in turn driven through a fluid clutch. There are no gear changes during a launch. AFAIK the gearbox does the following: - reduction gear. Drum speed is less than engine RPM (of course) - drum selection (its a two drum winch) - oscillating drive for the pay-on system -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Keep trying it. I think you will find you have control over airspeed. 180 - 240 HP isn't nearly enough power to prevent a big 2-seat glider from slowing the winch. I assume Martin flies at the Cambridge Gliding Centre. Their V8 Supacat could not be slowed by pulling (and in fact sped up at times) through multiple attempts by myself and an instructor (both of us in the 200+ lb range) in one of their ASK-21s. The only otherwise unusual outcome was a premature back release late in one launch. This was done with prior knowledge and discussion of the fact that it should theoretically be possible. I'd guess there is no overcoming gobs of torque... Marc |
#52
Bill Daniels wrote:
Keep trying it. I think you will find you have control over airspeed. 180 - 240 HP isn't nearly enough power to prevent a big 2-seat glider from slowing the winch. A big two seater may have a small effect on the straight six - we've only had that winch a year or two. I did all my training on the V8 and I know from both experience and instructor verbals that nothing in our club fleet can slow it down enough to make a detectable difference. An ASH-25 probably could, but although I've seen them winched I've not been in the winch or the ASH at the time so can't and won't comment further about that. I think you're ignoring torque. The 240 hp Deutz is likely to produce more torque than an automotive V8 of the same or higher power output. Its a mining engine and designed for high torque at low rpm. Power = torque * rpm, so for equal power the slower turning engine has proportionately higher torque. It is, after all, the torque not the power of the winch that determines whether a glider can affect its speed. I've looked for engine specs, but although I know it produces peak power at 2300 rpm, I can't find figures for max torque or the rpm for max torque. At a guess max torque will be produced at somewhat below 2000 rpm. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#53
![]() "Marc Ramsey" wrote in message et... Bill Daniels wrote: "Martin Gregorie" wrote: I tried it enough times when I was pre-solo, thanks, in both ASK-21 and Puchacz. Didn't work with them. The only effect I remember it having was breaking a weak link with the Puchacz in a gust. I did experience a small speed drop today, also in the Puchacz as it happens, but from the rate and amount of the decrease that was the driver adjusting the power by making a small reduction at around 500 ft. After that the remainder of the launch was smack on Vwinch (59 kts) until he chopped power at the top and we floated off at 55 kts. We have two Supacats. One has a 240 hp Deutz aircooled diesel V8 industrial engine and the second a big diesel straight six, probably around 180 hp: I think we were using the straight six winch today. Both winches drive the drums with a custom gearbox, in turn driven through a fluid clutch. There are no gear changes during a launch. AFAIK the gearbox does the following: - reduction gear. Drum speed is less than engine RPM (of course) - drum selection (its a two drum winch) - oscillating drive for the pay-on system -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Keep trying it. I think you will find you have control over airspeed. 180 - 240 HP isn't nearly enough power to prevent a big 2-seat glider from slowing the winch. I assume Martin flies at the Cambridge Gliding Centre. Their V8 Supacat could not be slowed by pulling (and in fact sped up at times) through multiple attempts by myself and an instructor (both of us in the 200+ lb range) in one of their ASK-21s. The only otherwise unusual outcome was a premature back release late in one launch. This was done with prior knowledge and discussion of the fact that it should theoretically be possible. I'd guess there is no overcoming gobs of torque... Marc As I said, try it again with careful observation. You will find it works though you may have to wait a bit to see the effect. Bill Daniels |
#54
Bill Daniels wrote:
"Marc Ramsey" wrote in message et... Bill Daniels wrote: "Martin Gregorie" wrote: I tried it enough times when I was pre-solo, thanks, in both ASK-21 and Puchacz. Didn't work with them. The only effect I remember it having was breaking a weak link with the Puchacz in a gust. I did experience a small speed drop today, also in the Puchacz as it happens, but from the rate and amount of the decrease that was the driver adjusting the power by making a small reduction at around 500 ft. After that the remainder of the launch was smack on Vwinch (59 kts) until he chopped power at the top and we floated off at 55 kts. We have two Supacats. One has a 240 hp Deutz aircooled diesel V8 industrial engine and the second a big diesel straight six, probably around 180 hp: I think we were using the straight six winch today. Both winches drive the drums with a custom gearbox, in turn driven through a fluid clutch. There are no gear changes during a launch. AFAIK the gearbox does the following: - reduction gear. Drum speed is less than engine RPM (of course) - drum selection (its a two drum winch) - oscillating drive for the pay-on system -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Keep trying it. I think you will find you have control over airspeed. 180 - 240 HP isn't nearly enough power to prevent a big 2-seat glider from slowing the winch. I assume Martin flies at the Cambridge Gliding Centre. Their V8 Supacat could not be slowed by pulling (and in fact sped up at times) through multiple attempts by myself and an instructor (both of us in the 200+ lb range) in one of their ASK-21s. The only otherwise unusual outcome was a premature back release late in one launch. This was done with prior knowledge and discussion of the fact that it should theoretically be possible. I'd guess there is no overcoming gobs of torque... Marc As I said, try it again with careful observation. You will find it works though you may have to wait a bit to see the effect. As I said, we discussed ahead of time what would happen if we were to pull harder (for a normal launch, only a small amount of back pressure was needed). We were observing carefully and tried holding the stick on the back stop for a good portion of the climb. We obviously didn't have a huge amount of elevator authority (forward CG from two heavy guys), so maybe we just couldn't generate enough lift on a cold autumn day to exceed the power output of the winch. Or, perhaps you are used to winches that are underpowered... Marc |
#55
Marc Ramsey wrote:
As I said, we discussed ahead of time what would happen if we were to pull harder (for a normal launch, only a small amount of back pressure was needed). We were observing carefully and tried holding the stick on the back stop for a good portion of the climb. We obviously didn't have a huge amount of elevator authority (forward CG from two heavy guys), so maybe we just couldn't generate enough lift on a cold autumn day to exceed the power output of the winch. Or, perhaps you are used to winches that are underpowered... By the way, I absolutely do not claim to be any sort of winch launch expert. I am interested in reviving ground launch locally, was in the UK on business, and chose a number of clubs to visit based primarily on their winch launch operations. I trained according to BGA standards, and was signed off to solo on the winch at a couple of clubs. I also received some training in winch driving, talked to anyone who would listen, and was generally impressed with equipment and the procedures used. I recommend that anyone who is interested in using a winch in the US do the same, we have a lot to learn here... Marc |
#56
Hi Bill,
With our Chevy big block powered Tost winches at Lasham, you cannot slow down by pulling back - if anything it has the opposite effect and risks breaking the weak link. Easing forwards also makes you go faster, so the only way to slow down is to signal to the winch driver by wagging the tail with the rudder. However we tried out a Skylaunch 2 winch for one day last week with a very similar engine and gearbox, but with a sophisticated throttle stop system. With that I could control the speed from the glider, at least in a K21, by about 5 knots either side of the mean speed, which was ideal anyway. Maybe this is because you are being supplied with just the right amount of power. Unfortunately I didn't get a chance to try this out with a lighter glider. Derek Copeland At 18:36 16 December 2007, Bill Daniels wrote: Actually guys, you CAN and SHOULD control airspeed on some winches. There are few winches that have enough power to prevent a large, heavy glider from pulling down the drum RPM. Maybe you guys have one - maybe not. If you are a little too fast, pitch up, load the winch a little and wait to see what the airspeed does. In most cases, it will ease back down to the desired airspeed. If you are a bit slow, lower the nose which unloads the winch a bit and wait for the effect. Once you get the hang of it, it works sweet. Many pilots think this won't work becasue they haven't tried it. Give it a try and get back to us. Bill Daniels 'Andreas Maurer' wrote in message .. . On Wed, 12 Dec 2007 22:33:24 +0000, Martin Gregorie wrote: Speaking for myself, I watched the video and saw a succession of launches with right wing low. As wing low launching is something that, on my field, would earn you a talk with the duty instructor, I was unhappy with the description of this being a 'best practices' event and said so. I agree, Martin. I've never seen such a series of really critical winch launches before. With all due respect - a very serious ground-loop accident is going to happen rather sooner than later. Comment on launch speed. The rules we use a - after lift off, maintain a shallow climb until the ASI passes 50 kts with steady acceleration. - then and only then rotate slowly. The ideal is to complete rotation not less than 5 seconds after lift off. - we have a high torque, high inertia, fluid clutch winch. The pilot cannot and should not attempt to control its speed except by signalling the winch driver. - if you're above Vwinch when the launch starts to flatten toward the top (i.e. when the angle is below 35 degrees or so), release. - if the speed drops toward 50 kts, lower the nose to maintain at least 50 kts and monitor the speed. - if the speed picks up, resume the climb. - if the nose approaches level and the speed doesn't rise, release. The same rules apply for us. Works like a charm. Bye Andreas |
#57
On Sun, 16 Dec 2007 11:34:33 -0700, "Bill Daniels"
bildan@comcast-dot-net wrote: Actually guys, you CAN and SHOULD control airspeed on some winches. There are few winches that have enough power to prevent a large, heavy glider from pulling down the drum RPM. Maybe you guys have one - maybe not. If you are a little too fast, pitch up, load the winch a little and wait to see what the airspeed does. In most cases, it will ease back down to the desired airspeed. If you are a bit slow, lower the nose which unloads the winch a bit and wait for the effect. Once you get the hang of it, it works sweet. Many pilots think this won't work becasue they haven't tried it. Give it a try and get back to us. Hi Bill, I'm giving this a try since over 20 years and I have to admit that the influence of pitch attitude on airspeed is negligible with out 280 hp turbo-diesel winch (even with gliders like ASK-21 and DG-505). On the other hand - I seldom have the need to control airspeed anyway. Anything between 90 and 120 kp/h is perfectly ok - if I'm faster or slower, I decrease pitch attitude. As simple as it gets. ![]() Cheers Andreas p.s.: I think it's usually the response of the winch driver that results in an airspeed increase: If the winch driver notices a sudden pitch-decrease (or an abnormal low pitch) of the gilder, he assumes that the gider is too slow and adds power. We don't have (and don't need) a voice communication between glider and winch. Bye Andreas |
#58
At 13:36 17 December 2007, Del C wrote:
Hi Bill, With our Chevy big block powered Tost winches at Lasham, you cannot slow down by pulling back - if anything it has the opposite effect and risks breaking the weak link. Easing forwards also makes you go faster, so the only way to slow down is to signal to the winch driver by wagging the tail with the rudder. However we tried out a Skylaunch 2 winch for one day last week with a very similar engine and gearbox, but with a sophisticated throttle stop system. With that I could control the speed from the glider, at least in a K21, by about 5 knots either side of the mean speed, which was ideal anyway. Maybe this is because you are being supplied with just the right amount of power. Unfortunately I didn't get a chance to try this out with a lighter glider. Derek Copeland Derek, The Skylaunch system works just as well for very light gliders and it beats me why other designers have not copied the elegant simplicity and effectiveness of the concept of using the progressive torque characterstics of the GM V8 spark ignition engine combined with properly researched throttle limitation. When our club had a Skylaunch for a trial I drove it under the supervision of their super-experienced winch man, Pete Salisbury. To my surprise the K8 pilots were just as complimentary about the suitability and controllability of their launches as were the pilots of heavier gliders. John Galloway |
#59
Andeas:
Andreas p.s.: I think it's usually the response of the winch driver that results in an airspeed increase: If the winch driver notices a sudden pitch-decrease (or an abnormal low pitch) of the gilder, he assumes that the gider is too slow and adds power. We don't have (and don't need) a voice communication between glider and winch. Bye Andreas Despite the danger that Bill Daniels calling me dangerous or some other unsubstantiated claim, I post here to agree with you 100%. Playing around with the airspeed should not be the focus of the launch. It is the winch driver who controls this to the greatest degree. Safety and minimizing risk should be the main focus of the pilot. The incidents mentioned here, are indicative of an increase in risks during winch launches when trying to influence airspeed as discussed in this thread. Weak links breaking as you're pulling back to put strain on the winch or the premature back releases of the cable as you're pulling are certainly not desirable nor add to safety. I am with Andreas that from the pilot's point of view, it should be a simple matter. The winch driver will also get a clue as to what's happening by observing the glider. However, by pushing and pulling as discussed here, the winch driver may not be able to figure out what's going on and perhaps not respond at all or respond in a way that makes thing worse. Since the winch driver is the one who has the most control over speed, you really don't want to confuse him or her. |
#60
On Mon, 17 Dec 2007 16:40:49 -0800 (PST), tommytoyz
wrote: from the pilot's point of view, it should be a simple matter. I think that's the main point. @Bill: I really love the fact that you are trying to promote winch launching in the US - but (please correct me if I'm wrong) from the comments here in this newsgroup I get the impression that you US guys regard the winch launch as something pretty hazardous that needs a lot of technology to be safe. Consequently, your approach to a US winch design looks a little over-engineered to me, I have to admit. Complex and expensive to build, hard to set up correctly. Possibly prone to mechanical problems. Us European guys seem to see things in a more relaxed way - we tend to advocate training instead of technological devices to achieve safe winch operations. Considering the number of accident-free winch launches per year on my side of the pond, don't you think that it might be useful to stick more closely to the KISS-principle ("keep it simple, stupid"), forget all that high-tech stuff and concentrate on correct training? Nearly all the winches here are basically very simple. Anything a winch needs is a strong diesel engine, two drums, 3.500 ft of cable (be it steel or plastic). No rocket science involved. Bye Andreas |
looking for a video | mike regish | Piloting | 20 | May 18th 07 12:27 AM |
ID this video, please | Jay Honeck | Piloting | 9 | January 4th 06 06:37 PM |
Video of RC F-14 | Yeff | Naval Aviation | 3 | April 19th 05 04:30 AM |
VIDEO: Frecce Tricolore collides over Ramstein - a new head on video | Montblack | Piloting | 1 | February 12th 05 04:03 AM |
F-14 and F/A-18 fly-by video | Ditch | Military Aviation | 3 | January 18th 04 03:54 PM |
