They tried, in one previous show, to duplicate the old cartoon shotgun
barrel blow up with the barrel unwinding. They tried to use modern shotguns which are made from solid tubular steel. Shotguns made before about 1920 were generally made by wrapping steel wire around a mandrel and using the old blacksmith welding with a hammer and anvil. Those barrels would have flaws and weak spots. What they showed with landing the NASA simulator is that any person with some level experience with a cockpit display can control an airliner. Most FAA controllers would not have the experience to describe the cockpit and give useful instruction in how to manually fly with the autopilot or where the switches are located, or how to use the radio to even start the "rescue." Maybe they should have an in-flight movie before each take-off on how to fly the airplane, do you think TSA would allow that? "Robert M. Gary" wrote in message ... | On Dec 8, 9:32 pm, Jim Logajan wrote: | "Jamie and Adam take wing to test if a person with no flight training can | safely land an airplane and if a plane can take off from a conveyor belt | speeding in the opposite direction. Tory, Grant, and Kari jump on some | Hollywood-inspired skydiving myths." | | Quoted from the Discovery channel schedule:http://dsc.discovery.com/tv-schedule...=1.13056.24704.... | | (My local paper's weekly TV schedule has just the brief summary "Landing a | 747" so I presume the plane they attempt to land without training is a 747. | Will be interesting to see if they try the real thing and are not limited | to a simulator.) | | I have no doubt that our buddy from France firmly believes he can land | a 747 if necessary. In fact he's done it hundreds of times. | | -Robert |
![]() "Jim Macklin" wrote in message ... They tried, in one previous show, to duplicate the old cartoon shotgun barrel blow up with the barrel unwinding. They tried to use modern shotguns which are made from solid tubular steel. Shotguns made before about 1920 were generally made by wrapping steel wire around a mandrel and using the old blacksmith welding with a hammer and anvil. Those barrels would have flaws and weak spots. More like 1880 than 1920. "Damascus" barrels were not really produced after the 1880's or so, long before the introduction of smokeless powder around 1900. Smokeless powder would easily destroy such a barrel. |
Matt W. Barrow wrote:
"Jim Macklin" wrote in message ... They tried, in one previous show, to duplicate the old cartoon shotgun barrel blow up with the barrel unwinding. They tried to use modern shotguns which are made from solid tubular steel. Shotguns made before about 1920 were generally made by wrapping steel wire around a mandrel and using the old blacksmith welding with a hammer and anvil. Those barrels would have flaws and weak spots. More like 1880 than 1920. "Damascus" barrels were not really produced after the 1880's or so, long before the introduction of smokeless powder around 1900. Smokeless powder would easily destroy such a barrel. Actually it's not the barrels but the chamber that couldn't take the higher pressure. I know one gunsmith that has somewhat permanently (red loctite) installed 20 and 28 gage adapters in 12 gage Damascus steel barrels. The adapter takes the load from firing the cartridge and the rest of the barrels are strong enough for the rest. This makes for a heavy low powered shotgun but it also makes a wall-hanger into a useful piece. Tony |
![]() "Anthony W" wrote in message news:AGd8j.22555$Bg7.20727@trndny07... Matt W. Barrow wrote: "Jim Macklin" wrote in message ... They tried, in one previous show, to duplicate the old cartoon shotgun barrel blow up with the barrel unwinding. They tried to use modern shotguns which are made from solid tubular steel. Shotguns made before about 1920 were generally made by wrapping steel wire around a mandrel and using the old blacksmith welding with a hammer and anvil. Those barrels would have flaws and weak spots. More like 1880 than 1920. "Damascus" barrels were not really produced after the 1880's or so, long before the introduction of smokeless powder around 1900. Smokeless powder would easily destroy such a barrel. Actually it's not the barrels but the chamber that couldn't take the higher pressure. I know one gunsmith that has somewhat permanently (red loctite) installed 20 and 28 gage adapters in 12 gage Damascus steel barrels. The adapter takes the load from firing the cartridge and the rest of the barrels are strong enough for the rest. This makes for a heavy low powered shotgun but it also makes a wall-hanger into a useful piece. After the load leaves the chamber, the barrel does...what (with the internal pressure)? |
On Dec 13, 12:06 am, "Jim Macklin"
wrote: What they showed with landing the NASA simulator is that any person with some level experience with a cockpit display can control an airliner. Most FAA controllers would not have the experience to describe the cockpit and give useful instruction in how to manually fly with the autopilot or where the switches are located, or how to use the radio to even start the "rescue." Maybe they should have an in-flight movie before each take-off on how to fly the airplane, do you think TSA would allow that? Jim, I caught just the parts of the show where J and A tried to land the plane with some coaching from the sim instructor (Mainly to see how the instructor would do this). These portions of the show were amazingly brief (Possibly for security reasons ?) . The stuff they did show was scary and I doubt they could have gotten awhay with some of it in a real plane. I do watch the show for its "Infotaiment" value but I remain unconvinced that someone could actually be talked down in an airliner. I think it has been tried a time or two in GA after the pilot became incapacitated. FB |
F. Baum wrote:
On Dec 13, 12:06 am, "Jim Macklin" wrote: What they showed with landing the NASA simulator is that any person with some level experience with a cockpit display can control an airliner. Most FAA controllers would not have the experience to describe the cockpit and give useful instruction in how to manually fly with the autopilot or where the switches are located, or how to use the radio to even start the "rescue." Maybe they should have an in-flight movie before each take-off on how to fly the airplane, do you think TSA would allow that? Jim, I caught just the parts of the show where J and A tried to land the plane with some coaching from the sim instructor (Mainly to see how the instructor would do this). These portions of the show were amazingly brief (Possibly for security reasons ?) . The stuff they did show was scary and I doubt they could have gotten awhay with some of it in a real plane. I do watch the show for its "Infotaiment" value but I remain unconvinced that someone could actually be talked down in an airliner. I think it has been tried a time or two in GA after the pilot became incapacitated. FB The big rub in the equation are of course the variables. They are HUGE in this equation and any one of them could take out the airplane. Just off the top of my head, one has to factor in the EXACT aircraft in the scenario, as each airline has the option to customize their cockpits to whatever the chief pilot wanted installed at the time of the contract signing with the manufacturer. This aspect alone might well require a company pilot completely familiar with the cockpit of THAT specific airplane, as even in type, changes are made to the cockpit configurations during a manufacturing run as requested by the front office, so that you might have one airplane with a switch or lever "here" and another with it "there". Then you have the issue of getting this company guy familiar with THIS cockpit on the radio and in touch with the guy trying to land the airplane. THEN you need a guy in the cockpit who can not only follow directions NOW, but follow them CORRECTLY and in real time. Notice we're talking here about a manually controlled landing. If the aircraft AND the landing facility are BOTH equipped accordingly, autoland might be a possibility and negate the manual landing. All things considered, my vote goes to doing it in the simulator with the help of the sim instructor but a high risk factor for losing a real aircraft in the manual mode. Could be done of course, but I wouldn't want to be a passenger on that one for sure :-) -- Dudley Henriques |
F. Baum wrote:
On Dec 13, 12:06 am, "Jim Macklin" wrote: What they showed with landing the NASA simulator is that any person with some level experience with a cockpit display can control an airliner. Most FAA controllers would not have the experience to describe the cockpit and give useful instruction in how to manually fly with the autopilot or where the switches are located, or how to use the radio to even start the "rescue." Maybe they should have an in-flight movie before each take-off on how to fly the airplane, do you think TSA would allow that? Jim, I caught just the parts of the show where J and A tried to land the plane with some coaching from the sim instructor (Mainly to see how the instructor would do this). These portions of the show were amazingly brief (Possibly for security reasons ?) . The stuff they did show was scary and I doubt they could have gotten awhay with some of it in a real plane. I do watch the show for its "Infotaiment" value but I remain unconvinced that someone could actually be talked down in an airliner. I think it has been tried a time or two in GA after the pilot became incapacitated. FB I had the opportunity to "fly" a American Airlines F-100 in their full motion simulator with an instructor. He was able to talk me through a landing at O'Hare Airport without crashing the airplane. However, without someone familiar with the aircraft the intimidation of the lights, buttons, dials, radios, switches, etc would overwhelm anyone. -- Regards, Ross C-172F 180HP KSWI |
Ross wrote:
F. Baum wrote: On Dec 13, 12:06 am, "Jim Macklin" wrote: What they showed with landing the NASA simulator is that any person with some level experience with a cockpit display can control an airliner. Most FAA controllers would not have the experience to describe the cockpit and give useful instruction in how to manually fly with the autopilot or where the switches are located, or how to use the radio to even start the "rescue." Maybe they should have an in-flight movie before each take-off on how to fly the airplane, do you think TSA would allow that? Jim, I caught just the parts of the show where J and A tried to land the plane with some coaching from the sim instructor (Mainly to see how the instructor would do this). These portions of the show were amazingly brief (Possibly for security reasons ?) . The stuff they did show was scary and I doubt they could have gotten awhay with some of it in a real plane. I do watch the show for its "Infotaiment" value but I remain unconvinced that someone could actually be talked down in an airliner. I think it has been tried a time or two in GA after the pilot became incapacitated. FB I had the opportunity to "fly" a American Airlines F-100 in their full motion simulator with an instructor. He was able to talk me through a landing at O'Hare Airport without crashing the airplane. However, without someone familiar with the aircraft the intimidation of the lights, buttons, dials, radios, switches, etc would overwhelm anyone. Oh, BTW, at the time I probably had about 800 hours and I have a CPSEL/IA. However I fly for self entertainment -- Regards, Ross C-172F 180HP KSWI |
Ross wrote in
: F. Baum wrote: On Dec 13, 12:06 am, "Jim Macklin" wrote: What they showed with landing the NASA simulator is that any person with some level experience with a cockpit display can control an airliner. Most FAA controllers would not have the experience to describe the cockpit and give useful instruction in how to manually fly with the autopilot or where the switches are located, or how to use the radio to even start the "rescue." Maybe they should have an in-flight movie before each take-off on how to fly the airplane, do you think TSA would allow that? Jim, I caught just the parts of the show where J and A tried to land the plane with some coaching from the sim instructor (Mainly to see how the instructor would do this). These portions of the show were amazingly brief (Possibly for security reasons ?) . The stuff they did show was scary and I doubt they could have gotten awhay with some of it in a real plane. I do watch the show for its "Infotaiment" value but I remain unconvinced that someone could actually be talked down in an airliner. I think it has been tried a time or two in GA after the pilot became incapacitated. FB I had the opportunity to "fly" a American Airlines F-100 in their full motion simulator with an instructor. He was able to talk me through a landing at O'Hare Airport without crashing the airplane. However, without someone familiar with the aircraft the intimidation of the lights, buttons, dials, radios, switches, etc would overwhelm anyone. And that's only a little fartbox of a jet! Bertie |
F. Baum writes:
Jim, I caught just the parts of the show where J and A tried to land the plane with some coaching from the sim instructor (Mainly to see how the instructor would do this). These portions of the show were amazingly brief (Possibly for security reasons ?) . The stuff they did show was scary and I doubt they could have gotten awhay with some of it in a real plane. I do watch the show for its "Infotaiment" value but I remain unconvinced that someone could actually be talked down in an airliner. I think it has been tried a time or two in GA after the pilot became incapacitated. A small GA airplane is completely different from an airliner, but in any case, it has been done successfully in small planes. No circumstances have ever required it in airliners, but it's certainly doable. |
Mythbusters Episode and FMS | Marco Leon | Piloting | 19 | February 13th 07 05:45 AM |
..and another hour... | hellothere.adelphia.net | Rotorcraft | 7 | October 7th 04 11:26 AM |
Mythbusters and explosive decompression | Casey Wilson | Piloting | 49 | July 15th 04 05:56 PM |
MythBusters | Hilton | Piloting | 7 | February 4th 04 03:30 AM |
Mythbusters Explosive Decompression Experiment | C J Campbell | Piloting | 49 | January 16th 04 07:12 AM |
