spins from coordinated flight
Old December 28th 07, 07:10 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default spins from coordinated flight
Dudley Henriques wrote in
Todd W. Deckard wrote:
I have a limited exposure to spins (I've demonstrated spins or
received spin instruction in 5 different airplanes on
six different occasions). I have a commercial certificate (although
you wouldn't think so from my demonstration
of a chandelle). Maybe I did have to demonstrate a power on stall
while in a climbing 20 degree bank, once.
As I recall, we survived it.
I return to the original question: if the ball is in the middle will
it spin?
Becuase I believe snowmobile suits are for snowmobiling and not for
flying I won't have a chance to explore it
with an aerobatic instructor and an appropriate (but drafty) airplane
for a few months -- so I thought I would
put the question in a bottle and throw it in the ocean.
Regards
Todd
news:f2aea120-c3c7-497c-bf68-
On Dec 27, 1:42 pm, "Todd W. Deckard"
Can you depart and spin from coordinated flight? Specifically a
coordinated
climbing turn?
And courting disaster doing a chandelle? If you're going to do a
commercial ticket you should be familair with spins intimately. An
incipient spin shouldn't even make you break a sweat.
The answer to the ball question is no. It won't spin. A ball centered
airplane in a climbing turn is compensated by rudder and is considered
coordinated (in the classic sense).
If you introduce a climbing turn stall with the ball centered, you
might get a temporary wing drop at the break but unless you introduce
a yaw rate as the stall breaks; no yaw rate...no spin!
Hm, yeah. I'l have to explore this abit when I get a chance. I was fond
of allowing the aiplane to snap over the top and allowing it to enter a
spin in thei scenario to demonstrate to students how easy it was to
enter a spin from a departure stall. Having said that, it always
required unco-ordinated flight, no matter how slight.
Lesson was to keep your eye on the airplane and not sit there FDH.
Bertie
  #52
Old December 28th 07, 01:58 PM posted to rec.aviation.piloting,rec.aviation.aerobatics
Todd W. Deckard
For my conclusion I am fixed in the stall + yaw = spin (where I was to start
with).
I appreciate the references to the Transport Canada material as the tendency
for the airplane to
"go over the top" when snapping over from a climbing turn was a very needed
reminder and
I intend to experiment with it aggressively next year with the appropriate
equipment and circumstances.
At Mr. Henriques suggestion I solicited an explaination from Rich Stowell:
He is the evangelist for the P-A-R-E recovery acronymn.
Power (to idle)
Ailerons (to neutral)
Rudder (against the spin)
Elevator (briskly forward to break the stall).
I must say he drafted a very thoughtful response to me in a direct email.
The only conclusion I can offer to this essay is to point to his web site,
and his book(s):
http://www.richstowell.com/
He articulately explained that the inclinometer is not a precise indication
of coordinated flight and that
some form of yaw is a necessary ingredient to the spin.
With this I'll sign off, thanks for the responses.
Todd Deckard
  #53
Old December 28th 07, 02:33 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
it spin?
Regards
Todd
coordinated
climbing turn?
Bertie
This is normal and many instructors (including myself BTW) use the
climbing turn power on stall as an intro to spin entry as a
demonstration (after careful verbal preparation with the student).
What screws everybody up when dealing with whether the airplane will
spin out of this cfg are the variables that are taking place as the
airspeed dissipates just before the stall break.
I personally don't like relying on the ball as the prime reference for
yaw cancellation when entering this regime just before the stall.
Between the slipstream forces and engine torque, the ball can be used as
a general indicator for correction but is seldom dead on as an indicator
that all yaw has been canceled out. The rub is that ther's a chance of
discrepency between a centered ball and a true canceling of all yaw from
the vertical axis of the airplane.
Like most aerobatic instructors, I like visual cues in these situations
and teach them constantly even to primary students. The wingtip is a
great visual cue as you approach stall. If you stabilize the low wingtip
tip visually against the ground then watch the left tip carefully, when
the yaw has been compensated for by the correct amount of opposing
rudder, that low tip will remain stable. If more rudder is needed, the
tip will appear to move back on you. Stabilize that low wingtip and the
stall break will be center nose down with little wing drop and little
tendency to spin (no yaw...no spin).
It's yaw if present, coupled with the other variables present in an
uncoordinated cfg as the stall breaks that can cause that severe wing
drop. This coupled with SUSTAINED UNCORRECTED YAW is what will produce a
pro spin scenario.
What confuses people the most about the stall break explanation as
relates to wing drop is that even with yaw compensated for, there is
still an AOA difference between the wings and possible interference with
the high wing at the stall break. This is what causes that over the top
scenario so familiar to everyone.
There is as well the possibility of a low wing breaking stall under
certain conditions of control misuse as the stall is breaking, but over
the top is usually what happens.
Dudley Henriques
  #54
Old December 28th 07, 02:35 PM posted to rec.aviation.piloting
it spin?
Regards
Todd
coordinated
climbing turn?
fond of allowing the aiplane to snap over the top and allowing it to
enter a spin in thei scenario to demonstrate to students how easy it
was to enter a spin from a departure stall. Having said that, it
always required unco-ordinated flight, no matter how slight. Lesson
Bertie
pro spin scenario.
...should read "watch the LOW tip carefully. I was mentally doing a left
climbing turn stall and wrote left instead of low :-))
Dudley Henriques
  #55
Old December 28th 07, 04:31 PM posted to rec.aviation.piloting
as
indicator
from
Yeah, OK, I'd go along wiht this.
situations
wingtip
when
a
pro spin scenario.
with
top
over
Yeah, OK. jibes with my experince ( I think, been a while).
NEver thought of looking at the tip during it. I'll try it and let you
know how I get on!
Bertie
  #56
Old December 28th 07, 04:57 PM posted to rec.aviation.piloting
as
indicator
from
situations
wingtip
when
a
pro spin scenario.
with
top
over
know how I get on!
Bertie
Works like a charm in the vertical plane as well...loops....Cubans...etc.
Dudley Henriques
  #58
Old December 28th 07, 08:44 PM posted to rec.aviation.piloting
Dudley Henriques wrote in news:9-qdnZO8Tvdst-
know how I get on!
Bertie
Well, for that, obviously! I always had problems with reverse cubans
though. I never did figure out a way to track my rotation perfecly going
up. So, I just avoidd them!
Bertie
A Reverse Cuban or more correctly a 1/2 Reverse Cuban since the complete
maneuver is simply two maneuvers done back to back put together :-) is
in my opinion one of the hardest maneuvers for a novice to get right.
First of all, it requires a high entry speed. For this reason, and as
well the slow roll rate of the Citabria and other flat wing light
aerobatic trainers, doing a good 1/2 reverse Cuban is not the easiest
thing to accomplish.
You can do one, but it amounts to a sloppy 1/2 roll at the top followed
almost immediately by a Split S. It isn't pretty in these airplanes.
To do a 1/2 Reverse Cuban correctly, you need an established 45 degree
up line erect, a quick 1/2 slow roll and an inverted 45 degree up line
continued as the energy drops down to the 1/2 inside Loop recovery.
The timing is critical as is the airspeed at the top gate as the pull is
initiated. In an underpowered airplane restricted by a low never exceed
speed you are severely hampered in obtaining the energy required to do
the maneuver properly.
As for visuals; you use the wing tips for establishing BOTH up lines
right side up and inverted, but in a Citabria or an Aerobat for example,
the low entry speed coupled with the energy lost doing the roll to
inverted leave you with little time to even establish an inverted 45
degree up line :-)
The result is sort of like doing what I refer to as a 1/2 whale roll and
a pull down into a 1/2 loop recovery.
You can get a decent 1/2 Reverse Cuban out of a Decathlon but barely :-)
Now the Extra, or a Pitts is another matter entirely :-))
But don't feel bad about not getting this one down just right. Actually
if you DID get one right within the airspeed and g limits suggested for
the Citabria or Aerobat type airplane you happened to be flying, you'd
be doing quite well :-)
Dudley Henriques
  #59
Old December 28th 07, 11:45 PM posted to rec.aviation.piloting
you know how I get on!
Bertie
going up. So, I just avoidd them!
Bertie
complete maneuver is simply two maneuvers done back to back put
together :-) is in my opinion one of the hardest maneuvers for a
novice to get right. First of all, it requires a high entry speed. For
this reason, and as well the slow roll rate of the Citabria and other
flat wing light aerobatic trainers, doing a good 1/2 reverse Cuban is
not the easiest thing to accomplish.
followed almost immediately by a Split S. It isn't pretty in these
airplanes. To do a 1/2 Reverse Cuban correctly, you need an
established 45 degree up line erect, a quick 1/2 slow roll and an
inverted 45 degree up line continued as the energy drops down to the
1/2 inside Loop recovery. The timing is critical as is the airspeed at
the top gate as the pull is initiated. In an underpowered airplane
restricted by a low never exceed speed you are severely hampered in
obtaining the energy required to do the maneuver properly.
example, the low entry speed coupled with the energy lost doing the
roll to inverted leave you with little time to even establish an
inverted 45 degree up line :-)
and a pull down into a 1/2 loop recovery.
:-) Now the Extra, or a Pitts is another matter entirely :-))
Actually if you DID get one right within the airspeed and g limits
suggested for the Citabria or Aerobat type airplane you happened to be
flying, you'd be doing quite well :-)
I used to od them in the Decathlon and they were OK ish, but certainly
not up to competition standards. It was the lack of decent reference,
really, not so much the performance or the agility of the airplane.
Going vertical was OK since the wingtip would stay at the same place on
the way up, but on a 45 I had nothing I could ever get a bead on to
maintain the line. They were OK. I didn't end up 90 deg to m entry
heading or anything, just not all that tidy.
It'll be interesting to see if I can do any better second time around!
Bertie
  #60
Old December 29th 07, 12:23 AM posted to rec.aviation.piloting
Bertie
Bertie
Bertie
I'm sure you will.
Generally for practice anyway, you can pick a long road or anything
straight in front of you extending a bit into the distance. Do the roll
as a slow roll but do it fast. The visuals are easy really in this
scenario. Use the left tip and form a 45 with about a 4g pull and set to
the angle formed by the wing and the horizon. It isn't nearly as
accurate as a metal or FG tip cross attachment but close enough for
government work.
Do the roll quickly holding in some excessive forward pressure past
knife and on into inverted. The Citabria will have a seemingly VERY high
inverted nose attitude at the inverted 45 due to the flat wing and angle
of attack needed to keep the airplane stable on the 45 inverted up line.
As you go past knife edge switch the visual cue directly over the nose
and pick up the extended reference and adjust if needed for the vertical
maneuver line. Check the wingtip for the inverted 45 up line but be
aware that in the Citabria you probably won't have any excess inverted
up line time available before you relax the forward pressure and go
through the float at the top. You should be just above stall so don't
pull down, just relax the forward pressure and let the airplane float on
through, then gently pull down as the airspeed starts to increase. Use
about a 4g maximum radial g pull on the back side.
When you can do this one well in the Citabria, you get the Gold Star for
being able to fudge a 1/2 Reverse Cuban and make it look good in a
Citabria :-))
Dudley Henriques
Coordinated turns without rudder, and autopilots Mxsmanic Piloting 188 June 1st 07 07:09 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
Snap / Flick and spins in flight simulators [email protected] Simulators 1 September 2nd 06 07:10 AM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
