#51
Hi - the thread seems to have been hijacked, but a few thoughts for
you: Get flight following before arriving at the area - that will make things easier. They are pretty likely to accommodate you if you sound competent on the radio. You could fly a bit lower, under the class B shelf, and contact Morristown tower for permission to transit their airspace. This will be granted, almost certainly. There is a VFR transit route directly through NYC, down the Hudson River. It's a bit hard to see on the TAC, but it is there - you can fly all the way down the Hudson as long as you stay below certain altitudes (the lowest is 1100 ft for the bits adjacent the city). You really should do this route, as it is a lot of fun and very very scenic. just make sure you are well prepared, study the TAC (and the back of the TAC too) in advance, and perhaps get the advice of a local pilot too. I can help you with this if you want. good luck! Tom Second question since I'm on the topic. *I've never flown through any class B airspace. *If i popup knocking on the door, having planned a flight to avoid the airspace, what is the chance that they will clear me through it for asking? *For example, I'm planning a flight that will save a couple miles if i can cut through the NY Class B, on the west side, e.g. over Morristown field, and I may not want to get up over the 7,000 ceiling due to winds aloft. *Is it more likely to get clearance to cut a chord through the outer ring like this -- as opposed to say expecting to, say, overfly the Statue of Liberty vicinity at 5,500 (which is much closer to the center rings of the Class B). *I don't see any VFR transit routes from a quick glance of the NY TAC. *I guess my strategy would be to plan a circutous route that keeps my clear of the Class B, but then when I'm close (but not too close), ask if i can cut direct through it to my destination. *IF yes, I'll just aim for a VOR on the other side.... Any thing I can do to, perhaps planning the right route through, to increase my chances of getting clearance? Thanks -- Tman! |
#52
John Mazor writes:
No matter how much you tout the value of opinion ... I don't assert that opinions are valuable, because their value is very low. However, all opinions have an equal value, and that is the important point. ... to the point of claiming that "my opinion is irrefutable because it's an opinion," opinion isn't fact. I haven't said this, although others have said essentially the equivalent. It's a fact that simming isn't flying. That depends on what you consider flying. Is being a passenger in an aircraft flying? Is moving through the air without flapping wings flying? Answer carefully. |
#53
Tom writes:
There is a VFR transit route directly through NYC, down the Hudson River. It's a bit hard to see on the TAC, but it is there - you can fly all the way down the Hudson as long as you stay below certain altitudes (the lowest is 1100 ft for the bits adjacent the city). You really should do this route, as it is a lot of fun and very very scenic. just make sure you are well prepared, study the TAC (and the back of the TAC too) in advance, and perhaps get the advice of a local pilot too. I can help you with this if you want. Is there a FLY chart for New York? I don't see one on SkyVector. |
#54
"Mxsmanic" wrote in message ... John Mazor writes: No matter how much you tout the value of opinion ... I don't assert that opinions are valuable, because their value is very low. However, all opinions have an equal value, and that is the important point. ... to the point of claiming that "my opinion is irrefutable because it's an opinion," opinion isn't fact. I haven't said this, although others have said essentially the equivalent. It's a fact that simming isn't flying. That depends on what you consider flying. Is being a passenger in an aircraft flying? Is moving through the air without flapping wings flying? Answer carefully. That depends on what your definition of "is" is. Answer carefully. |
#55
MX has been known to defy conventional use of words many times.
Reading his posts is more or less like seeing a turn signal used in Boston: all you can be sure of is the lamp isn't burned out. In his case you can be sure he still has a connection the the 'net. On Jan 5, 10:41*am, "John Mazor" wrote: "Mxsmanic" wrote in message ... John Mazor writes: No matter how much you tout the value of opinion ... I don't assert that opinions are valuable, because their value is very low. However, all opinions have an equal value, and that is the important point. |
#56
Tina wrote:
MX has been known to defy conventional use of words many times. Reading his posts is more or less like seeing a turn signal used in Boston: all you can be sure of is the lamp isn't burned out. In his case you can be sure he still has a connection the the 'net. Probably paid for by someone else. |
#57
Mxsmanic wrote:
That depends on what you consider flying. Is being a passenger in an aircraft flying? Is moving through the air without flapping wings flying? Answer carefully. According to the dictionary they are. -- Jim Pennino Remove .spam.sux to reply. |
#58
Mxsmanic wrote in
: John Mazor writes: The voices in his head must do a good job of simulating radio traffic. No voices in the head are required. The traffic is provided by other pilots and controllers on the network. Nope Bertie |
#59
"John Mazor" wrote in
news:68Bfj.254$Xo1.93@trnddc06: "Mxsmanic" wrote in message ... John Mazor writes: So they go away while you're on a sim? What does? Oh, dear. Looks like we need to add ADD to your list of ailments. That would explain why you spend so much time on it - kind of like the old joke about the guy who hits himself on the head with a hammer because it feels so-o-o good when he stops. I spend a lot of time on simulation because I like to fly. At the risk of encroaching on Bertie's schtick - that ain't flying, fjuckwit. That'#s OK. I got a million of em. Bertie |
#60
Mxsmanic wrote in
: John Mazor writes: At the risk of encroaching on Bertie's schtick - that ain't flying, fjuckwit. That is a matter of opinion, and viewpoint. No, it's a matter of fact. Bertie |
| Thread Tools | |
| Display Modes | |
| Flight Questions | Jed | Piloting | 32 | September 15th 07 04:12 PM |
| flight level questions | [email protected] | Instrument Flight Rules | 1 | August 14th 06 10:13 PM |
| Yesterday's IFR flight with questions | A Lieberman | Instrument Flight Rules | 30 | November 23rd 05 11:31 PM |
| Nice Surprize During Pre Flight, And A Few Odd Questions | MRQB | Owning | 12 | March 25th 04 12:26 AM |
| IFR flight in MSFS '98 questions | Sydney Hoeltzli | Simulators | 9 | July 31st 03 01:05 AM |
