#51
On Jan 9, 5:07*pm, Andreas Maurer wrote:
But trust me - you won't feel a difference between 36:1 and 38:1... but you are going to feel the difference between 31:1 and 1:36. *vbg Hey, I took a flight in the front seat of a DG-1000. Want to talk about a differencein L/D? heheheheh... Pure sink rates don't work - you also need to incorporate the airspeed in your judgement since this decides about turn radius. Not to mention Fair enough. This is also where flaps can help - moderate flap application = lower speed thermalling; so as long as the drag isn't too bad from the flap deployment you should have a net gain in climb performance as you can make tighter thermal turns. But my Russia stalls at around 39 kts indicated (I am 200 lbs and 6' tall - a big American *sigh*)... The aircraft really likes a 45- degree thermal turn at about 48 - 50 knots (min-sink speed is around 42kts so that jibes well with the load-factor of a 45-degree turn). I think most of the gliders from the late 70's and early 80's have similar stalling speeds - so as long as I stick to models that have the good roll control and responsiveness that I seek, their ability to have a tight thermalling circle should be adequate. I promise: you are going to be blown away by their performance - and you are not going to be able to judge which of them has the better performances. Especially flapped ships need a couple of dozen of hours Well I've flown my Russia AC-4 *alongside*: Apis 13m (equal in climb, small but noticeable difference in height per mile of cruise), PIK-20B (could out-thermal it, but not keep up on glide), 1-34 (Russia was noticeably better all around; though not by a big margin), Chinook S 17m (I was slightly worse in climb, no comparison in glide), Open Cirrus (I had the slight edge in climb w/small circles; but the damned Cirrus just defies gravity and lumbers along for miles), Blanik L-13 (I was slightly better in glide, slightly better on a ridge, and noticeably better in thermals), DG-1000 (hahahahaha! "alongside" is almost a misnomer...) Plus I have my Private Pilot's License in single-engine aircraft (got that before starting in gliders) - so I'm familiar with flaps and that stuff... way to current (German) standard classgliders. You can get a comparably young 55 for the same price as an aolder German ship. Definitely worth a closer look. Huh. Lot of varying opinions about that it seems! Some people seem to think I could get one for around $30k, others think $50k - $60k... interesting. Can I have one of you "cheaper" people call some SZD-55 owners and convince them to sell it for less? *grin* Thanks all, don't be shy to pile on more feedback! :-) --Noel |
#52
On Wed, 9 Jan 2008 17:48:11 -0800 (PST), "noel.wade"
wrote: Fair enough. This is also where flaps can help - moderate flap application = lower speed thermalling; so as long as the drag isn't too bad from the flap deployment you should have a net gain in climb performance as you can make tighter thermal turns. Unfortunately it's not that way, at least not in the flapped gliders I fly. ![]() Usually you don't thermal a flapped glider significantly slower nor do you climb better than a non-flapped ship. The advantage is that you can ballast a flapped glider to higher wing loadings (while still being able to thermal halfways slowly) to increase your cruise speed - and of course the flatter polar at higher speeds even without ballast. In weak weather there's really no noticable performance difference between flapped and non-flapped gliders - but the better the weather (=higher wing loading and higher cruise speeds), the bigger the difference. But my Russia stalls at around 39 kts indicated (I am 200 lbs and 6' tall - a big American *sigh*)... LOL... I'm as heavy as you, but 7" taller... I think most of the gliders from the late 70's and early 80's have similar stalling speeds - so as long as I stick to models that have the good roll control and responsiveness that I seek, their ability to have a tight thermalling circle should be adequate. Indeed. Well I've flown my Russia AC-4 *alongside*: Apis 13m (equal in climb, small but noticeable difference in height per mile of cruise), The Apis has pretty good numbers on paper, but I suspect that its low wing loading makes penetration at higher speeds bad compared to a ballasted Standard class glider. Plus I have my Private Pilot's License in single-engine aircraft (got that before starting in gliders) - so I'm familiar with flaps and that stuff... Not even similar, I'm afraid. ![]() Perhaps I was spoiled by the ASW-20 that way my first flapped glider, but at least in the 20 I had the feeling that I needed about 50 hours until I felt I had mastered it halways because especially the 20 needs pretty precise adjustment of the flap setting to the current speed, wing- and g-loading, meaning that the left hand is nearly as busy as the right one. The LS-3 is easier to handle (wrong flap settings have less negative influence on the performance), the optimum is probably the DG-300 and LS-4... lol. Think twice if you really need flaps on your glider (and if youre willing to pay them) - if the weather is really weak in the area you fly in, flaps won't give you a noticeable performance advantage. Huh. Lot of varying opinions about that it seems! Some people seem to think I could get one for around $30k, others think $50k - $60k... interesting. Can I have one of you "cheaper" people call some SZD-55 owners and convince them to sell it for less? *grin* The problem on oyur side of the pond is the very limited number of available used gliders. Move to Europe. Plenty of really good used gliders here. Bye Andreas |
#53
Frank Whiteley wrote:
On Jan 9, 2:42 am, "noel.wade" wrote: Thanks Adam, but I'm not interested in a medium-performance metal ship. The Jantar Standard 2 is a fine first ship; but its not enough of a performance jump from my Russia to be an appealing choice. I believe that my budget affords ships that are newer and have better performance - whether they're standard-class or flapped. And I am more interested in those options. Appreciate it, though! --Noel Std Jantars are glass and strong. Consider the following world record. Speed over a triangular course of 100 km : 249.09 km/h Date of flight: 01/12/2003 Pilot: Horacio MIRANDA (Argentina) Course/place: Chos Malal (Argentina) Glider: PZL-Bielsko SZD-48-1 Jantar Standard 2 Registered 'LVDPD' Insanely fast. Must've been something like one of the "Power" online tasks for Condor! Shawn |
#54
I've been following this post with some interest as I used to own a
Russia AC-4c. I moved up to a Zuni II and also 1/2 of an LS-8. Last year, I took a club member on a drag and drop. He flew my Zuni with me in the LS-8. After a decent 200km flight, we were on a final glide home. After 26 miles at 80-90 kts, the Zuni was 1000' lower than the LS-8. So 5 times the price will get you a 1000' in 26 miles. The Zuni will also thermal with a PW5. There is now another Zuni on the field at Tucson. I really enjoy my Zuni. Randy "AV8" |
#55
On Jan 10, 8:58*am, LOV2AV8 wrote:
I've been following this post with some interest as I used to own a Russia AC-4c. *I moved up to a Zuni II and also 1/2 of an LS-8. *Last Thanks, Randy! As far as specs and performance and looks, I like the Zuni II. I just really did not like the all-flying-tail coupled with the push/pull stick arrangement. Plus, the flap crank-handle interfered with my leg. :-/ I am in agreeance with you as well, that the large extra cost of newer gliders only nets you a small performance gain. However, it does get you a better surface finish (usually), probably a nicer trailer, better cockpit safety & ergonomics, and other intangibles. That's why I've set a budget, set certain benchmarks, and am looking to maximize the glider I can get for that budget and with those benchmarks (instead of purely looking for max performance, or purely looking for the cheapest solution). :-) It makes things more complicated; but also makes me a more happy owner in the end - or at least that's the theory!! Take care, --Noel |
| Thread Tools | |
| Display Modes | |
| Glider Model - Blaue Maus- 1922 Wasserkuppe Glider | [email protected] | Soaring | 5 | November 20th 06 12:08 AM |
| shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 03:05 PM |
| Schweizer 1-35 and other flapped sailplanes | Jack | Soaring | 39 | August 22nd 05 09:57 PM |
| CHT recommendations | Dude | Owning | 3 | December 26th 04 06:07 PM |
| MFD recommendations | Richard Kaplan | Products | 13 | January 27th 04 05:04 PM |
