Mayday in Utah
Old June 12th 08, 06:22 AM posted to rec.aviation.soaring
Default Mayday in Utah
Today (June 11) Oakland Center asked the Global Hawk Test Team to help
with a Mayday call from a motorglider in Utah. The team was flying a
new Global Hawk somewhat above 50,000 feet north of Edwards AFB and
was 8 hours into a 30 hour mission to test the sensor suite when OAK
Center made the request. Center reported a Mayday from a "powered
glider with a failed engine" and asked if the Hawk could join in the
search and rescue. Fortunately good news followed that the
motorglider had safely landed.
You all be careful out there. We don't fly Hawks every day. It is
better to have a SPOT and/or an ELT.
Soar safe, have fun, go fast and far,
Jim Payne
Old June 12th 08, 02:36 PM posted to rec.aviation.soaring
JJ Sinclair
*Center reported a Mayday from a "powered
Sounds like one of our motorized brethren actually had to SOAR his way
out of trouble. Got to be tough when one presses the iron thermal
button and gets no put-put noise.
JJ
Old June 12th 08, 08:00 PM posted to rec.aviation.soaring
Darryl Ramm
On Jun 12, 5:36*am, JJ Sinclair wrote:
**Center reported a Mayday from a "powered
JJ
JJ
You are sounding a little bitter JJ. :-) Put-put? Maybe in past times.
Most motorgliders now sound more like gas powered weed whackers. The
ASH-26E sounding like a particularly fine weed whacker IMNSHO.
Seriously - it should be an unusual situation to declare an emergency
because of an engine failure to start. Most motorglider pilots will do
starts over a suitable landing location should things not go well. And
should allow for things like stuck partially extended engine masts
etc. I've had to put my motorglider into a field because of a mistake
I made. The only real hassle was having to call a non-motorglider
pilot to come retrieve me and put up with some teasing (thank God it
was not J.J.). Utah can be intimidating, desolate areas etc. and maybe
the pilot had a good reason to do what they did.
Darryl
Old June 12th 08, 04:56 PM posted to rec.aviation.soaring
5Z
Sounds like the pilot involved has a really odd sort of
mindset - mired in the world of powered flight. I mean,
what's the use of those long wings if you're not going
to use them?
OK, I'm sure some of you are jesting, but here's what *might* have
happened:
Pilot is soaring over remote Utah with some reasonably safe looking
dry lakes, pastures, whatever below. Runs out of lift and decides
it's time to start the engine while within easy range of one of these
landing options. The engine fails to start, the location is extremely
remote, so pilot makes a MAYDAY call while still in the landing
pattern to ensure someone will come get him if problems arise.
If he had a transponder or SPOT, he might activate these before
landing, again in case something bad happens.
When I fly my ASH-26E, I'm always planning to land it somewhere
safely, but it's a welcome relief when the engine starts. It's just
plain stupid to not be preparing to land as one is starting the engine
- just in case.
-Tom
Old June 12th 08, 05:29 PM posted to rec.aviation.soaring
Scott[_7_]
to use them?
happened:
- just in case.
-Tom
Way back, as a powered pilot student, I was always taught to constantly
be scanning for suitable landing sites if the fan stopped and I became a
glider. Since I've never been to Utah, I don't know the terrain but
always assumed a lot of those dry lake beds, etc with some mountains
thrown in here and there
Scott
Old June 12th 08, 05:41 PM posted to rec.aviation.soaring
FreeFlight107[_2_]
mindset - mired in the world of powered flight. *I mean,
to use them?
happened:
dry lakes, pastures, whatever below. *Runs out of lift and decides
landing options. *The engine fails to start, the location is extremely
Easy Cowboys, if you transmit a MAYDAY or activate your transponder to
Mayday before landing and land where radio transmission is not likely
to reach anyone, wouldn't this activate SAR missions? If one had ELT
or SPOT this could be used on the ground anywhere except in dense
jungle, right?
Granted in Utah & Nevada you could actually land in an area so remote
that not even a paved road for 50 miles is near your dry lake or open
desert landing, in which case this would be prudent. I guess what I'm
saying is, if you could still be in deep doo-doo after a landing, it
would be prudent to Mayday, but if the landing is pretty near
civilization, maybe hold off till you get on the ground?
Any comments from SAR people on this?
Old June 12th 08, 06:02 PM posted to rec.aviation.soaring
Tim Taylor
to use them?
happened:
- just in case.
-Tom
Scott
Southern Utah, lots of mountains, scrub, river beds and very few dry
lake beds, epically this year. There are alfalfa fields in some
valleys.
Google Earth Duck Creek Village Utah, the runway is not usable by
gliders. Fence posts on each side that will let a Cezzna land but not
gliders. You will notice the elevation is 8400 feet, don't want to
think about the density altitude the day I was forced to land there
(way over 10,000 feet). Went from fat dumb and happy to Oh sh#* in
about two minutes by a thunderstorm miles away. The only lucky thing
was I was flying a Ventus B that day and could get it into one of the
meadows and stopped in about 300 feet.
I can understand the precautionary Mayday if you are not sure you are
going to make a good landing and no one knows where you are. Often I
can be anywhere in 90,000 square miles out here. Without an ELT
signal or spot they will find my bones ten years from now when a
hunter stumbles on the glider. I think a Mayday with coordinates
would be a good idea. Yes I fly with an ELT, but it has to work.
Where is Steve Fossett?
Old June 12th 08, 08:59 PM posted to rec.aviation.soaring
Scott[_7_]
May PAN PAN might be more appropriate. I believe MAYDAY is supposed to
be used when loss of property or life is imminent. Pan Pan is for
"urgent" situations. I realize it's a judgement call, but I'd use PAN
PAN if I was lost or something, and MAYDAY when a wing or tail feathers
departed the plane. Maybe the Feds should add an Oh S***! phrase since
all one has to do is remember to key the PTT line because Oh S*** comes
out without even the slightest thought as "Now what were those proper
FAA phrases?"
Scott
Sparrowhawk 300 km in Utah Mike the Strike Soaring 8 May 6th 07 04:33 AM
MAYDAY in the Everglades Marty from Sunny Florida Owning 46 May 16th 05 11:01 PM
Utah Bush Flying O-Usagi Piloting 3 March 22nd 04 05:24 PM
Region 9 - Parowan Utah Dirk Elber Soaring 0 February 9th 04 01:54 AM
St George Utah Casey Wilson Piloting 6 August 9th 03 05:17 AM
