#51
Mike writes:
You mean the damage which was improperly repaired almost 10 years prior? Yes. Why didn't he catch it on the preflight? You said that if you miss damage on a preflight, you're not doing a preflight. Do you even know what a bulkhead is? Yes. Apparently the pilot of that aircraft didn't do a preflight inspection, because you've indicated that the only way to miss damage is to not preflight the aircraft. |
#52
Mike writes:
The chances of any such 'invisible' damage being a safety of flight issue are pretty much nil. What natural law ensures that damage related to safety is usually visible? It seems to have failed that Japanese pilot, not to mention a long list of other pilots. |
#53
Mike writes:
I always give each side a good heave up and down for this very reason, so such can easily be checked on the preflight for impending failure. It is unlikely that you can create the same magnitude and type of stress with "a good heave" that the aircraft would or could experience in flight. Certainly. But that's what pre-flight and annual inspections are for. My A&P found a cracked bulkhead in the tail on my first annual after I bought the plane. It had probably been that way for years. Such problems you mentioned are common, but how many airframes do you see breaking up in flight because of it? More than necessary. And an annual inspection provides a year for things to go wrong in flight. The preflight is just a simple way to find out if the aircraft is airworthy to the best of the pilot's ability. I never suggested it was anything else, so you should go back and check your inference for any degree of reasonableness. You said that if a pilot doesn't find damage, he hasn't done a preflight, which implies that a preflight will find all damage. Have you changed your mind? So why do you take a simple statement and take it to the nth degree? It is only necessary to show that the statement cannot stand, which has been done. The previous poster (who has no flight experience, btw) condemned partial ownership because another owner might "damage" the airplane and not tell anyone. It was a ridiculous statement to begin with because a proper preflight and regular inspections make such a non issue to the safety of flight. Except that this is not true. You made an absolute statement where a qualified one was required. If you don't want to get flamed, try working your way up the thread and figuring out what the context is before you jump on a comment and try to make it something it isn't. In the future, structure your statements more carefully, and you will not find yourself in a corner in debate. My "comment" was far more valid than yours, BTW. Your statement that, in effect, a preflight cannot fail to find damage and that a pilot who does not find damage has not done a preflight inspection was manifestly false, and does a disservice to pilots who do a thorough preflight inspection and yet die anyway as a consequence of damage that no preflight inspection can detect. |
#54
Charles Talleyrand wrote:
My kid and I just washed the plane. Even after washing it, there are still chips of paint missing, a bit of rust, a drip-stain of fuel, and so on. The panel looks like it has been modified every once in a while since 1966. My plane is relatively nice compared to the other ones on the field, but it's still in worse cosmetic condition than my car. None of these problems is a safety issue, and none of them could be fixed without spending significant time and/or money. One of the reasons we own airplanes is pride of ownership. This makes me sad. Makes me want to sell and rent. We added this stuff to our Aerostar (inboard wing sections and horizontal stabs not protected by the de-ice boots). Works wonders. No stone chips. As for the rust... deal with it. Not only is it a sure sign you need a paint job, it also tells me you're not spending enough time with your baby. :-) http://www.getwrapped.ca/leadingedge/ |
#55
"Mxsmanic" wrote in message
... Mike writes: You mean the damage which was improperly repaired almost 10 years prior? Yes. Why didn't he catch it on the preflight? You said that if you miss damage on a preflight, you're not doing a preflight. Do you even know what a bulkhead is? Yes. Apparently the pilot of that aircraft didn't do a preflight inspection, because you've indicated that the only way to miss damage is to not preflight the aircraft. What part of improperly repaired do you not understand? |
#56
... Mike writes: I always give each side a good heave up and down for this very reason, so such can easily be checked on the preflight for impending failure. It is unlikely that you can create the same magnitude and type of stress with "a good heave" that the aircraft would or could experience in flight. Nor is that the intention. Certainly. But that's what pre-flight and annual inspections are for. My A&P found a cracked bulkhead in the tail on my first annual after I bought the plane. It had probably been that way for years. Such problems you mentioned are common, but how many airframes do you see breaking up in flight because of it? More than necessary. How many do you think that is? The preflight is just a simple way to find out if the aircraft is airworthy to the best of the pilot's ability. I never suggested it was anything else, so you should go back and check your inference for any degree of reasonableness. You said that if a pilot doesn't find damage, he hasn't done a preflight, which implies that a preflight will find all damage. Have you changed your mind? Actually I said damage was a non-issue because of the preflight because any damage that would be an issue for the next flight is going to be found during the preflight. So why do you take a simple statement and take it to the nth degree? It is only necessary to show that the statement cannot stand, which has been done. The previous poster (who has no flight experience, btw) condemned partial ownership because another owner might "damage" the airplane and not tell anyone. It was a ridiculous statement to begin with because a proper preflight and regular inspections make such a non issue to the safety of flight. Except that this is not true. You made an absolute statement where a qualified one was required. Actually what I have done is show that your fear of "damage" by someone else is irrational and a weak point against partial ownership. So once again you've shown your "experience" is limited by what Microsoft FS can offer. If you don't want to get flamed, try working your way up the thread and figuring out what the context is before you jump on a comment and try to make it something it isn't. In the future, structure your statements more carefully, and you will not find yourself in a corner in debate. My "comment" was far more valid than yours, BTW. Your statement that, in effect, a preflight cannot fail to find damage and that a pilot who does not find damage has not done a preflight inspection was manifestly false, and does a disservice to pilots who do a thorough preflight inspection and yet die anyway as a consequence of damage that no preflight inspection can detect. Go do a search of the NTSB database sometime and see how many of those cases you can find, then tell me again about my "disservice". |
#57
... Mike writes: The chances of any such 'invisible' damage being a safety of flight issue are pretty much nil. What natural law ensures that damage related to safety is usually visible? It seems to have failed that Japanese pilot, not to mention a long list of other pilots. The damage to the JAL aircraft WAS detected. |
#58
On Jul 4, 4:56 pm, "Mike" wrote:
Obviously, you haven't seen some of the things I have seen. One of the more tender, and more invisible spots on some airframes is where the horizontal stabilizer connects to the fuze. Many designs allow a tremendous moment arm for any non-balanced load on the stabilizer to stress the attachment points. This shows up as cracked spars on Cessnas, and I have seen stressed and cracked fittings from another airframe. How can this happen? Well on Cessnas it happens from folks using improper procedures to back the plane into a parking spot. It can also happen from innocent (but ignorant) bystanders, mowers, animal activity, or any of thousands of other posibilities. I always give each side a good heave up and down for this very reason, so such can easily be checked on the preflight for impending failure. A good heave up and down on the end of the stab of a 172 flexes the center of the forward spar, eventually cracking it. A gentle bit of push-pull is all that's needed, to see if there's unusual tip travel. I bet your spar is cracked now. Many are. Cessna calls for stopdrilling the crack unless it has reached the spar flange, in which case it has to be repaired. I once flew a 172 that I subsequently found had a broken spar, busted clear through both flanges so that the skin was all that was holding it. The thing could have killed me if I gotten into turbulence or had to take violent evasive action. We run several 172s and have seen cracks, up to four of them, in a spar; we now forbid students to push down on the things. No more cracks. 172s suffer cracking at the bottom of the aft doorposts. Some models crack inside the forward doorposts. Do I need to point out that these doorposts are what the wing pulls on to lift the airplane, along with the struts? No preflight will find those. The wing spar attach lugs are known to crack at the bolt holes. In older 172s the forward elevator bellcrack bracket would break loose, reducing elevator control. In newer 172s (rod-style gear; 1973 or so and on) the landing gear retaining bolt sometimes shears and totals the airplane on landing. As the years go by, these older airplanes will become the subjects of ADs addressing age-related airframe failure, probably after a couple come apart in flight. Sooner or later. Dan |
#59
On Jul 6, 4:45*am, wrote:
On Jul 4, 4:56 pm, "Mike" wrote: *Obviously, you haven't seen some of the things I have seen. *One of the more tender, and more invisible spots on some airframes is where the horizontal stabilizer connects to the fuze. *Many designs allow a tremendous moment arm for any non-balanced load on the stabilizer to stress the attachment points. *This shows up as *cracked spars on Cessnas, and I have seen stressed and cracked fittings from another airframe. *How can this happen? *Well on Cessnas it happens from folks using improper procedures to back the plane into a parking spot. *It can also happen from innocent (but ignorant) bystanders, mowers, animal activity, or any of thousands of other posibilities. I always give each side a good heave up and down for this very reason, so such can easily be checked on the preflight for impending failure. * * * * *A good heave up and down on the end of the stab of a 172 flexes the center of the forward spar, eventually cracking it. A gentle bit of push-pull is all that's needed, to see if there's unusual tip travel. I bet your spar is cracked now. Many are. Cessna calls for stopdrilling the crack unless it has reached the spar flange, in which case it has to be repaired. I once flew a 172 that I subsequently found had a broken spar, busted clear through both flanges so that the skin was all that was holding it. Why did your push-pull test not detect it? I prefer to give a shake and feel the nature of surface response. Cheers |
#60
Dry Washing - Wing Waxers? | Spitfire | Owning | 2 | November 28th 06 01:28 AM |
Washing a fiberglass airplane | City Dweller | Owning | 5 | May 22nd 06 02:13 AM |
Depression and flying | Flyingmonk | Piloting | 44 | February 13th 06 02:28 PM |
Washing - how often? | Reid & Julie Baldwin | Owning | 15 | May 7th 05 07:15 AM |
US debt is higher now than during Depression | WalterM140 | Military Aviation | 9 | March 31st 04 05:30 PM |
