Quick guide to the F-35 JSF versions.
Old February 27th 04, 08:54 PM
Tarver Engineering
"Chad Irby" wrote in message
m...
"Tarver Engineering" wrote:
That is a common thread in Irby's posts.
It's definitely a badge of honor that "Tarver Engineering" thinks I'm so
eeeevil.
The poster was claiming you are stupid, Irby.
  #52
Old February 27th 04, 09:35 PM
Mike Marron
Chad Irby wrote:
Mike Marron wrote:
Why you keep trotting out the F-14 is beyond me.
Because, during its development, it crashed *more* often than the
"dangerous" Osprey has, per hour of flight.
And *way* more often than the "troubled" F-22.
This is a non-response. Snipping away the crux of the message
won't make it go away....
Why you keep trotting out the F-14 is beyond me. Squadrons of
fighters and fighter bombers with variable geometry wings have
been around for decades (since the 60's) long before the F-14
was even on the drawing boards. In fact, unlike tilt-rotor aircraft,
some swing-wing aircraft such as the F-111, Su-22 and Su-24 have
been operational for so long now that they've even become obsolete!
And there's also the B-1, Mig-27 and Tornado swing wings which,
unlike the Osprey tilt-rotor, have also been operational for decades.
Don't misunderstand, I wouldn't be building and flying flexwing trikes
if I were a luddite, but I haven't met too many pilots whom are all
that impressed by either the Osprey or the Harrier especially
when compared to their more conventional fixed and rotary wing
counterparts.
  #53
Old February 28th 04, 01:00 AM
Chad Irby
Actually, he was saying:
"David Lednicer" wrote in message
Chad Irby wrote:
On the other hand, when the Blackhawk was in development and early
deployment, the pilots called the the "Black Rock." Tail issues.
Not certain what you are talking about.
You see, to *normal* people, that means he didn't understand what I was
saying, or didn't get my point. This is a normal part of discussion for
most folks.
In my answer to his post, I gave the information he didn't know about.
This is also normal.
I know that these are two things you're not able to do with any
regularity, but you should understand that other people *do*.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #54
Old February 28th 04, 01:02 AM
Chad Irby
No, it's a bloody direct and obvious one.
You're complaining about a *current* machine that's having some
problems, and can't keep it in your mind that almost all *previous*
planes and copters have had similar or worse problems.
The complaint isn't about the F-14, it's that the various current
machines really aren't bad at all.
Complaining about the (actually low) accident rate of the V-22 or the
F-22 as being "bad" is just silly.
cirby at cfl.rr.com
  #55
Old February 28th 04, 01:04 AM
Tarver Engineering
m...
I am well aware of what you do, Irby.
Have you any idea how much money Lockmart has robbed the American People of
on the usenet with WAAS and the F-22?
  #56
Old February 28th 04, 01:51 AM
Tarver Engineering
m...
Tell that to the Marine's mothers.
It is not the accident rate that is problematic for the V-22, it is the kill
rate.
  #57
Old February 28th 04, 02:04 AM
Mike Marron
Bloody schmuddy. A bit long on melodramtics and short on
substance ain't cha?
You keep conveniently snipping away all the planes such as the F-111,
Su-22, Su-24, B-1, Mig-27, Tornado. Why is that?
Right. The compaint is about the V-22 and its tilt-wing predecessors.
Er um, there ya' go again changing the subject. We're talking about
the V (as in "Vee") Twenty Two Osprey NOT the F-22 Raptor (not
to be confused with the Osprey which, as a bird of prey, has been
woefully misnamed ). Not that you'd know anything about actually
flying an airplane Irby being the maintainer and prolific usenet
poster that ya' are...but like it or not there just aren't a whole
helluva lotta' pilots (civilian -OR- military) whom are all that
impressed by the Osprey. Sorry.
  #58
Old February 28th 04, 02:24 AM
Chad Irby
Maybe if you beat that dead horse some more, you might get it to do some
work...
cirby at cfl.rr.com
  #59
Old February 28th 04, 02:35 AM
Chad Irby
Because they all had their own problems, and the point was that
experimental and/or new aircraft *crash*. The F-111 was near-legendary
for development problems, for example. The B-1 had problems for
*years*.
Thanks for mentioning them, though. It builds my case.
New aircraft tend to have problems. That's how it goes.
cirby at cfl.rr.com
  #60
Old February 28th 04, 03:05 AM
Mike Marron
*years*.
One_BIG_difference between all those swing-wing aircraft
I mentioned above vis a vis your beloved tilt-rotor Osprey -- the
swing wing aircraft have been OPERATIONAL for *decades*
(you do understand how long a decade" is, no?) whereas
tilt-rotor designs such as your beloved Osprey have NOT been
operational and are still NOT operational to this day. Results
speak for themselves, Irby. But you'll only come to realize that
if you can manage to pry yourself away from your beloved
'puter and try something a bit more constructive such as learning
how to fly your own self.
Riiiight...like Jonah said when his "case" got swallowed by the
Great White One? Whether you realize it or not, Irby, you've
done LOST your "case" since, despite the fact that tilt-rotors
have been around since the early fifties...you have yet to
provide a single example of an OPERATIONAL tilt-rotor
military -OR- cvilian aircraft (V-22 or otherwise) in use
*anywhere.*
Wanted: copy of Flying Buyers' Guide 1983 or older Ren? Aviation Marketplace 1 January 14th 05 06:06 AM
FS: 1996 "Aircraft Of The World: A Complete Guide" Binder Sheet Singles J.R. Sinclair Aviation Marketplace 0 July 14th 04 07:34 AM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
FA: Congested Airspace: A Pilot's Guide The Ink Company Aviation Marketplace 0 August 10th 03 05:51 PM
FA: Used Aircraft Guide The Ink Company Aviation Marketplace 0 July 15th 03 03:17 AM
