#51
I don't know if anybody has used tapered pultruded rods in a spar as well but it may be a possibility given the complex rods and tube shape being manufactured for other applications. Rectangular profiles are made, the smaller the cross section of the Pulltrusion the better you are able to match the bending moment. Naturally it is more effort to built with smaller sections but it provides for a near optimum spar. Udo |
#52
On Jan 6, 8:30*pm, Udo Rumpf wrote:
Yes. Due to the alignment of the fibres and the higher tensile strength of the resin, plus the high cure temperature. Hand lay-up and vacuum bagging can only achieve a fraction of the potential strength of the carbon fibre. Unidirectional preprec have some of the same benefits but not to the same extent as pultrusions. To expound on what Udo writes: Pultruded carbon fiber strips (or rods or ribbons or whatever profile) are a neat way to make spar caps for wing spars because they have great properties and don't require heroics in terms of fiber alignment, lamination conditions, and climate control. Their application to sailplane design was Pioneered (pun intended) by Jim Marske who tested and developed a variety of ways to design and work with them. Jim further did tests on a variety of hand-laminated unidirectional carbon fiber test coupons and found that it is very difficult, and sometimes impossible, to achieve handbook properties without extreme control of fiber alignment and curing conditions. Offhand, I think that pultruded strips offer max tensiles of around 300 ksi and (this is the important part) max compressive of around 275 ksi. That's around five times what you get in compression strength from hand-laminated uni carbon. Their Young's modulus is somewhere around 20 million. The biggest arguement against pultrusions (and this might be the most compelling thing for Greg), is that while they offer great strength, their stiffness (as in Youngs modulus) has only a 10% to 15% improvement over hand-laid uni. Since a lot of sailplane design considerations are bound by stiffness more than by strength, the extra strength of pultruded carbon doesn't have all that much effect on the finished product. I suspect that since Greg has good access to high-tech prepreg materials, and more importantly to the expensive autoclaving equipment and energy it takes to press and cook it, Pultrusions don't hold as much advantage in his shop as they do in my more lowbrow and low- dollar operation. Thanks, and best regards to all Bob K. www.hpaircraft.com/hp-24 |
#53
On Jan 7, 1:40*pm, Bob Kuykendall wrote:
On Jan 6, 8:30*pm, Udo Rumpf wrote: Yes. Due to the alignment of the fibres and the higher tensile strength of the resin, plus the high cure temperature. Hand lay-up and vacuum bagging can only achieve a fraction of the potential strength of the carbon fibre. Unidirectional preprec have some of the same benefits but not to the same extent as pultrusions. To expound on what Udo writes: Pultruded carbon fiber strips (or rods or ribbons or whatever profile) are a neat way to make spar caps for wing spars because they have great properties and don't require heroics in terms of fiber alignment, lamination conditions, and climate control. Their application to sailplane design was Pioneered (pun intended) by Jim Marske who tested and developed a variety of ways to design and work with them. Jim further did tests on a variety of hand-laminated unidirectional carbon fiber test coupons and found that it is very difficult, and sometimes impossible, to achieve handbook properties without extreme control of fiber alignment and curing conditions. Offhand, I think that pultruded strips offer max tensiles of around 300 ksi and (this is the important part) max compressive of around 275 ksi. That's around five times what you get in compression strength from hand-laminated uni carbon. Their Young's modulus is somewhere around 20 million. The biggest arguement against pultrusions (and this might be the most compelling thing for Greg), is that while they offer great strength, their stiffness (as in Youngs modulus) has only a 10% to 15% improvement over hand-laid uni. Since a lot of sailplane design considerations are bound by stiffness more than by strength, the extra strength of pultruded carbon doesn't have all that much effect on the finished product. I suspect that since Greg has good access to high-tech prepreg materials, and more importantly to the expensive autoclaving equipment and energy it takes to press and cook it, Pultrusions don't hold as much advantage in his shop as they do in my more lowbrow and low- dollar operation. Thanks, and best regards to all Bob K.www.hpaircraft.com/hp-24 Another consideration is transferring the shear loads out of the caps at the root. With prepreg or wet-layup, you can wrap the caps part way around the end of the spar to help with this; not so with pultrusions. I don't know how important this is... Wet lay-ups in a glider factory environment are not too hard (not at all trivial, but control of wetting and fiber-straightness are understood). Perhaps not to "handbook values" (nor designed to) ;-) See ya, Dave "YO electric" |
#54
On Jan 7, 1:01*pm, DRN wrote:
Another consideration is transferring the shear loads out of the caps at the root. With prepreg or wet-layup, you can wrap the caps part way around the end of the spar to help with this; not so with pultrusions. I don't know how important this is... The spars that Jim Marske has helped develop for the Genesis and LAK ships, and the static tests that they survived, seem to demonstrate that this is not a critical issue. ...control of wetting and fiber-straightness are understood... 1. O {Press Button} 2. ~~~ {Receive Ondulation} Thanks, Bob K. |
#55
On Jan 7, 2:11*pm, Bob Kuykendall wrote:
On Jan 7, 1:01*pm, DRN wrote: Another consideration is transferring the shear loads out of the caps at the root. With prepreg or wet-layup, you can wrap the caps part way around the end of the spar to help with this; not so with pultrusions. I don't know how important this is... The spars that Jim Marske has helped develop for the Genesis and LAK ships, and the static tests that they survived, seem to demonstrate that this is not a critical issue. ...control of wetting and fiber-straightness are understood... 1. O * *{Press Button} 2. ~~~ *{Receive Ondulation} Thanks, Bob K. .... o /|\ 5. _/ \_ {walk on it} :-) Darryl |
#56
The name is taken for a metal trainer made by a glider manufacturer in
Florida(?) I never heard of a pulltrusion and can only guess what it means; I'm a poltroon, my self. At 05:46 07 January 2009, Darryl Ramm wrote: On Jan 6, 9:16=A0pm, Greg Arnold wrote: Udo Rumpf wrote: Are pultrusions lighter than something made with vacuum =A0 bagged pre-pregs? =A0If so, why are they lighter? Yes. Due to the alignment of the fibres and the higher tensile strength= of the resin, plus the high cure temperature. Hand lay-up and vacuum bagging can only achieve a fraction of the potential strength of the carbon fibre. Unidirectional preprec have some of the same benefits but not to the sa= me extent as pultrusions. Udo Does a pultrusion work with a spar that is tapered as you get further from the fuselage? Yes, usually just like spar caps on conventional I beam spars also allow tapered wings (was this a trick question?). See http://continuo.com/marske/ARTICLES/...ods/carbon.htm --- I'll suggest a marketing program to Greg Cole... let the first handful of position holders rename the Duck Hawk. Peregrine (i.e. what a Duck Hawk is) works for me. Ooops I'm not a position holder. Darryl |
#57
On Jan 7, 2:30*pm, Nyal Williams wrote:
The name is taken for a metal trainer made by a glider manufacturer in Florida(?) I never heard of a pulltrusion and can only guess what it means; I'm a poltroon, my self. Opposite of an extrusion - which had already been named or it would have been called a push-trusion I suppose. Calling the opposite of an extrusion an intrusion didn't work either so there you go... 9B |
#58
#59
On Jan 6, 9:16*pm, Greg Arnold wrote:
Does a pultrusion work with a spar that is tapered as you get further from the fuselage? [Warning: I am not an engineer. The following is not engineering advice. Read and apply at your own risk. Via con Dios, Amigo!] You have to make them work. Designing economically with pultrusions is all about using commercially-available profiles. You can order entire custom mondo bars or strips or even angles or T-sections if you want, but the cost per unit strength and stiffness is through the roof. Economically, it makes better sense to select smaller strips or rods that have wide application in consumer goods, and take a free ride on their economies of scale. Basically, you assble the spar as a box, I-beam, or C-section using relatively conventional composite construction techniques, and use a matrix (columns and rows) of pultruded elements in the spar caps to collect the tensile and compressive loads. LAK has used 1/8" dia pultruded rods in the past, as did the Genesis. I think LAK's recent designs might tend towards the use of rectangular-section strips as do mine. You taper the spar in depth to match the wing depth by making the shear web in the shape of one or more elongated trapezoids. You taper the spar caps in cross-section to match the sectional moment of inertia to the local bending moment by ending the pultruded elements (or entire columns or rows of elements) at various spanwise stations. So out by the tip there might be only an eighth or a tenth of what you have at the side-of-body where the bending moment is at its maximum. As Dave Nadler suggests, transferring loads between the upper and lower spar caps in the spar stub, and transferring the moment from one spar butt to the other through the main pins, is not trivial. However, what I've seen of crashed and otherwise torn apart European racers suggests that if you're methodical and consistent you can approach it relatively casually and still have plenty of margin. The tooling required to make spars using pultrusions can be as substantial or as hokey as your workshop environment lets you get away with. I've seen it done successfully with a pair of sharpie lines drawn on a long level Formica tabletop. Using strips of wood on the tabletop to guide the spar cap matrix alignment has also worked well. Thanks, Bob K. |
| Thread Tools | |
| Display Modes | |
| High Altitude Waypoints | Dennis Johnson | Instrument Flight Rules | 7 | May 2nd 08 03:44 AM |
| High Altitude Bombing? | Larry Dighera | Piloting | 0 | February 6th 07 04:47 PM |
| High Altitude Linnies | TTaylor at cc.usu.edu | Soaring | 4 | August 4th 06 11:47 PM |
| High altitude & RPM | abripl | Home Built | 1 | September 1st 05 01:12 AM |
| High-altitude autorotations? | Bill McClain | Military Aviation | 17 | March 15th 04 05:23 PM |
