#51
![]() "Anthony W" wrote The 3.5 and 4" belt setups are running about $1500 and probably not worth it for what we're talking about. These belts are for engines that run over 100 BHP peak and the riders of these bikes can be very abusive when doing burnouts and drag racing. Humm, I saw some brand new 3" with 2 pulleys and belt for less than 500 bucks, but they were set up for installing the one pulley on a clutch, so an adapter would probably have to be made for that one. If they are available on Ebay for less, that would be what I would consider reasonable. 500 bucks isn't too far out of reach for most non 3rd world country resident, either. -- Jim in NC |
#52
I'm running a bit behind on this thread; here are thoughts about a
couple of questions. Someone mentioned that the industrial engines are a bit heavy. True to a degree, but if you're designing a plane around the engine (as God intended) the extra weight is only a minor penalty. Early VW powered designs had to make do with not much more than 40 hp, & the VW weighed over 150 lbs. Hundreds of 'Piets' are flying with 35-40 hp Model A engines that weigh way more than 300 lbs, IIRC. The plane was designed for the engine. Hanging one on a plane designed for a Rotax won't be too successful, though. :-) Someone else mentioned using a heavier cam drive train as the prop reduction drive. It's been done on certified engines. The problem I've heard about is that it increases the likelihood of torsional resonance (supposedly the reason that reduction ratios are almost always some weird number). Charlie |
#53
On May 25, 5:40*pm, Charlie wrote:
Someone mentioned that the industrial engines are a bit heavy. True to a degree, but if you're designing a plane around the engine (as God intended) the extra weight is only a minor penalty. ------------------------------------------------------------------------------------------ Dear Charlie, Seeking information about TATA's engine line-up, with special interest toward the most popular and having the longest years of service, I was told it was a 1403cc I-4 SOHC in both Otto Cycle & Diesel (!!), offered as an industrial engine, for cars, trucks and even marine applications. I guess they do things differently in India because 1403cc is about 85cid -- even the stock 1600cc VW would look like a stump-puller. But the weight is said to be 'about' 300 lbs (!!!) Which may explain the ability to use the basic block for a Diesel as well as a SOHC gas engine. Any way you slice it, the weight is a tad much. ------------------------------------------------------------------------------------ Early VW powered designs had to make do with not much more than 40 hp... ----------------------------------------------------------------------------------- Late ones, too :-) The VW is thermally limited by its heads, which were designed for the 40hp 1300cc engine. You can increase it's displacement.. . and you may CLAIM any horsepower you wish.... but you maximum SUSTAINED output is going to fall in the 40 to 50 hp range, depending on the local atmosphere. Demand any more and your MTBO takes a major header into the porcelain fixture. (Engines can't lie. Go by their fuel consumption figures. The SFO (specific fuel consumption) of all air- cooled engines is clustered around the 0.5lb/hp mark (Standard Day assumed, etc.) ) -R.S.Hoover |
#54
Veeduber wrote:
On May 25, 5:40 pm, Charlie wrote: Someone mentioned that the industrial engines are a bit heavy. True to a degree, but if you're designing a plane around the engine (as God intended) the extra weight is only a minor penalty. ------------------------------------------------------------------------------------------ Dear Charlie, Seeking information about TATA's engine line-up, with special interest toward the most popular and having the longest years of service, I was told it was a 1403cc I-4 SOHC in both Otto Cycle & Diesel (!!), offered as an industrial engine, for cars, trucks and even marine applications. I guess they do things differently in India because 1403cc is about 85cid -- even the stock 1600cc VW would look like a stump-puller. But the weight is said to be 'about' 300 lbs (!!!) Which may explain the ability to use the basic block for a Diesel as well as a SOHC gas engine. Any way you slice it, the weight is a tad much. ------------------------------------------------------------------------------------ Early VW powered designs had to make do with not much more than 40 hp... ----------------------------------------------------------------------------------- Late ones, too :-) The VW is thermally limited by its heads, which were designed for the 40hp 1300cc engine. You can increase it's displacement.. . and you may CLAIM any horsepower you wish.... but you maximum SUSTAINED output is going to fall in the 40 to 50 hp range, depending on the local atmosphere. Demand any more and your MTBO takes a major header into the porcelain fixture. (Engines can't lie. Go by their fuel consumption figures. The SFO (specific fuel consumption) of all air- cooled engines is clustered around the 0.5lb/hp mark (Standard Day assumed, etc.) ) -R.S.Hoover Hi Bob, Sorry for the confusion; the industrial engines I was referring to are the new ones typically used for generators, like the one Valley Engineering uses. http://www.culverprops.com/big-twin.php 120 lbs *including a reduction drive and a large diameter prop* for lots of low speed thrust. I think the direct drive version is under 100 lbs when stripped for aviation. Their web site is a bit tricky to navigate, but there's a lot of info on how they did the mods if you dig for it. The stock engine (unmodified for aviation) is available for around $3,000, new in box. Their 'Backyard Flyer' (a couple of different versions on the web site) using this engine looks a lot like what I would have designed, if I had the chops. They claim that it's UL-legal, using this 'heavy' engine. http://www.culverprops.com/back-yard-flyer.php http://www.culverprops.com/back-yard-ul.php Oh yeah, someone mentioned motorcycle chain drives. Several years ago there was a 2 seat pusher UL-like plane based in south Mississippi flying with (IIRC) a Honda CBR600 shaft drive engine. It was mounted low in the airframe with a racing chain up to a high-mounted prop shaft in pillow block bearings. The owner said that he flew in 2nd or 3rd (I forget which) when solo & downshifted one gear when carrying a passenger. Apparently it was reliable, because he flew it on cross countries. I ran the idea past a friend who has raced bikes for most of his life. He said that it'll work fine if most of the rpm reduction happens before the chain, but 6K rpm (2 stroke rpms) into the chain would cause serious issues with the chain trying to turn into a solid rod entering & leaving the sprocket. FWIW, Charlie |
#55
![]() "Veeduber" wrote in message ... ------------------------------------------------------------------------------------ Early VW powered designs had to make do with not much more than 40 hp... ----------------------------------------------------------------------------------- Late ones, too :-) The VW is thermally limited by its heads, which were designed for the 40hp 1300cc engine. You can increase it's displacement.. . and you may CLAIM any horsepower you wish.... but you maximum SUSTAINED output is going to fall in the 40 to 50 hp range, depending on the local atmosphere. Demand any more and your MTBO takes a major header into the porcelain fixture. (Engines can't lie. Go by their fuel consumption figures. The SFO (specific fuel consumption) of all air- cooled engines is clustered around the 0.5lb/hp mark (Standard Day assumed, etc.) ) -R.S.Hoover Most of the early VW powered designs, of which I was aware, were designed and built to work well with a claimed 25 HP. As I recall it, for example, the Jodel D9 had a wingspan of roughly 23 feet and was supposed to depart over a 50 foot obstacle in little more than 450 feet and cruise at around 65 mph (about 57 kts) carrying a modest amount of fuel and a 160 pound pilot. I admit to being about 10 percent heavier than that; but the basic concept was valid. Unfortunately, it weighed a little over 300 poinds and the speeds were just a little above the subsequent Part 103 limits, so interest in that class of aircraft has been low--even though the stated utility and fuel efficiency remain better than any of the popular ultralights of which I am aware. My recollection is that around 1.5 gph was claimed. Clearly, a 50 HP engine should be able to power a 2 seated of similar performance, with a gross weight around 1000 pounds. That's as fast as some of the older "certified" aircraft like the early Cub and the "bathtub" Aeronca--and it's nearly impossible to maintain 100 percent power for more than a minute or so with a fixed pitch propeller--so 40 to 50 sustained horsepower is not necessarily a deterrant for that class of aircraft. Peter |
#56
This website does a bang-up job of running through the options of
various reduction types, and comes down firmly on the side of spur gears with hydrodynamic bearings: http://www.epi-eng.com/propeller_red...y_contents.htm This Polish outfit produces spur gear reductions for various relatively low power engines: http://www.aerotech-poland.com/index.php?go=5 I wrote and asked how much: Hi, a typical price for gear rd is 1180 EUR + shipping cost. This price is changing due to currency rates. Regards Wlodzimierz Krukowski They seem to be engine oil lubricated. |
#57
"flybynightkarmarepair" wrote in message
... This website does a bang-up job of running through the options of various reduction types, and comes down firmly on the side of spur gears with hydrodynamic bearings: http://www.epi-eng.com/propeller_red...y_contents.htm This Polish outfit produces spur gear reductions for various relatively low power engines: http://www.aerotech-poland.com/index.php?go=5 I wrote and asked how much: Hi, a typical price for gear rd is 1180 EUR + shipping cost. This price is changing due to currency rates. Regards Wlodzimierz Krukowski They seem to be engine oil lubricated. Spur geared engines are not generally well thought of by the mechanics with whom I have talked. Unless there is a clutch located between the engine crankshaft and the input shaft of the PSRU, as would normally be the case in an automobile with a manual transmission, the driving gear will always have the same orientation with respect to the power pulses of a reciprocating engine. The resulting uneven wear will ultimately define the replacement interval of the gear(s). The use of gear ratios that randomize the tooth contact between the driving and driven gear, or the choice of an engine with a greater number of cylinders, will serve to mitigate the problem; but a planetary or epicyclic PSRU will remain the preferred solution whenever there is no randomizing feature between the crankshaft and the input gear. Supposedly, cogged belts are imune to the problems; but I suspect it is simply that the wear rate on the cogged pullies is simply low enough to make the problem appear trivial. Personally, just to be on the safe side, I would choose the ratios of both sprockets and the belt to randomize the contact on a cogged belt drive as well and I would do the same with chain! Peter |
#58
flybynightkarmarepair wrote:
This website does a bang-up job of running through the options of various reduction types, and comes down firmly on the side of spur gears with hydrodynamic bearings: http://www.epi-eng.com/propeller_red...y_contents.htm I notice this site puts a deal of effort into slagging off a competitor's sprag clutch use. Without regard to the merits, this is a warning to me.... Brian W |
#59
On May 28, 10:16*am, Brian Whatcott wrote:
flybynightkarmarepair wrote: This website does a bang-up job of running through the options of various reduction types, and comes down firmly on the side of spur gears with hydrodynamic bearings: http://www.epi-eng.com/propeller_red...earbox_technol... I notice this site puts a deal of effort into slagging off a competitor's sprag clutch use. * *Without regard to the merits, this is a warning to me.... Brian W I hear where your're coming from, and respect that point of view. However, that competitor no longer exists. The successor company that absorbed what was left designed a NEW PSRU from scratch - single reduction, helical gears, but NOT planetary. No sprag clutch, and a torsionally soft resilient element between the engine and the gears: http://www.maxwellpropulsion.com/sportsman/psru.html Other than the Helical/Spur gear issue, pretty much like EPI engineering suggests. OTOH, Real World Solutions has a Ford based planetary out there racking up hours. BOTH the RWS and Maxwell Propulsion units are too big and heavy for the low horsepower applications Veeduber was initially talking about. The Polish Aerotech unit is the only gear reduction I'm aware of suitable for smaller engines. |
#60
Hello All:
I'm not sure if it was this thread or another similar one, but someone suggested reverse engineering a Pobjoy engine - if one could be found. Read the last post in the following thread for a link to one that is on display in a museum (at South County Airport in Northern CA): http://www.warbirdinformationexchang...ic.php?p=20143 Dave |
A Camcorder for Homebuilders | [email protected] | Home Built | 3 | June 1st 08 03:27 PM |
Mexico City - Homebuilders ... | ......... :-\)\) | Home Built | 2 | February 7th 05 12:04 PM |
Is this the place for Homebuilders? | Gilan | Home Built | 2 | September 23rd 04 02:06 PM |
NPR Segment on Elderly Homebuilders | Jay Honeck | Piloting | 0 | May 29th 04 11:32 PM |
Best Homebuilders Books? | [email protected] | Home Built | 5 | January 21st 04 01:06 AM |
