NTSB Report on Bill Phillips' Accident
Old September 28th 09, 03:21 PM posted to rec.aviation.homebuilt
Default NTSB Report on Bill Phillips' Accident
Sailplanes are adopting forward hinged canopies as a safety feature.
Any canopy opening system can open inadvertently if not properly
latched but the forward hinge system will open less violently than
other systems.
Regardless of the hinge system, an open canopy is not likely to render
an aircraft unflyable. The first priority is to FLY THE AIRCRAFT and
deal with the canopy on the ground after a safe landing.
Long experience has shown that the biggest hazard of an open canopy in
flight is the pilot trying to close the canopy and not flying the
aircraft while he's doing it. There's a history of glider accidents
with this scenario. Glider pilots are taught to assume an open canopy
is trashed, put it out of their mind and fly the glider as an open
cockpit aircraft.
Bill is correct. The biggest hazard of an unlatch/open canopy is trying to close it. I can make this statement as a "voice of experience."
http://www.soaridaho.com/Schreder/HP-16/nocan.htm
I only had about 30 hours in glider when this incident occurred. If I my glider had a forward hinged canopy the result of an unlatched canopy would have been a bit of noise caused by the canopy not being properly sealed.
One of these days I am going to have to replace the canopy on my current homebuilt sailplane. When the time arrives a I will install forward hinged canopy.
http://tinyurl.com/N990-6F
  #62
Old September 28th 09, 03:56 PM posted to rec.aviation.homebuilt
vaughn[_2_]
"Wayne Paul" wrote in message
news
To add to Wayne's excellent post, the following canopy-caused accident
always sticks in my mind. It caused fatal injuries to a paying passenger,
severe injuries to the Commercial pilot, & less severe injusies to the tow
pilot. There happened to be an FAA inspector watching the accident happen,
so the witness description is probably better than most.
"A Federal Aviation Administration (FAA) Aviation Safety Inspector witnessed
the accident. In a
written statement the Inspector said:
"My attention was drawn to the glider by its erratic pitch changes. As I
concentrated on the
glider I saw that the rear canopy had opened and the person in the rear seat
extended an arm toward
the open canopy. At the same time, the glider pitched up rather steeply and
the arm returned
inside the glider. With the canopy still open, the glider reduced its pitch
but remained on high
tow. This effort to close the canopy occurred at least three times with the
glider going higher
and higher. Toward the end of the runway, the tow plane began to descend
then pitch up once or
twice then descend and impact the ground. As the tow plane impacted the
ground, the glider, which
was much higher and still on the tow rope, continued forward and climbing
and the tow rope became
almost vertical...[which] separated from the glider and fell in a pile by
the tow plane. The
glider continued...beyond the tow plane...rolled left to the inverted
position...and impacted the
ground..."
http://www.ntsb.gov/ntsb/GenPDF.asp?...9FA004B&rpt=fa
Like I said, this one sticks in my mind, but if you search the NTSB database
you will find too many more.
Vaughn
  #63
Old September 29th 09, 05:20 AM posted to rec.aviation.homebuilt
bildan
On Sep 28, 8:56*am, "vaughn"
news
Bill is correct. *The biggest hazard of an unlatch/open canopy is trying to
close it. *I can make this statement as a "voice of experience."
always sticks in my mind. *It caused fatal injuries to a paying passenger,
pilot. *There happened to be an FAA inspector watching the accident happen,
the accident. In a
concentrated on the
the arm returned
glider going higher
the tow plane. The
ground..."
Vaughn
I should have added that when letting a student open a canopy in
flight, it is done at low airspeed and in a glider whose canopy is
known to be easily opened and closed in flight. There are many
expensive two-east gliders with canopies costing thousands of dollars
that I would never let a student risk.
On at least one occasion a student of mine who had experienced a
deliberate canopy opening with me later suffered an inadvertent
opening and handled it well. He told me the story years after his
training.
Bill Daniels
  #64
Old September 29th 09, 12:02 PM posted to rec.aviation.homebuilt
Barnyard BOb
On Wed, 23 Sep 2009 20:13:04 -0700, Ron Wanttaja
I wouldn't risk a passenger's life. There's a lot of peace of mind, in
flying a single-seat airplane....
And all these years I thought it was Chuck Sluzarczyk's MUZZLELOADER.
Thanks for clearing this up, Ron. ;+)
Barnyard BOb - Flybaby & RV3 driver
Badwater Bill - Janice Phillips contact BobR Home Built 1 October 24th 08 02:46 PM
NTSB report - ILS and ATC. How does it all come together? Montblack Piloting 1 June 19th 06 11:26 PM
NTSB report - ILS and ATC. How does it all come together? Montblack Instrument Flight Rules 1 June 19th 06 11:26 PM
Preliminary NTSB report on Walton accident ChuckSlusarczyk Home Built 11 July 12th 05 04:23 PM
Prelim NTSB report, Pilatus accident in PA vincent p. norris Piloting 15 April 11th 05 02:52 PM
