If all midair collisions were eliminated...
Old February 12th 10, 02:23 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Dan[_12_]
Default If all midair collisions were eliminated...
Wayne Paul wrote:
"Mxsmanic" wrote in message ...
writes:
... Snip ...
One advantage of simulation is that you can afford better avionics. However,
only one of my small aircraft (the Baron) is equipped with TCAS, and the very
same instrument (a Sandel ST3400) is available to anyone with a small aircraft
who is prepared to pay for it (about $35,000 for the real-world version, and
1000 times cheaper for the sim version).
... Snip ...
"... available to anyone with a small aircraft ..."?????
I don't have the budget to put one in my aircraft; however, if I did ..... How big would the battery have to be to power a TCAS on a 6+ hour cross country flight in an aircraft without an electrical system? The follow on question is ... What use is simulation if the simulator avionics aren't in the aircraft you fly?
HP-14 "6F"
http://tinyurl.com/N990-6F
Trying to hold a logical conversation with mxmanic is futile. If you
want a giggle ask him to fly one of his simulations then try the real
thing. I assume no one would risk a real airplane on him so a real
simulator would suffice. Throw a few emergencies or weather problems at
him and watch what happens.
Dan, U.S. Air Force, retired
  #64
Old February 12th 10, 04:07 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Mxsmanic
Wayne Paul writes:
electrical system?
I don't think battery operation is an option. Besides, the instrument has to
be connected to other devices that also require electricity, such as GPS
units, VOR receivers, etc., not to mention TCAS hardware itself.
It depends on the purpose of the simulation. Some pilots do indeed simulate
the exact aircraft that they fly in the real world. But simmers who do not fly
are free to choose the aircraft of their choice, and in my case, I have
several dozen aircraft to choose from. The Baron has TCAS, and it could also
accommodate TCAS in real life, so it's not unrealistic. The Cessna 152 doesn't
have much of anything. So I may be generous with the avionics on a few of the
aircraft, but it's not unrealistic. An instrument costing $35,000 isn't much
on an aircraft that costs well over $1 million new.
  #65
Old February 12th 10, 04:25 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
"Mxsmanic" wrote in message news
Wayne Paul writes:
electrical system?
In my real life experiences the simulators were exact replicas of the aircraft cockpit. Its' purpose was to provide a platform for developing emergency procedures, crew coordination, thus enhancing flight safety. If "simmers' don't fly then a simulator is nothing more then an aviation related toy with which they can play with while pretending to be pilots.
Respectfully,
HP-14 "6F"
P.S. You use the term "aircraft" which in the U.S.A has a broader definition then the term "airplane."
  #66
Old February 12th 10, 04:34 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Mxsmanic
Wayne Paul writes:
An exact replica would include pressure changes from altitude changes or
pressurization, and I rather doubt that the simulators you used had that
feature.
The point being, of course, that different simulators serve different
purposes. Each simulator is adapted to simulate whatever is relevant to its
purpose.
Some full-motion simulators have visuals that are worse than Microsoft Flight
Simulator, simply because visuals are not relevant to their purpose (which
often emphasizes instrument flight or procedures, not pilotage).
Then presumably it simulated aspects of the real aircraft relevant to these
purposes. How well did it simulate magnetic compass anomalies?
You're entitled to your opinion.
Yes, I know, thank you.
  #67
Old February 12th 10, 05:16 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Frank Whiteley
On Feb 12, 9:34*am, Mxsmanic wrote:
Wayne Paul writes:
feature.
purpose.
related toy with which they can play with while pretending to be pilots.. *
P.S. *You use the term "aircraft" which in the U.S.A has a broader
I've flown the United 777 and DC-10 simulators in varietal weather and
emergencies. For the PC, I prefer Condor Soaring.
  #68
Old February 12th 10, 05:26 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
This is my last post on the subject.
I believe you grossly underestimate the capabilities of good cockpit simulators. Even the air combat, carrier landing, etc simulators of the 1970s far surpass the capabilities of a PC based system.
If you had flight experience the view from the cockpit flying one-on-one or two-on-one with pilots in adjoining simulators could even convince you that you were experiencing high Gs. Without flight experience the G suite inflations merely caused discomfort.
The same was true with a night carrier landing simulator. As the simulated weather deteriorated and the fuel state became critical your heart beat would increase, palms would sweat, etc. A non-pilot didn't relate the flight conditions with death; therefore, did not experience the same physiological symptoms; therefore, gaining little form the training other then a bit of hand/eye coordination. In fact in many cases it actually caused complacency instead of developing skill under stress.
This is why I consider a non-pilot in a simulator simply playing a game with only minor aviation training relevance.
Respectfully,
Wayne, USN Retired.
Wayne Paul writes:
feature.
purpose.
  #69
Old February 12th 10, 05:28 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Peter Dohm
"Dan" wrote in message
writes:
... Snip ...
However,
very
aircraft
and
... Snip ...
"... available to anyone with a small aircraft ..."????? I don't have the
aircraft you fly?
HP-14 "6F"
Just the thought made my day!
Peter
  #70
Old February 12th 10, 05:36 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Frank Whiteley" wrote in message ...
Frank,
We are in agreement on this one for sure!!!
Mid Air Collisions Sukumar Kirloskar Soaring 2 July 3rd 08 02:42 PM
FAA Soaring Forecasts being eliminated? David Neptune Soaring 6 July 15th 06 05:47 AM
Kids and Aviation records. I thought these were supposed to be eliminated. Roger Halstead Piloting 2 September 27th 04 07:20 PM
Mid-Air Collisions JJ Sinclair Soaring 26 April 19th 04 08:52 AM
MID AIR COLLISIONS Vorsanger1 Soaring 2 April 16th 04 04:17 AM
