Substandard Italian workmanship renders first 787s unsafe
Old June 28th 10, 12:33 PM posted to rec.aviation.piloting,rec.travel.air
Ken S. Tucker
Default Substandard Italian workmanship renders first 787s unsafe
On Jun 25, 2:10 pm, Mxsmanic wrote:
Boeing has discovered that the Italian firm to which it subcontracted
construction of tail assemblies isn't doing the work correctly, putting the 23
aircraft it has already built at risk:
http://travel.usatoday.com/flights/p...halts-787-test...
No surprise here. When you allow Third World companies to built vital parts to
your airplane, you should take for granted that there will be potentially
dangerous defects. That's the consequence of trying to be politically correct.
Wops tell me, "never trust a wop", it's good advice, but can
it be trusted?
Ken
  #62
Old June 28th 10, 04:54 PM posted to rec.aviation.piloting
On Jun 28, 5:35*am, Mxsmanic wrote:
There isn't any way to test software systems for correctness.
How is MSFS tested for correctness????????????????
  #64
Old June 28th 10, 06:25 PM posted to rec.aviation.piloting
VOR-DME[_3_]
says...
Everything you are describing is analog. In digital systems that use binary
numbers (the majority of electronic systems), everything is either one or
zero. There is no half-one/half-zero. There are no intermediate values. That
is the nature of digital systems.
However, all real-world, physical systems that represent information
digitally
do so using an analog infrastructure. In the analog realm, intermediate
values
are possible; in the digital realm, they are not.
For example, the written word is a digital representation of information.
There are no "half W's" or "partial A's"; either a symbol is one letter, or
it's another. But the written word is typically actually stored on analog
physical devices, such as books or disk drives. These analog representations
must be resolved unambiguously to discrete values upon entering the digital
realm. The print on a page may be blurry, but in order to read it, each
letter
on the page must be unambiguously identified--there are no partial or
intermediate letters.
You would do well to stop spewing elementary school nonsense and go back to
that textbook (or Newsweek article or whatever your course of study was) and
learn the difference between a bit and a byte. When you have grasped that, you
will understand why everything you have just said is pure nonsense.
I've been studying the safety of aviation computer systems for several
decades.
Some people are slow learners.
  #65
Old June 30th 10, 06:37 PM posted to rec.aviation.piloting
Tom P[_3_]
In rec.aviation.piloting Mxsmanic wrote:
Tom P writes:
Factory workers make mistakes all the time. It's normal.
The number and magnitude of mistakes they make depend a great deal on
corporate and social culture.
I recall Akio Morita describing such a problem. Sony was building Trinitrons
in both Japan and the USA. In both countries, the tubes had to meet the same
tolerances. Nevertheless, the company found that the Japanese tubes were
always far closer to perfection than the USA tubes.
Finally, management figure it out. The Japanese always tried to get things
perfect, no matter what the accepted tolerances were, whereas the Americans
didn't care whether it was perfect or not, as long as it fell within the
tolerances.
To fix this, Sony made the tolerances far tighter for the USA tubes. Their
quality then improved significantly.
All of which was stupidity on Sony's part.
All things have a tolerance and tighter tolerances increase costs.
If Sony needed tighter tolerance they should have originally specified
tighter tolerances instead of ****ing and moaning that stuff made to
their specified tolerance wasn't "good enough".
It was all about culture.
Wrong, it is all about getting the specifications to be what is really
needed in the first place.
That is basic engineering.
We have a realworld problem with a part right now. It's a tube with an
internal dimension of 58mm with a specified tolerance of +0.3mm - note
not -/+0.3mm.
Parts are being rejected on arrival at the customer as being under
58mm. The problem is that the manufacturer is passing parts measured
right down to 58mm, so with the minute difference between the mfgr's and
the customer's test pieces, the only solution is for the mfgr not to
ship anything under 58.1mm.
  #66
Old July 1st 10, 10:54 PM posted to rec.aviation.piloting
Mxsmanic wrote:
VOR-DME writes:
I said you were out of your depth, now you are sinking fast. I gave you that
something like a slew rate is an analog performance parameter, but to claim
there are no meaningful tolerances for digital systems is screaming nonsense.
No half-written byte? Of course there are. All the time. There are incorrect
words. Checksum errors. Bytes that arrive too late. A 30cm trace on a printed
circuit board translates to a nanosecond of transit time, and at GB speeds
this is meaningful.
It all went right over the top of you head, didn't it?
Your knowledge of things digital is just as superficial as everything else
you claim to know about.
Jim Pennino
Remove .spam.sux to reply.
  #67
Old July 2nd 10, 02:59 AM posted to rec.aviation.piloting
Peter Dohm
news
Mxsmanic wrote:
VOR-DME writes:
that
claim
nonsense.
incorrect
printed
speeds
this is meaningful.
binary
That
Jim Pennino
It really is hopeless, Jim,
If you were interviewing job applicants, too many like him could drive you
to drink.
Peter
  #69
Old July 2nd 10, 01:44 PM posted to rec.aviation.piloting
a[_3_]
On Jul 1, 9:59*pm, "Peter Dohm" wrote:
news
Mxsmanic wrote:
VOR-DME writes:
that
claim
nonsense.
incorrect
words. Checksum errors. *Bytes that arrive too late. A 30cm trace on a
printed
speeds
this is meaningful.
binary
zero. There is no half-one/half-zero. There are no intermediate values..
That
Jim Pennino
to drink.
Peter
Back in the last century when I did design, much of it digital, there
were many times the electrons refused to read my schematics. But
interviewing was not that difficult, many were VERY short because
there was no reason to talk further to someone who was as simplistic
as at least one of the posters here. My comment frequently was, "You
know, I don't think there's a good fit here. Why don't we finish our
coffee and talk about" -- insert here whatever we found as an area of
mutual interest.
"Aircraft Unsafe, Do Not Fly" T8 Soaring 2 April 13th 10 08:24 PM
Relief Tube Housing - Unsafe Tim Taylor Soaring 12 June 18th 09 09:30 PM
renders [email protected] Restoration 0 April 25th 04 03:35 AM
Your Italian Consultant, your italian business opportunity Techenquire.com Products 2 January 12th 04 08:08 AM
Your Italian Consultant, your italian business opportunity Techenquire.com Aviation Marketplace 0 January 5th 04 02:10 PM
