#61
alexy wrote: (Jay) wrote: Instead of running numbers on Excel with formulas filled with fudge factors from experimental data taken 70 years ago, I think I'm going to throw some wings on my FEA computer model and let the computer take care of the algebra at 2.4GHz. Now THAT is scary. Someone who thinks a computer model is a substitute for learning fundamentals (and is impressed by the speed if his PC's processorVBG) is a huge danger to himself. If you do get into the build mode, I hope you will try out your ideas on an RC model first. But learn about scale effects, or the model work isn't useful. Ben "Osborne Reynolds" Sego |
#62
ChuckSlusarczyk wrote: In article .net, Ben Sego says... other than Jim Campbell, he liked it... Corky Scott Well, I'm sold then! He likes anything that he thinks will lead to some ad money :-) He only stops liking them when they stop the ads. zoom likes it and jaun will probably rebuild it .....but never fly it. LOL!!! Chuck(believer in 70 year old data) S I understand it can be difficult to cancel an ad. Perhaps people aren't speaking clearly and forthrightly enought to them...er...him. Ben "governing myself" Sego |
#63
Jay wrote: *sigh* Instead of running numbers on Excel with formulas filled with fudge factors from experimental data taken 70 years ago, I think I'm going to throw some wings on my FEA computer model and let the computer take care of the algebra at 2.4GHz. I give up. Good luck, and please post or publish your results when you're done. The world awaits. Dave 'Pontius Pilot' Hyde ++++++++++++++++++++++++++++++++++++ Nice try, Pontius. However, this outcome was inevitable. Kinda like with his brother, Latchless. g Barnyard BOb -- |
#64
#65
#66
Thanks Alexy,
I wasn't sure what the convention was in aero work for defining "aspect", it doesn't really matter as long as everybody agrees on the same definition! So I just took David's definition and went from there. Then in his next expresion said "span^2/aero", so I figured "AERO" meant something that he hadn't defined, but I should have implicitly known, and figured at this point it wasn't crucial to the discussion. But this is the reason why I was trying to discuss relationships before we got into botched algebra. I'm seem to be continually making those kinds of errors so I end up doing everything 2 ways just to make sure. alexy wrote in message . .. Dave Hyde wrote: I think you have a fundamental misunderstanding of the basics here. An infinte (span) wing has an aspect ratio of INFINITY, not zero. LARGER aspect ratio is less drag. Dave, to be fair to Jay, you did type :The _definition_ of aspect ratio is chord/span Of course, you immediately contradicted that by typing r span^2/aero (they're equivalent)which should have clued anyone in that you had inverted the first expression. |
#67
Hey don't give up Dave, nobody said it would be easy. You haven't
convinced me not to run the model. But you have pointed out 2 things I will look at more carefully: 1) Will the root/tip losses from 2 wings eat up any benefit from the shorter/lighter spans? Are there tip treatments that diminish this? 2) What wing configuration can be used that minimizes mutual interference between the 2 lifting surfaces. Thanks! p.s. I will post the results when I get them. Dave Hyde wrote in message ... Jay wrote: *sigh* Instead of running numbers on Excel with formulas filled with fudge factors from experimental data taken 70 years ago, I think I'm going to throw some wings on my FEA computer model and let the computer take care of the algebra at 2.4GHz. I give up. Good luck, and please post or publish your results when you're done. The world awaits. Dave 'Pontius Pilot' Hyde |
#69
It looks like Atlantica is still in development, they're using the
same software as I am for my dabbling. Prescott's Pusher looks like it was pretty ordinary in terms of the trade offs made (high stall speed), the computer used for that development looks like it was for manufacturability (CAM) rather than conducting experiments in aerodynamics. The twitchyness in pitch people write about is obvious because of the distance between the center of lift and the elevator, no mystery there. If they'd had the tools available to the hobbiest today, they'd have been able to see it before they built it. Computers aren't perfect, they're programmed by people, with the same assumptions and errors. But the throughput allows a different type of analysis to be done than was previously available. Instead of trying to find a closed form aproximation for a particular parameter of flight, it allows you to model lots and lots of very simple phenomenon which come together to produce some high level behaviour like a stall or another unanticipated effect. wrote in message . .. On 19 Nov 2003 10:56:41 -0800, (Jay) wrote: :Instead of running numbers on Excel with formulas filled with fudge :factors from experimental data taken 70 years ago, I think I'm going :to throw some wings on my FEA computer model and let the computer take :care of the algebra at 2.4GHz. There you go. Exactly what Alan Shaw did with the Atlantica. It turned out great. And the Prescott Pusher, designed entirely with McDonnald Douglass CAD. A terrific airplane. A computer can't go wrong. BTW, if you aren't using a Pentium 4 3.06GHz 533Mhz 512K Xeon at a minumum, you aren't even a serious amateur. |
#70
In article , Dave Hyde wrote:
Jay wrote: Okay, thanks for all that, I think you're missing some parentheses in there because I'm getting a quad decker formula. The formula is correct as written. So with this theoretical wing of aspect approaching zero, 2 non-interfering wings of half span, would be essentially the same lift and drag as one. I think you have a fundamental misunderstanding of the basics here. An infinte (span) wing has an aspect ratio of INFINITY, not zero. LARGER aspect ratio is less drag. Again, to make a successful break from the mouse-maze, you've either got to have a sound grasp of the fundamentals or be very lucky. Counting on luck does not instill confidence (but sometimes produces interesting threads). Most if not all of those X planes were R&D payed for by the you and me, the tax payers of America. Its extremely rare for a large company to take a "flyer" with their own money and reach very far forward. Who pays is irrelevant. There have been and will continue to be radical departures from the 'box' even by giants in the aerospace industry. The simple fact that you are not aware of them does not mean that they do not exist. Dave 'to infinity...and beyond' Hyde AHA! *THERE's* the proper explanation. Twin wings, with aleph-sub-one aspect ratio _should_ out-perform a (merely) 'infinite' AR wing. *snicker* chortle =+GUFFAW+= |
| Thread Tools | |
| Display Modes | |
| Looking for a fast light plane | Dave lentle | Home Built | 2 | August 6th 03 04:41 AM |
| Glass Goose | Dr Bach | Home Built | 1 | August 3rd 03 06:51 AM |
