On Mar 5, 12:55 pm, Sean Fidler wrote:
I have an intern currently working on a slightly different project for US flights in an effort to isolate for potential cloud flying incedents over thousands of competition flights. It has been very interesting so far. More later. He did create a batch method for adding large sets of flights (but only a few dozen at a time). Not sure what dbase he is using. No one else seems to have jumped in on this so perhaps I’m overreacting. The above posting from another thread was provocative, perhaps intentionally so. I'm concerned it could send the wrong message. In the nearly 45 years since I began flying contests here in the US, I have witnessed only one or two incidents that could be classified as "cloud flying". I’m referring to extended flight in cloud primarily by reference to instruments rather than by visual reference to the ground, NOT the separate and--in the context of this discussion-- unrelated issue of VFR clearance from clouds. I am aware of no incidents that could be detected using the available analytical tools and databases. Convective cloudbases are influenced by variations in terrain, weather, time of day, and chance and may vary by thousands of feet in a relatively brief time over a small area. As with many things in aviation, we leave it up to the pilot to exercise good judgment accounting for safety and the FARs. I think this approach has served us well. No one would argue that the system is perfect, or that there will always be a few pilots to whom rules, regulations, and sportsmanship matter less than seeing their names at the top of the list, albeit only briefly. And I don’t deny that the controversy over new IMC capabilities in soaring software is messy. But I worry that this posting implies a level of "problem" that I don't believe exists. I'm not suggesting that this research be discontinued; I'm sure it’s being done conscientiously with the best interests of our sport and the flying public at heart. But publicizing provocative statements about “very interesting” findings to date without any conclusions, much less evidence, borders on being irresponsible. I have great respect for the competent, conscientious employees of the FAA I've met (yes, there are many despite the horror stories). But I know from experience that even those who are soaring pilots themselves and/or support our freedom to continue soaring feel bound to investigate further when they read something like this. And, yes, some of them do read this newsgroup. I'm aware that I am potentially adding to the visibility of this by reposting it instead of contacting the author privately but I feel strongly that we shouldn't create a problem where we can't demonstrate that one exists. The system we have now works well. The Rules Committee has done a good job of addressing the potential for future problems as a result of evolving technology. As with other trends in soaring, we should continue to monitor the situation closely to see what further action may (and almost certainly will) be required. Chip Bearden ASW 24 "JB" U.S.A. |
Chip:
I was one of those in earlier discussions who made the very strong point that it is very difficult to tell if folks have flown near clouds and you certainly can't do it from an igc file. Cloudbase is not known with any precision and can vary thousands of feet over a typical contest task area. I have on at least one occasion flown over cumulus clouds without violating any FARs and know of several occasions where other pilots have done so. Comparing flight traces of pilots with each other or a reasonable guess of cloudbase isn't going to tell you very much. An entirely different question is the practice of staying in thermals until you reach cloudbase and then exiting through the wispies. It's hard to judge when to leave a strong thermal and this can happen to the best of us. I see it a lot of this in both pleasure flights and contests. I don't know how you would make an enforceable rule to control this, unless you are going to add cockpit cameras and dew-point sensors (quite doable, by the way!).. Mike |
On Thursday, March 8, 2012 8:21:02 PM UTC-5, Mike the Strike wrote:
Chip: I was one of those in earlier discussions who made the very strong point that it is very difficult to tell if folks have flown near clouds and you certainly can't do it from an igc file. Cloudbase is not known with any precision and can vary thousands of feet over a typical contest task area. I have on at least one occasion flown over cumulus clouds without violating any FARs and know of several occasions where other pilots have done so. Comparing flight traces of pilots with each other or a reasonable guess of cloudbase isn't going to tell you very much. An entirely different question is the practice of staying in thermals until you reach cloudbase and then exiting through the wispies. It's hard to judge when to leave a strong thermal and this can happen to the best of us. I see it a lot of this in both pleasure flights and contests. I don't know how you would make an enforceable rule to control this, unless you are going to add cockpit cameras and dew-point sensors (quite doable, by the way!). Mike There's a wonderful picture that pops up on the rotating SSA photo board taken during the prestart period at a Mifflin contest a few years back. The photographer and several others (including yours truly) were lolling around in wave a couple thousand feet above the clouds enjoying the warm sun while the masses engaged in thermal warfare down in the boundary layer. Not sure what analyzing those traces would tell you... |
On Mar 9, 7:34*am, Papa3 wrote:
On Thursday, March 8, 2012 8:21:02 PM UTC-5, Mike the Strike wrote: Chip: I was one of those in earlier discussions who made the very strong point that it is very difficult to tell if folks have flown near clouds and you certainly can't do it from an igc file. *Cloudbase is not known with any precision and can vary thousands of feet over a typical contest task area. *I have on at least one occasion flown over cumulus clouds without violating any FARs and know of several occasions where other pilots have done so.. *Comparing flight traces of pilots with each other or a reasonable guess of cloudbase isn't going to tell you very much. An entirely different question is the practice of staying in thermals until you reach cloudbase and then exiting through the wispies. *It's hard to judge when to leave a strong thermal and this can happen to the best of us. *I see it a lot of this in both pleasure flights and contests. *I don't know how you would make an enforceable rule to control this, unless you are going to add cockpit cameras and dew-point sensors (quite doable, by the way!). Mike There's a wonderful picture that pops up on the rotating SSA photo board taken during the prestart period at a Mifflin contest a few years back. * The photographer and several others (including yours truly) were lolling around in wave a couple thousand feet above the clouds enjoying the warm sun while the masses engaged in thermal warfare down in the boundary layer. * Not sure what analyzing those traces would tell you... "engaged in thermal warfare down in the boundary layer" What a great line! |
On Friday, March 9, 2012 9:34:34 AM UTC-5, Papa3 wrote:
On Thursday, March 8, 2012 8:21:02 PM UTC-5, Mike the Strike wrote: Chip: I was one of those in earlier discussions who made the very strong point that it is very difficult to tell if folks have flown near clouds and you certainly can't do it from an igc file. Cloudbase is not known with any precision and can vary thousands of feet over a typical contest task area. I have on at least one occasion flown over cumulus clouds without violating any FARs and know of several occasions where other pilots have done so. Comparing flight traces of pilots with each other or a reasonable guess of cloudbase isn't going to tell you very much. An entirely different question is the practice of staying in thermals until you reach cloudbase and then exiting through the wispies. It's hard to judge when to leave a strong thermal and this can happen to the best of us. I see it a lot of this in both pleasure flights and contests. I don't know how you would make an enforceable rule to control this, unless you are going to add cockpit cameras and dew-point sensors (quite doable, by the way!). Mike There's a wonderful picture that pops up on the rotating SSA photo board taken during the prestart period at a Mifflin contest a few years back. The photographer and several others (including yours truly) were lolling around in wave a couple thousand feet above the clouds enjoying the warm sun while the masses engaged in thermal warfare down in the boundary layer. Not sure what analyzing those traces would tell you... Found it: http://www.ssa.org/sport/PhotoGaller...p?PhotoID=1186 |
On Mar 9, 9:50*am, Papa3 wrote:
On Friday, March 9, 2012 9:34:34 AM UTC-5, Papa3 wrote: On Thursday, March 8, 2012 8:21:02 PM UTC-5, Mike the Strike wrote: Chip: I was one of those in earlier discussions who made the very strong point that it is very difficult to tell if folks have flown near clouds and you certainly can't do it from an igc file. *Cloudbase is not known with any precision and can vary thousands of feet over a typical contest task area. *I have on at least one occasion flown over cumulus clouds without violating any FARs and know of several occasions where other pilots have done so. *Comparing flight traces of pilots with each other or a reasonable guess of cloudbase isn't going to tell you very much. An entirely different question is the practice of staying in thermals until you reach cloudbase and then exiting through the wispies. *It's hard to judge when to leave a strong thermal and this can happen to the best of us. *I see it a lot of this in both pleasure flights and contests. *I don't know how you would make an enforceable rule to control this, unless you are going to add cockpit cameras and dew-point sensors (quite doable, by the way!). Mike There's a wonderful picture that pops up on the rotating SSA photo board taken during the prestart period at a Mifflin contest a few years back. * The photographer and several others (including yours truly) were lolling around in wave a couple thousand feet above the clouds enjoying the warm sun while the masses engaged in thermal warfare down in the boundary layer. * Not sure what analyzing those traces would tell you... Found it: *http://www.ssa.org/sport/PhotoGaller...p?PhotoID=1186 I knew there would be some Glickin' trouble maker involved. T8 |
On Mar 9, 9:34*am, Papa3 wrote:
There's a wonderful picture that pops up on the rotating SSA photo board taken during the prestart period at a Mifflin contest a few years back. * The photographer and several others (including yours truly) were lolling around in wave a couple thousand feet above the clouds enjoying the warm sun while the masses engaged in thermal warfare down in the boundary layer. * Not sure what analyzing those traces would tell you... Cool photo! I recall waiting in the pre-start wave at the Fairfield regional a few years ago well above the convective clouds and looking down to see my first circular rainbow! Of course, I had to share this experience on the radio with my fellow competitors. I couldn't understand why they weren't all happy for me. It's true that some of my flight path would show up as climbing while stationary over the ground but the wind was relatively weak and I was doing S turns and even lazy circles to maintain position in the wave, which would have no doubt confused any algorithyms designed to filter out this kind of thing. Chip Bearden ASW 24 "JB" U.S.A. |
I also got lucky in the mifflin wave pre start. Listening to the
anguished calls from fellow competitors as they relit and struggled to stay up while I admired the view from 10,000' was just lovely. Then I cursed the rules committee who put in this darn altitude-limited start when I had to open the spoilers go back down again! Seriously, if Sean does get the data mining program working I hope he will share it with the rest of us. IMC flying is a non issue as many have pointed out. But I can think of all sorts of great things to do with traces if I could only get them in my computer easily. Hot spots, statistical evaluation of glide probabilities, analysis of tactics, "near miss" analysis, analysis of course deviations, how to make transitions,... many winters could be spent productively. John Cochrane |
On Mar 9, 9:08*am, John Cochrane
wrote: I also got lucky in the mifflin wave pre start. Listening to the anguished calls from fellow competitors as they relit and struggled to stay up while I admired the view from 10,000' was just lovely. Then I cursed the rules committee who put in this darn altitude-limited start when I had to open the spoilers go back down again! Seriously, if Sean does get the data mining program working I hope he will share it with the rest of us. IMC flying is a non issue as many have pointed out. But I can think of all sorts of great things to do with traces if I could only get them in my computer easily. Hot spots, statistical evaluation of glide probabilities, analysis of tactics, "near miss" analysis, analysis of course deviations, how to make transitions,... many winters could be spent productively. John Cochrane Hypothetically, data mining traces for a given contest day could yield something like a "soarability index" which could reveal the relative advantage of one handicapped glider over another given the average thermal strength, height, distance between thermals etc... This index might inform tilting the handicaps to level the playing field for the day's weather. |
On Mar 9, 11:08*am, John Cochrane
wrote: But I can think of all sorts of great things to do with traces if I could only get them in my computer easily. Hot spots, statistical evaluation of glide probabilities, analysis of tactics, "near miss" analysis, analysis of course deviations, how to make transitions,... many winters could be spent productively. I've used flight traces to analyze "near misses" on several occasions, including for a safety talk using a multii-media projector that elicited sharp intakes of breath from the assembled pilots when two blips appeared to merge briefly. I also emailed my trace to another pilot with a copy of his to explain why I'd gotten a little agitated one day. And on more than one occasion I've replayed situations where sailplanes appeared rather suddenly to see what I'd missed and how I could have avoided being surprised. This doesn't tell you what a pilot was looking at or whether the sun was reflecting off the canopy or if it was hazy that day but it does help explain the events that led up to one or more pilots briefly experiencing a rapid heart rate. And all of this can help lead to greater awareness of how to avoid becoming a statistic of a different sort. Chip Bearden ASW 24 "JB" U.S.A. |
R9N Logan Competition | Ron Gleason | Soaring | 1 | July 20th 10 08:12 PM |
304S in competition again | Tim Mara | Soaring | 7 | July 25th 08 06:41 PM |
See You Competition | Mal[_4_] | Soaring | 0 | August 14th 07 01:56 PM |
Satellite wx competition | john smith | Piloting | 0 | February 10th 06 02:03 AM |
Competition I.D. | Ray Lovinggood | Soaring | 22 | December 17th 03 12:22 AM |
