#61
On 6/5/2012 11:09 PM, Eric Greenwell wrote:
On 6/5/2012 10:15 PM, Ramy wrote: Hopefully not hijacking this thread, but electronic compensation such as the one my 302 is using seem to be as good as the TE compensation my winter is using, so looks like I could get rid of the TE probe (except that in many cases it is also the pitot). Works for me! It's particularly valuable for a motorglider like I have, because the prop wash drives the TE nutty. My glider uses the nose pitot for the airspeed indicator, not the one on the TE probe, and I think that is common. Possibly, those of us that no longer use the fin-mounted TE probe could mount our PowerFlarm antennas in it's place. Held out in front of the fin, the two antennas would have an excellent view of the world, and the coax could be run beside the TE probe tubing and through the same holes it uses. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
#62
On 6/6/2012 6:25 PM, Eric Greenwell wrote:
the two antennas would have an excellent view of the world, and the coax could be run beside the TE probe tubing and through the same holes it uses. Yes that's all true, but that sounds like a long coax run. Have you considered coaxial cable loss at that frequency? Vaughn |
#63
On 6/6/2012 6:37 PM, Vaughn wrote:
On 6/6/2012 6:25 PM, Eric Greenwell wrote: the two antennas would have an excellent view of the world, and the coax could be run beside the TE probe tubing and through the same holes it uses. Yes that's all true, but that sounds like a long coax run. Have you considered coaxial cable loss at that frequency? Vaughn The long run requires very good coax to keep the signal low. That usually means the easy to pull skinny coax can't be used; also, the tubing might be tied glued in a few places, so it's not obvious the idea is practical. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
#64
On 6/6/2012 7:33 PM, Eric Greenwell wrote:
On 6/6/2012 6:37 PM, Vaughn wrote: On 6/6/2012 6:25 PM, Eric Greenwell wrote: the two antennas would have an excellent view of the world, and the coax could be run beside the TE probe tubing and through the same holes it uses. Yes that's all true, but that sounds like a long coax run. Have you considered coaxial cable loss at that frequency? Vaughn The long run requires very good coax to keep the signal low. That usually means the easy to pull skinny coax can't be used; also, the tubing might be tied glued in a few places, so it's not obvious the idea is practical. That should be "to keep the signal losses low". -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
#65
On Jun 6, 10:23*pm, Eric Greenwell wrote:
On 6/6/2012 7:33 PM, Eric Greenwell wrote: On 6/6/2012 6:37 PM, Vaughn wrote: On 6/6/2012 6:25 PM, Eric Greenwell wrote: the two antennas would have an excellent view of the world, and the coax could be run beside the TE probe tubing and through the same holes it uses. Yes that's all true, but that sounds like a long coax run. Have you considered coaxial cable loss at that frequency? Vaughn The long run requires very good coax to keep the signal low. That usually means the easy to pull skinny coax can't be used; also, the tubing might be tied glued in a few places, so it's not obvious the idea is practical. That should be "to keep the signal losses low". -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) This prompted me to Google "low drag antennas" and "conformal antennas". There's a lot to choose from but I can't say which is best. It occurs to me that the actual conductors inside a "rubber ducky" antenna is extremely fine. Could these fine wires be attached to the inside of a canopy and be essentially invisible? |
#66
Years ago, I fabricated an antenna out of stick-on aluminum foil that was about the same thickness as vinyl letters. It worked great on my fiberglass fuselage and adjusting the length to get a good SWR reading was a snap.
You might have a challenge finding somewhere on a modern glider that doesn't have carbon fiber, which is too conducting for this to work. (A colleague suggested that cutting a slot antenna in the fuselage might be an alternative!) Mike |
#67
might be an alternative!) Mike That was a good one! Thanks ![]() |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
If your bored, think about this and notes about Ely, Nv. | [email protected] | Soaring | 15 | February 9th 07 11:30 PM |
Notes from the RAP pre-OSH party | Viperdoc | Piloting | 2 | July 23rd 06 06:24 PM |
DG500 AD notes | Sailplane Mechanic | Soaring | 2 | August 27th 04 05:35 PM |
A few notes from Uvalde | Dave Nadler YO | Soaring | 0 | August 13th 04 05:26 PM |
