Who's At Fault in UAV/Part91 MAC?
Old April 28th 04, 12:34 AM
Larry Dighera
On Tue, 27 Apr 2004 20:11:17 GMT, "Bob Jones" wrote
in Message-Id: m:
"Larry Dighera" wrote in message
Once you show me *evidence* of lackadaisical attention to safety by
the owners and operators of those very expensive bits of hardware,
I'm happy to have you aboard. :-) Here is the information you
request:
Interesting that none of those cites indicate anything approaching "evidence
of lackadisical attention to safety".
Obviously our assessments differ.
Lessee... Inadvertent cloud entry.
http://www.globalsecurity.org/milita...0219-acc01.htm
releases RQ-1 accident report
According to an Air Combat Command accident investigation report
released today, the primary cause of the accident was that the
pilot unintentionally flew the aircraft into a hazardous cloud.
FARs prescribe limits on how close to clouds a VFR flight may be, and
a certificated pilot is trained in recovery techniques.
Reference to difficulty in landing.
http://www2.acc.af.mil/accnews/dec99/990383.html
The two Predator pilots, who control the aircraft from a ground
station, executed critical action procedures but were unable to
land the aircraft safely. It crashed in a wooded area four miles
south of Tuzla AB.
According to the report, the pilots' attention became too focused
on flying the Predator in icing and weather conditions they had
rarely encountered. The report also cites lack of communication
between the two pilots during the flight emergency as a cause of
the accident.
Faulty assembly.
http://www2.acc.af.mil/accnews/apr01/01127.html
According to Air Combat Command's Accident Investigation Board
report released Thursday, the accident resulted from mechanical
failure in the UAV's propeller control system. Investigators found
substantial evidence indicating errors during maintenance on the
propeller control system on Sept. 28 played a critical role in the
accident. Evidence showed that certain components of the propeller
assembly were not adequately lubricated; in addition, a key bolt
was stripped and had not been tightened properly. These errors
likely led to the accident, according to the lead investigator.
As you will note, the maintenance personnel did not apply the same
diligence in maintaining the unmanned aircraft as is required by
regulation for manned aircraft.
Icing encounters (two of those).
http://www2.acc.af.mil/accnews/aug01/01267.html
LANGLEY AIR FORCE BASE, Va. (ACCNS) -- Officials investigating the
March 30 crash of an RQ-1L Predator unmanned aerial vehicle have
determined the accident resulted from operator error.
According to the Accident Investigation Board report released
today by Air Combat Command, the Predator experienced an icing
problem and the pilot was unable to maintain control of the
aircraft.
According to the report, the pilot recognized the icing problem,
but failed to immediately execute critical checklist steps for
pitot static system failure.
Mechanical failure due to inadequate lubrication.
Yes, and a stripped bolt. That sort of poor maintenance practice is
not permitted manned aircraft.
Sounds like a reading from the NTSB database.
No. It sounds like you failed to appreciate the operational errors
committed by the ground based UAV operators and maintenance personnel.
The point is that none of these equate to "lackadaisical attention to safety
by the owners and operators".
By omitting the citations below, you publicly demonstrate your biased
thinking:
http://www.aetc.randolph.af.mil/se2/...305/runway.htm
GROUND CREW’S INATTENTION LEADS TO UNMANNED AIRCRAFT CRASH
released last month, the primary cause of the accident was the
ground crew’s inattention to the aircraft’s altitude.
http://www.globalsecurity.org/intell...s/predator.htm
As of 31 October 2001 the Air Force had received a total of 68 air
vehicles, and had lost 19 ...
The operator has the camera pointing out the front of the plane,
but he really has lost a lot of situational awareness that a
normal pilot would have of where the ground is and where the
attitude of his aircraft is.
http://www.reviewjournal.com/lvrj_ho.../19962521.html
May 17 crash of unmanned spy plane blamed on human error
http://www.af.mil/news/Feb2001/n2001...shtmlOfficials
02/02/01
Officials release Predator RQ-1L Predator accident report
... the pilot -- who flies the aircraft from a ground control
station -- inadvertently cleared the primary control module's
random access memory. As a result, the Predator lost its data link
connection with the ground control station.
  #62
Old April 28th 04, 01:02 AM
Bob Jones
Where in that report did it mention the flight plan type? You're either
making assumptions again or making another bad comparison.
the accident.
Again, you posted these cites in response to a request for evidence of
"lackadaisical attention to safety". How does this provide such evidence?
For that matter, how is this any different from an IR pilot unaccustomed to
actual conditions suddenly finding himself coated in ice? Human error?
Yes. Additional safety concern? No.
How is this different from certificated A&P's working for, say, Alaska
Airlines? Or any number of similar NTSB reports for GA crashes. You still
haven't made the case that UAV's pose an inherent aviation safety risk.
"Not permitted," he says. See above. Humans make maintenance mistakes
regardless of aircraft type (manned or not). You still haven't made the
"Operational errors" like the hundreds (thousands?) of similar incidents
committed with manned aircraft. You still haven't made the case that UAV's
thinking:
"Biased", eh? Like you're totally open-minded on this issue. You so full
of BS your eyes are brown.
You keep making the claim that UAV's pose a risk to manned aircraft.
However, even when asked for such evidence, you can't find a single incident
where a manned aircraft was threatened much less harmed by UAV's.
...the primary cause of the accident was the
ground crew's inattention to the aircraft's altitude.
No different from manned aircraft.
Actually, I did reference this one. See "difficulty landing". You left out
the critical context of your quote. See this (from your link):
"A good number of them were lost due to operator error, **since it is hard
to land the UAV.** The operator has the camera pointing out the front of the
plane, but he really has lost a lot of situational awareness that a normal
pilot would have of where the ground is and where the attitude of his
aircraft is."
[Emphasis added by me.]
Larry, don't bother calling me biased when you're not even *close* to
unbiased.
"Human error" does not equate to "lackadaisical attention to safety." You
still have not proven that UAV's pose an inherent aviation safety risk.
Human error again, but not "lackadaisical attention to safety." You still
have not proven that UAV's pose an inherent aviation safety risk. (Note:
I'd venture to say this is a bad design feature. The pilot should not be
able to clear the UAV's RAM - especially if doing so can cause the UAV to
lose connectivity with ground control.)
  #63
Old April 28th 04, 06:50 PM
Larry Dighera
On Wed, 28 Apr 2004 00:02:54 GMT, "Bob Jones" wrote
in Message-Id: m:
What if 30% of the manned aviation fleet were to be lost in 10 years
as is the case of UAVs?
Incidently, you haven't contributed any factual information to this
message thread at all.
  #64
Old April 28th 04, 06:51 PM
Larry Dighera
On Tue, 27 Apr 2004 19:26:56 GMT, "Bob Jones" wrote
in Message-Id: m:
I was taught to scan for traffic to the rear of the side to which I
intend to turn before making the turn.
That may be, but do you perform this scan in all quadrants in real-time?
If necessary.
Or only when you need it? My point is you appear to be placing a higher
standard on UAV's than are placed on existing aircraft/pilots.
That is not my intent.
By the way, where in Part 61 are the vision requirements specified?
He
[really long URL]
Ah, Part *67*, just as I thought. You were either lying or ignorant when
you made this claim:
"It's doubtful the...UAV operators' vision systems would function equal to
or better than that required meet the Part 61 requirements."
Part 61 (§61.23) requires the pilot of an airplane to possess a valid
Medical Certificate, so it indirectly mandates pilots to meet the
vision requirements of Part 67.
Why would you think I was fabricating the pilot vision requirement?
Do you hold an airmans certificate?
As near as I can tell, the words "vision", "eyesight" and "sight" don't even
appear in Part 61.
See above.
Further, you admitted elsewhere in this thread that you
have no idea what the capabilities of these systems are (yet more
ignorance).
I believe the UAV capabilities are a bit of a moving target, as its
systems are still under development.
But why let the facts get in the way of your quixotic quest, eh?
You haven't provided any facts at all, only personal opinion, so you
have no accountability at all to worry over.
  #65
Old April 28th 04, 09:41 PM
Bob Jones
Apples and oranges - again. Military UAV losses have no relation to the
civilian sector. Besides, your original question posed was "who's at fault
in a UAV/Part91 MAC?" Now you're trying to change the argument to "UAV's
losses are too high."
Are you trying to imply something else?
Neither have you posted any facts to back up your claim that UAV's somehow
pose a risk to Part 91 or any other Part aviation.
You claim that UAV's should not be allowed to fly border patrols due to
their inability to achieve the vision requirements in all quadrants in
real-time as specified in 14CFR Part 61. Only when pressed did you post the
actual requirements - from Part 67 - and then you admitted that you have no
idea what these UAV's are capable of achieving. For all you know, they may
have systems far better than human eyesight.
You are trying to get us all riled up about some perceived safety issue.
However, all you have demonstrated is that there have been significant
losses in UAV's used by the military - many of which have occurred during
landing or in action. Several incidents have been attributed to "human
error" - not necessarily operator error - and none of these incidents causes
me much concern for sharing the skies with them.
You claim I haven't provided any facts and you're right. I don't have
enough to make an educated judgement on this issue. That's why I'm willing
to see the proposals for the operating parameters of the UAV's before I get
concerned, but that doesn't mean I won't call you on your BS.
Face it. You haven't made the case that UAV's pose an inherent aviation
safety risk.
My position remains one of "wait and see". I want to see the operational
plans. Where will they be based? Where will they operate? Will they be
coordinating with ATC? What altitudes will they maintain? What paths will
they take to get to station? Will they have strobes and nav lights to help
VFR visibility? Will they have collision avoidance systems? Other
questions may come to mind after reading their operational plans, but if
these questions are answered to my satisfaction, then I see no problem.
The original quotes you posted mentioned UAV use being considered by
non-military agencies, but you haven't posted any relevant information about
the operational plans or aviation safety record of these agencies.
Nothing you've posted has *any* relation to overall aviation safety. All
you've done is try to stir the pot with implications and innuendo.
  #66
Old April 28th 04, 10:10 PM
Bob Jones
Do you know the UAV operators won't have valid certificates? If you don't
know the answer to this question, then this point of yours is a non
sequitor, isn't it?
If you don't know the capabilities (i.e., "you don't have the facts"), then
on what are you basing your opinion?
You're the one trying to make a case to get the rest of us concerned over
something. Bring your facts and we'll discuss them. All you've done so far
is bring implications and innuendo (i.e., "BS").
  #67
Old April 29th 04, 03:08 PM
William W. Plummer
ALL planes, manned, remotely piloted or UAVs, are a risk to aviation.
That's why we have the FARs, flight plans, restricted entry to MOAs, etc.
We all operate in the same air. --Bill
"Bob Jones" wrote in message
s.com...
fault
no
may
causes
willing
get
safety risk.
will
help
about
  #68
Old April 29th 04, 04:39 PM
Tony Cox
s.com...
sequitor, isn't it?
They may have in the future, but they certainly don't have them now.
Says FAA spokesman William Shumann, "Currently, there are no
FAA regulations dealing with the certification of UAV pilots,
aircraft or (commercial) operators". Nor have I seen any suggestion
that they'll have to be certified in the future.
far
From your point of view, maybe. I've found Larry's contribution
interesting, and certainly something to be concerned about. If you'd
been on this newsgroup longer, you'd realize that it'd be a pretty
empty forum if we just concerned ourselves with "facts".
The most important and worrying aspect of operating UAVs in
the public airspace is that *currently* they will not be operating
under the same constraints as the rest of us. Why? Well for one
thing the entire optical system through camera to operator
isn't certified to private pilot standards.
Of course, you may well be right (as in another post) that "For
all you know, they may have systems far better than human
eyesight". Hell, for all I know, the old duffer at the airport
flying without any sort of medical may well have the best
vision on the planet. But this just doesn't cut it. You can't
'self certify' for vision, and suggesting that this is OK if the "old
duffers" just happen to be the UAV manufacturers is a
significant departure from existing practice. It's not BS, it's
a very valid concern.
  #69
Old April 30th 04, 02:43 AM
Bob Jones
"Tony Cox" wrote in message
nk.net
...It's not BS, it's a very valid concern.
That's where I differ: I tend not to get very concerned until there are
*facts* to be concerned about.
  #70
Old April 30th 04, 08:37 AM
Dylan Smith
In article et, Tony Cox i
It sort of begs the question - if UAV pilots are going to need to be
essentially PPL standard for medical etc. why bother? Why not just send
the guy up in a Cessna 172 to do his patrols instead? It'd be much
cheaper to stick the man in an existing aircraft that you can buy off
the open market for low (for Government) cost if you're going to need
the man to fly a UAV remotely, anyway.
I see an advantage to using UAVs for reconnaisance over enemy territory.
But over your own country, the only point to UAVs I can see is research
and training the recon operators - which can all be done in a MOA.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Who's At Fault in UAV/Part91 MAC? Larry Dighera Instrument Flight Rules 24 April 29th 04 03:08 PM
Thunderbird pilot found at fault in Mountain Home AFB crash Ditch Military Aviation 5 January 27th 04 01:32 AM
It's not our fault... EDR Piloting 23 January 5th 04 04:05 AM
Sheepskin seat covers save life. Kevin Owning 21 November 28th 03 10:00 PM
Senators Fault Air Force on Abuse Scandal Otis Willie Military Aviation 4 October 2nd 03 05:46 AM
