"Do It Yourself" airborne proximity warning device
Old October 30th 18, 03:35 PM posted to rec.aviation.soaring
Linar Yusupov
Default "Do It Yourself" airborne proximity warning device
Mike,
Mark Hawkins has it working with iGlide via WiFi.
Hmm. Are you sure?
He wrote earlier that:
3. Have gotten it to connect via Bluetooth LE (BLE) to iSoar which seems to process the PF sentences just as it does from other devices
As for iGlide, Air Avionics does not specify he https://www.air-avionics.com/?page_id=507
that it is able to do BLE, but they do AirConnect instead.
T-Beam's are shipped with either RC4 or RC5 SoftRF firmware versions. NMEA TCP (AirConnect) option was not available at that time yet. So build of the firmware from current source code and re-flashing is necessary.
I would also appreciate if someone will confirm that ForeFlight is dong fine with SoftRF over Garmin GDL90.
I have not done it by myself yet, as well as never seen reports about that from builders worldwide.
Linar.
  #62
Old October 30th 18, 03:48 PM posted to rec.aviation.soaring
Mike C
On Tuesday, October 30, 2018 at 9:35:45 AM UTC-6, Linar Yusupov wrote:
Mike,
Hmm. Are you sure?
Linar.
Linar,
When I saw Ed A's post an hour or so ago, I asked Mark who uses the app and he replied exactly as I have indicated.
  #63
Old October 30th 18, 03:53 PM posted to rec.aviation.soaring
Linar Yusupov
Ok. Good news! Thank you!
  #64
Old November 5th 18, 05:04 PM posted to rec.aviation.soaring
John Wells
Can a softrf be integrated into an existing (FLARM) setup?
I'd like to keep the flarm for its proven anti-collision warnings, and add in the ability to see all the other stuff that the Softrf provides. However the two antennae will interfere with each other (?).
  #65
Old November 5th 18, 07:48 PM posted to rec.aviation.soaring
Darryl Ramm
"interface" means so much asking that is pretty meaningless. What do you expect/want it to do? Work on separate displays? An integrated display? Provide what services? What FLARM do you have and what country are you in? In the USA do you have ADS-B Out?
  #66
Old November 6th 18, 12:59 PM posted to rec.aviation.soaring
John Wells
I'd like to be able to take NMEA stream from the Softrf for NON-FLARM contacts. I'm happy to write software or whip up a little micro to merge this with the NMEA output from FLARM and present them on my xcsoar radar.
But I expect the Softrf antenna will negatively impact my flarm tx/rx and vice versa.
I'm in the UK. CLASSIC Flarm. But at the high level I don't think this makes any difference. I'm happy to do a lot of the leg work myself but just wondered what was possible.
  #67
Old November 6th 18, 01:20 PM posted to rec.aviation.soaring
Christophe Mutricy
depending your skillset, it might be easier to review/adapt Xcsoar. I
believe XCSoar uses the data from the first device with that kind of data.
That is certainly the case for GPS.
So you might have to modify the code so that "FLARM" data is accepted from
several device. (flarm between quote because all traffic device are seen as
flarm if using the flarm protocol)
vice versa.
If the SoftRF doesn't transmit and the antenna are not close there won't be
interference.
If the softRF transmit on the same or close by frequency as FLarm then we
might have provlem if they both transmit exactly at the same time.
Xtophe
  #68
Old November 6th 18, 04:14 PM posted to rec.aviation.soaring
Linar Yusupov
Can a SoftRF be integrated into an existing (FLARM) setup?
If you are considering XCSoar as FMS software, you either:
1) wait until Max will release next 7.0 preview or
2) build your own XCSoar binary from current source code tree.
( make sure that this commit : https://github.com/XCSoar/XCSoar/com...5fd3abf08e09e3
is in there. )
1) Two receivers typically do not affect each other when distance between them is more than 2X of max. antenna size. Otherwise even inactive 2nd receiver's antenna (as well almost any other metal object) will slightly alter characteristics of 1st receiver's antenna (such as RL, SWR, …) ;
2) SoftRF's transmitter is compliant with 1% duty cycle rule ;
3) in any doubts, SoftRF user can disable transmitter with "Tx Power" menu option:
https://github.com/lyusupov/SoftRF/wiki/Settings
After that, other traffic will not see you on this protocol, but you will still be able to see them all.
  #69
Old November 7th 18, 03:56 PM posted to rec.aviation.soaring
John Wells
Neat... I'm already using v7 on a custom openvario.
Is it worth transmitting ogntp if I already have a flarm?
  #70
Old November 8th 18, 02:48 AM posted to rec.aviation.soaring
Ed A
On Tuesday, October 30, 2018 at 2:35:04 AM UTC-6, Linar Yusupov wrote:
Will this device work with iGlide on IOS?
AirConnect compatible Wi-Fi connection service is active in the firmware's source code since October 9th.
Known to work good with SkyDemon, Air Nav Pro.
You could let us know if it works with iGlide too.
Hello Linar,
We experimented with our new Prime Mk II device last weekend. It was a non-flying day here in Colorado, so we ground tested it against a PowerFLARM in a parked Ventus. We successfully paired the device (using Wi-Fi) with XCSoar running on a Samsung Tab A tablet. Then, we tested it by walking up and down the taxiway and were pleased to see that our "glider" was clearly displayed on the Ventus FLARM display and the Ventus was displayed on our tablet. Mission accomplished, so far. Next step will be to set up an OGN receiver and do some flight testing.
It's quite amazing that a DIY product that goes together in five minutes and costs about $50 can provide this kind of capability. (One of our members made the enclosure on his 3D printer.) Thank you Linar!
Note: I was hoping to try it with iGlide on the iPhone X, but was not successful. I installed AirConnect on the iPhone but couldn't get them to link. I've never used AirConnect before and may not be configuring it correctly. Is there a secret to this? I would appreciate any helpful suggestions from anyone who has had success with iGlide. Mike, Mark ... any suggestions?
Ed A
"View Limiting Device" recommendations please [email protected] Instrument Flight Rules 27 February 4th 08 02:25 AM
Monday 073007 in Oshkosh - Going Home [01/10] - "Departing Oshkosh - Airborne Inaging DC3C.jpg" yEnc (0/1) Just Plane Noise[_2_] Aviation Photos 0 August 2nd 07 04:39 AM
Monday 073007 in Oshkosh - Going Home [01/10] - "Departing Oshkosh - Airborne Inaging DC3C.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 August 2nd 07 04:39 AM
New traffic warning device Loran Products 26 February 18th 04 12:14 AM
Plane with no stall warning device? Roy Smith General Aviation 23 February 17th 04 03:23 AM
