#61
Hi Jay,
Yes, in order for a towered Airport to be class "D" it must have surface based weather observation cabability, if not it is class "E" and in some cases class "G" airspace. And as I believe others have already said, only Class "B" airspace provides VFR seperation, hence the 3SM visibility, clear of clouds VFR minimum. Greg King Dakota N2957F "Jay Honeck" wrote in message news:mdspc.6907$qA.776955@attbi_s51... Aren't you forgetting about class E? That is labeled "controlled", too, but hopefully even the dumbest pilot would not expect VFR traffic separation by ATC in class E. We're talking about tower-controlled airspace here, methinks. Are there any Class E towers? |
#62
![]() "atis118" wrote in message om... Yes, in order for a towered Airport to be class "D" it must have surface based weather observation cabability, if not it is class "E" and in some cases class "G" airspace. That's not correct. All surface areas, Class B, C, D or E, require weather reporting capability. And as I believe others have already said, only Class "B" airspace provides VFR seperation, hence the 3SM visibility, clear of clouds VFR minimum. Class C airspace provides separation between VFR and IFR aircraft, TRSAs provide it between all participating aircraft. |
#63
On Sun, 16 May 2004 13:47:43 GMT, "Steven P. McNicoll"
wrote: "atis118" wrote in message . com... Yes, in order for a towered Airport to be class "D" it must have surface based weather observation cabability, if not it is class "E" and in some cases class "G" airspace. That's not correct. All surface areas, Class B, C, D or E, require weather reporting capability. Would a radio to phone link to FSS qualify for a class e airport? |
#64
![]() "StallFearer" wrote in message ... Would a radio to phone link to FSS qualify for a class e airport? With regard to weather reporting? I don't understand your question. |
#65
On Sun, 16 May 2004 15:28:30 GMT, "Steven P. McNicoll"
wrote: "StallFearer" wrote in message .. . Would a radio to phone link to FSS qualify for a class e airport? With regard to weather reporting? I don't understand your question. Yes, with regard to the weather reporting requirement mentioned higher in the thread. |
#66
![]() "StallFearer" wrote in message ... Yes, with regard to the weather reporting requirement mentioned higher in the thread. But what's your question? |
#67
![]() "StallFearer" wrote in message ... Would a radio to phone link to FSS qualify for a class e airport? No. Class E or G airports are temporary in nature. |
#68
"Steven P. McNicoll" wrote in message hlink.net...
"atis118" wrote in message om... Yes, in order for a towered Airport to be class "D" it must have surface based weather observation cabability, if not it is class "E" and in some cases class "G" airspace. That's not correct. All surface areas, Class B, C, D or E, require weather reporting capability. You're right..I stand corrected, I got mixed up with the fact that when a tower at a class "D" airport shuts down for the evening, the airspace reverts to class "E" with controlled airspace starting at 700' or 1200'. I started typing before thinking :-) Greg Dakota N2957F |
#69
#70
![]() "Newps" wrote in message ... No. Class E or G airports are temporary in nature. Temporary airports? |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
