#61
kontiki wrote:
Friedrich Ostertag wrote: It IS neccessary. Just to name an example, evaporation proporties need to be adjusted to climatic conditions. Try and fill your car in AZ, preferably at a high altitude location, then drive it to one of the northern states without refueling (probably won't work with the mileage you get on current US cars..:-)) and try to start it in the morning at below freezing temperatures. You will be surprised. By that logic then, we'd need to have a different blend of AVGAS for each density altitude that we fly at, Only if you require to cold-start it at altitude... And if you expect a clean, instantaneous runup like you get from any current production car. From what I have seen the starting behavior of aircraft engines couldn't be further from it even at "normal" ambient temperatures. Another point, of which I'm not perfectly sure, but could it be, that the detailed and stringent requirements on many properties of Avgas, which ensure that it will work properly under very different conditions, are part of what makes it so expensive? Motor vehicle engines are not weight limited and are generally far more advanced in design than the average piston aircraft engine. This technology gives them the capability to adjust their fuel air mixtures and ignition timing based upon real time conditions so they can always operate at maximum efficiency at any altitude or temperature (after being warmed up of course). partly true, but to warm it you have to start it first. And no car user would accept having to warm up his vehicle for 10-15 Minutes before driving away. Cars today are expected to perform flawlessly even when cold (or, for that matter, very hot). This does require different fuel properties depending on climatic conditions. Although I will admit, that you have a point in the following: Different fuel blends are not necessary unless you carry emission standards to exaggerated extremes, which is exactly what is going on in this country today. At least, the emission standards, and therefore the dependant fuel properties, should be handled at federal level. regards, Friedrich -- for personal email please remove "entfernen" from my adress |
#62
#63
They were, and that's how the goddamned farmers in Iowa got California mandated
to go to this frikkin' gasahol. Jim "Friedrich Ostertag" shared these priceless pearls of wisdom: - -At least, the emission standards, and therefore the dependant fuel -properties, should be handled at federal level. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 10:43 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 10:43 PM |
Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | Aviation Marketplace | 1 | January 13th 04 08:26 PM |
Fuel dump switch in homebuilt | Jay | Home Built | 36 | December 5th 03 02:21 AM |
