US Rules change needed for devaluation of contest day
Old August 10th 14, 06:10 PM posted to rec.aviation.soaring
Tim Taylor
Default US Rules change needed for devaluation of contest day
After the day at Moriarty earlier this year and Nephi yesterday for the 15M/Std Combined class the rules for how a day is devalued needs to be addressed. I understand why the rule was modified a few years ago so that if pilots just didn't fly it would not devalue the day, but the criteria of what makes a valid attempt is now too high.
We had most of the class yesterday not able to get up and make a start. It was not from trying as some pilots took up to three tows. We had a thunderstorm come just north of the field and had to elephant walk the class to the other end. We had several pilots including 7V and GW land out trying to get to better air prior to starting so they were considered not creditable attempts. How much more creditable do you have to be than willing to land out to attempt the task?
Why is this important? Because it makes the contest score subject to random luck rather than showing skill. If we want to attract more pilots to racing we need to ensure that they feel like they can have a fair opportunity to race.
Yesterday should have been devalued to almost nothing or have no score because too few pilots had an opportunity to compete.
Please send a note to one of the SSA Rules Committee Members to ensure that this gets put on their list of things to address this year.
Tim (TT)
Old August 10th 14, 09:01 PM posted to rec.aviation.soaring
John Cochrane[_3_]
Granted devaluation is a mess, but this situation does not require a rules change. If the whole start zone has no lift, if many pilots cannot stay up, then the task should not be opened. If the task is opened anyway, the CD should cancel the task when it becomes clear that an unfair situation developed. If the CD does not cancel the task, pilots may protest. There is precedent from Parowan, when pilots at the end of the grid had no chance to start, and the protest was upheld.
11.1.3 A valid competition day is a day on which every regular entrant is given a fair opportunity to compete,...
10.8.1.2 After the announcement of task opening time, the CD should consult with the task advisors as to whether the selected task is fair and safe.
3.1.3.1 ... The CD ...is responsible to the SSA for insuring compliance with these rules and fair competition.
(also search about 5 other instances of "fair" in the rules)
You know the process, put in a protest ASAP.
John Cochrane
Old August 10th 14, 10:11 PM posted to rec.aviation.soaring
Tim Taylor
John Cochrane
John,
I agree that a protest could be filed at this point, but I still think the rules need to be changed so that not all the responsibility is on the CD during a contest. With start calls no longer required at most contest the CD does not always know how many are on course or not until long after the gate is open. There were several that landed out only a few miles away but the CD did not know if they had started or not.
We also need some hard rules in the scoring for percentages that attempt, etc. that automatically devalue a day until it is zero if too great of a percentage of pilots can't attempt the task. I realize the program should work that way but right now if they don't make a minimum distance they are treated as if they did not try. So if only one or a few get away they get 1000 points rather than a few or none. The definition of a credible attempt may need to be changed to something less restrictive like those that turned in a flight log for the day.
I was one of the few that was not affected by the result but and I have friends on both sides that benefited and were hurt by the last day. Would be nice if we had hard rules so it felt fair to all and they didn't feel like someone had to rule for one group or the other.
Tim
Old August 11th 14, 12:35 AM posted to rec.aviation.soaring
Steve Koerner
I agree with Tim. If we are going to endure the complication of having a devaluation scheme in the rules, then most certainly it should have kicked in for yesterday. For myself, I wouldn't mind seeing the whole devaluation concept thrown out in the interest of simplification. It seems to be impossible to get to a devaluation scheme that works right.
As the last person on the grid, I'm pretty sure I launched into impossible conditions. As Tim said, I glided away from the storm to no avail and had to put down in a farm field 8 miles south of Nephi. I don't give up easily.. That said I'm not personally inclined to file a protest since it doesn't actually make any difference to me - I'd already eaten thunderstorm humble pie on the two preceding days so I was out of the running. And for the record, Ron did a really outstanding job as CD for this contest even if there might have been a small mistake in opening the task for 15m handicapped class on the last day. It was really a great contest and very well run.
To share a certain beauty of the occasion it was this: As I had picked what I thought to be the best of dozens of possible fields in the area, I was flopping hopelessly in bits of turbulence at low altitude about a half mile downwind from that chosen field ready to make each turn my last of the contest. To my surprise, I sighted 7V a little west at the same low altitude flopping just like me. We both gave up at exactly the same altitude and glided into that particular farm field for simultaneous landings.
Old August 11th 14, 12:40 AM posted to rec.aviation.soaring
John Cochrane[_3_]
Was there the recommended consultation about a "fair and safe" start with the task advisers? Did anyone pipe up on the radio and say "it is impossible to stay up anywhere near the start cylider, I think starting the task right now would be very unfair?"
John Cochrane
Old August 11th 14, 12:42 AM posted to rec.aviation.soaring
John Cochrane[_3_]
PS:
It would be most helpful to have a suggestion of exactly what formula you would like put in place for a situation like this. Include pre-start landouts in the definition of "contestant?," as if they had landed out after starting?
John Cochrane
Old August 11th 14, 01:07 AM posted to rec.aviation.soaring
Steve Koerner
John Cochrane
I'm not sure whether advisors were consulted. I know that I was consulted twice I presume because I was the last designated launcher. On one occasion I reported to the CD that I was gliding with no lift found; and on the other occasion, if I remember correctly, I advised that I was in one knot at 1500 AGL. Immediately after that report, the CD confirmed that the task would open in 5 minutes. I was surprised at that. Before I launched there had already been numerous relights in the class.
And I'll say again: I'm not whining about any of this. Ron did a great job with lots of quick decisions to be made yesterday. The culprit was the damn thunderstorm outflow.
Old August 11th 14, 03:23 AM posted to rec.aviation.soaring
Dave Leonard
John Cochrane
The adviser was on the ground waiting for a relight. The other class task advisers were long gone on course where the weather was fine. A few pilots were staying up, even climbing very slowly, drifting away with the 20+ kt wind.
May be a rare glitch. But it happened in both Region 9 contests this year with two different CDs.
Tough day.
Old August 11th 14, 06:01 PM posted to rec.aviation.soaring
John, I've taken your advice and submitted a formal protest.
Bif Huss "H7"
Old August 11th 14, 06:15 AM posted to rec.aviation.soaring
WaltWX[_2_]
Tim and all...
Here's the Sat imagery, Radar for the last day at Nephi. The plus plots are the TP database. The label for the plot points is mangled due to a bug in the program.
Here are two radar loops from MTX (Salt Lake City radar): One is reflectivity at 0.5 deg (lowest) elevation angle; the other is for echo tops in thousands feet. The GOES 1km Vis photo follows that. Note that there was an outage of sat imagery between 130pm and 3pm MDT (1930z-2100z):
https://www.dropbox.com/s/pyze3df7tc...1_20140809.mp4
https://www.dropbox.com/s/lc7wtxh3lh...s_20140809.mp4
https://www.dropbox.com/s/zou6a4j9n9...s_20140809.mp4
One suggestion on how to get the most timely radar graphics. Install an app called "RadarScope" or "Radar Pro". It's the best app out there for NEXRAD radar imagery of professional quality (free and paid for version - Iphone, Ipad, Android). I recommend the paid for version ($4.99) because it has lightning data plots. Lightning data in the U.S. is proprietary and must be accessed with a subscription (even the NWS pays for it). The Pro version also has the latest 20 frames instead of 5 (they come in every 3-10 minutes). There is no PC version... just IOS and Android. The free version is minus lightning data and shows only last 5 frames.
I've used this on the ramp just before launch to help make a decision on which way storms are moving or developing. It's also good for deciding on whether or not to disassemble. Works great on a small screen PDA phone.
Walt Rogers WX
When did the OLC rules change on submission? Tim Taylor Soaring 19 May 11th 10 05:11 PM
[igc-discuss] To change or not to change... rules ? Denis Soaring 0 February 16th 05 07:24 PM
Change the rules for the National Guard.? ArtKramr Military Aviation 91 February 23rd 04 01:48 AM
Change the rules for the National Guard.? Tarver Engineering Naval Aviation 8 February 22nd 04 07:39 PM
Contest rules for 04 Duane Eisenbeiss Soaring 5 February 3rd 04 02:11 PM
