Accident in Namibia, SH Ventus 2cxm
Old February 5th 16, 03:23 AM posted to rec.aviation.soaring
Default Accident in Namibia, SH Ventus 2cxm
Standard equipment for flight testing of aircraft:
http://www.airborne-sys.com/pages/vi...covery-systems
On Thursday, February 4, 2016 at 6:51:48 PM UTC-8, son_of_flubber wrote:
I was aware of the chute used for landing on Libelle. So you think a similar chute mechanism could be used during spin/spiral dive recovery.
Old February 5th 16, 03:25 AM posted to rec.aviation.soaring
JS
On Thursday, February 4, 2016 at 11:02:14 AM UTC-5, Bruce Hoult wrote:
On Thursday, February 4, 2016 at 6:32:26 PM UTC+3, son_of_flubber wrote:
On Thursday, February 4, 2016 at 3:32:51 AM UTC-5, Surge wrote:
One wonders if the inclusion of a tail parachute would have been a better option on these slippery open class ships with tricky recovery envelopes?
You would need a reliable means to jettison the chute at the right moment.
Like the blue knob low on the right hand cockpit wall in my glider here, you mean?
http://hoult.org/bruce/gliding/sasha/sasha-Images/3.jpg.
First stop deploys the chute. Zig right and all the way forward to jettison it.
Shouldn't this move to another thread?
Old February 4th 16, 09:08 PM posted to rec.aviation.soaring
Sounds like a good idea.
As an aside, I have many chute only landings in an Elfe S-3 and a Libelle 301. Besides being great pattern & speed control practice (I slip around the pattern from downwind through final until I'm at about 50ft before deploying the chute) its a hell of a lot of fun!
Accidental or unreliable deployment issues aside, a drag chute could probably be used to recover from a spin or spiral dive without exceeding Vne.
For example the Nimbus 2 has a terminal velocity in a vertical dive of 200 to 220 km/h (108 to 119 knots) with the tail chute deployed, air brakes and landing gear extended. So assuming one popped the chute within a couple of seconds (giving extra time to extend air brakes and lower the landing gear) the glider would be able to exit the spin/spiral vertically and then gently pull out of the dive without breaking anything in the process.
Is this a crazy idea or feasible?
Old February 5th 16, 04:03 AM posted to rec.aviation.soaring
Mike Schumann[_2_]
Another option that would cover a broader range of potential disasters is the installation of a ballistic recovery chute.
Old February 7th 16, 01:55 PM posted to rec.aviation.soaring
With the sailplane departing form controlled flight and then accelerating at a high rate I wonder if the pilot would remember to actuate the chute. The critical part happens very quickly and is disorienting. Some would want to try to save it to avoid having to lose the chute.
That said it might be very useful after the wings are pulled off by making the projectile more stable and buying exit time.
FWIW
UH
Namibia - Bitterwasser rhwoody Soaring 4 March 2nd 11 09:33 PM
Ventus 2cxM Solo 2625 01 EGT Installation Chris Woolley Soaring 2 April 4th 08 04:09 AM
Gliding in Namibia Ian Johnston Soaring 13 April 29th 06 07:01 AM
[PICTURES] NAMIBIA Frederic FUCHS Soaring 6 January 13th 06 02:58 PM
Flying In namibia tom Piloting 1 March 22nd 05 07:07 PM
