Oups - I take back my first remark.
-- Bert Willing ASW20 "TW" a écrit dans le message de news: ... Sorry Marty. I type at warp speed and don't always leave a name at the end. For 17 years my contest ID was 59, thus the yahoo address. And perhaps as a frequent contributor to the group, I've let my ego swell to the point that I figure others will recognize me by content or style. Chris O'Callaghan Ventus 2bx -- Oscar Charlie Frederick, Maryland Member of the Mid-Atlantic Soaring Association |
OK. I think this thread has served its purpose, at least for me. It
looks like the key may be centered on "coordination." Might I suggest to active instructors that you try my exercise and report back: coordinated turn to a heading that establishes ground track as you would at altitude, the entry and recovery from a slip to demonstrate gear alignment and return to wings level coordinated flight. You might preface this with a forward slip demonstration in light winds and comment on the misalignment of the gear with the runway and the need to align before touch down. When might this misalignment be useful? Let the student mull that over... then start talking about crosswind navigation and see if he makes the connection. I'm checking out for the next week. If someone has an epiphany, please copy me back channel. Cheers, Chris O'Callaghan |
is that Zeb?
jon gogan |
At 06:00 26 February 2005, Eric Greenwell wrote:
I start using crab when I'm close to full rudder in the side-slip, which can happen in strong cross winds. The low wing still seems sufficiently high at that point, but I don't have a measurement for the angle it makes with the ground. Regardless, it's very rare that I've had to land where the height of the grass or bushes was a concern. If I routinely landed where the wing tips were over 20'-30' high grass, perhaps I'd be using a crab instead. Here's some interesting data. ASK-21's have quite a bit of dihedral and relatively stiff wings as compared to most fiberglass single place gliders. A K-21 pilot landing with the upwind wing leading edge parallel to the ground has a 3.5 degree bank. If he was foolhardy enough to touch down with the main wheel and upwind wing at the same time, he would be in a 6.5 degree bank. So it might seem reasonable to expect that a pilot proficient in side slips would therefore maybe be willing to touch down with a 5 degree bank. M Eiler |
It would appear that there has been confusion over
track and heading, I know you have susssed it Todd but others may not. If we consider the relative airflow in the horizontal, Ignoring the vertical, it is simple. With the wings level the relative airflow is straight down the fuselage, the string is in the middle. With a slipping approach the relative airflow is at an angle from the side of the lowered wing, the string will be blowing away from the lowered wing. The aircraft is balanced as you say. In both cases the track over the ground will, if we have got it right be lined up with the runway centreline/direction What puzzles me is that we fly around all day using the first method to achieve our required track, why complicate things near the ground. At 19:30 28 February 2005, T O D D P A T T I S T wrote: Why not just say that in a crosswind landing, on final, you always have to fly an upwind course through the air to achieve a ground track aligned with the runway. Always. 'J.A.M.' wrote: Because it is not true... Obviously I lack the ability to explain myself well enough to be understood. You are doing fine - better than my Spanish, which is the closest I can come to a second language :-) You see, english is not my craddle language, and I am having some trouble with it... And from other posts, as the one you don't see how a slip on base will get you a longer final, I'm afraid that we have some confusion going here about the manouever discussed. Maybe we are talking about different manouevers. Perhaps I'll try to make a diagram (one image is worth a thousand words...) and post it somewhere. Just for this one, I'll fall, though... Imagine a runway, a left crosswind, for example, and you trying to land. If your fuselage is aligned with the runway the wind will blow you to the right of the centerline. That's clear. You can turn left, into the wind, and then compensate as you say. Your nose will point left of the runway, and your ground track (velocity vector) will be aligned with the runway. Correct - we agree. At this point, your flight through the air is angled to the left of the runway to achieve the ground track carrying you straight to the runway, or as I originally wrote, you are flying 'an upwind course through the air to achieve a ground track aligned with the runway.' Or you can put the left wing down. The glider will try to turn to the left (uncoordinated), but then you, as a savvy pilot, push the right rudder to mantain the fuselage aligned with the runway. Correct. This is the upwind wing down slipping approach. The first was the level wings, nose pointed upwind, crabbing approach. Well, now we are aligned with the runway, wind wing (left) down, right rudder to mantain alignment... We are in agreement to here. the wind drift now is compensated with the lateral force produced by the banked wings. But here we disagree. The drift is not stopped by 'lateral force produced by the banked wings.' It is stopped because you are flying a course upwind. You are confused with exactly the confusion that the original poster felt was a problem. Lowering the upwind wing does not oppose the wind with a force. The force produced by the wing is countered by an opposite force produced by the fuselage that is flying at an angle to the direction of motion. The direction of motion is upwind relative to the air to achieve motion over the ground straight towards the runway. So you are not turning upwind as you suggest, Yes, you are. You suffer from the same misunderstanding that started this thread - a belief that the lowered upwind wing produces an unbalanced force. It does not.. You can see that by considering that you can fly straight towards the runway in a slip when there is no crosswind, only by pointing the fuselage to the side. When slipping the direction you are going through the air is never aligned with the fuselage. and your ground track is aligned with the runway. Voila!!! Think carefully again. When you are closer to the ground as to concern you, reduce the bank and the rudder as fit. It'll be for a few seconds anyway. I've used this technique many times. So have I. It is not the technique that is wrong, just your understanding of the aerodynamics. I have also induced severe slips to augment my descent rate and make for steeper approaches into short fields (outlandings) and with obstacles. And when you did that, you should have noticed that your nose was pointed to the side of the direction you were actually traveling. Anyway it's sunny outside, I'll be flying again soon! Suggest you to do the same. It's getting closer to that time - can't wait. |
Todd P. Wrote: "Forward slips to either side are not skids. In a typical
left pattern, this would be left rudder and right aileron/wing down on base. " Just checking...but do you mean that in a left pattern, you reccomend turning to the left, then rolling the aircraft into a slip the opposite direction?? If you do, I think that is wrong. I fly most of my patterns with a more rounded base and final and if I were in a left pattern, slipping in a turn to final to the left, the rudder would be nearly neutral or slightly biased to the right, and the left wing would be down...Opposite of what you wrote... Am I confused here..?? Steve. |
Tailwheel Crosswind Landing | Piloting | 32 | December 6th 04 02:42 AM | |
Thermal right, land left | John | Soaring | 195 | April 1st 04 11:43 PM |
Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 02:56 AM |
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) | Matt Wiser | Military Aviation | 0 | December 7th 03 08:20 PM |
Dr. Jack's Wind Direction | rjciii | Soaring | 14 | October 5th 03 05:37 AM |
