Seniors Contest
Old March 13th 05, 06:03 AM
Mark James Boyd
Jamie,
Great response, and very helpful. Especially knowing that it is a
1/2 km radius circle. In the case I mentioned, a 1/2 km circle
around our metal tank is still far enough away that it doesn't
infringe on our pattern (I think). I'll need to check it again though.
I really like this remote finish idea and will ask around a bit more.
As others have pointed out, it seems to be at Contest Director discretion
here in the US how this kind of stuff is handled.
Cheers!
Mark
John Doe wrote:
Hi Mark
A control point in simply an additional turnpoint
(as opposed to a remote finish) placed next to the
airport so as to bring gliders round to finish from
a direction where an appropriate finish gate can be
provided. As per UK rules this is the usual 1/2 km
radius circle and 20k (I think) thistle. If you aren't
sure about the thistle part (I don't know if it has
an equivalent in US rules) there is a diagram on page
11 of:
http://www.gliding.co.uk/forms/competitionrules2005.pdf
For an example of Control Point use look at this
task from last years junior nationals:
http://www.lasham.org.uk/comps/natio...p?comp=b&ddate
=Saturday%2021st%20August
Lasham has a very open finish line coming in from the
west but no suitable place to locate a finish line
from the north, so each day where the task came in
from the north an aditional turn point (in this case
TP4) was added to force competitors to approach from
the west.
A glider has not finished until it has crossed
an on airfield finish line or entered the finish circle
(page 12 of the above pdf).
You mentioned the self selection of turnpoints
in the US Sports class (I assume that is similar to
our Club Class). In this case might it not be an idea
to have the provision for a mandatory turn point at
the end of the task and say 'you may select the order
of your turnpoints but your final turnpoint must be
this one'. This would seem to eliminate the whole
problem of converging gliders at low level without
necessitating the use of such a large finish cylinder
(which I have to admit I am sceptical of the value
of). There are obvious issues regarding the use of
thistles and penalty sectorsif the direction you are
approaching the airport is not fixed (in UK competitions,
the order of turns is usually fixed), but I think these
could be alleviated by the use of a simple 1k cylinder.
The idea of the thistle I believe is to allow a pilot
to round a turnpoint further out if the conditions
at the turnpoint are unfavorable, but as the control
point is very near the finish a pilot would be trying
to get to that exact location so the thistle could
be discarded at this point, leaving a 1 or 2 km radius
cylinder as the only point.
Cheers
Jamie
p.s. I have to admit that on that day during the Juniors
I forgot about the conrol point and went straight for
the finish, recording a gps landout a few k from the
airfield, d'oh!
At 18:30 11 March 2005, Mark James Boyd wrote:
Jamie,
That is exactly what I was thinking. A control point.
Yes, sort of like what we locally call an IP (initial
point)
when entering on the 45 for our normal pattern to land.
We are fortunate to have a huge metal tank maybe
50 meters
diameter that could be used as this remote 'control
point' and
is in line with the 45 entry (sort of). It is probably
3-4 km
away. At 500ft AGL in a 2-33 with a headwind this
would be a little
close, but in the L-13 or anything sexier it looks
ok.
Thanks for your post! Control point. I like that.
Is it scored as an OZ or a cylinder? Scoring as an
OZ
would take a little bit of thought, and as a cylinder,
I'd
expect it'd need to be pretty narrow to not cover the
airport.
John Doe wrote:
Mark,
I think what you are getting at is what we in the UK
call a control point, a final turnpoint that must be
rounded in the normal way, but is only maybe 5-10 km
from the airfield, each glider is a few hundred feet
(or more depending on the pilots saftey margins) up
at this point and after turning the control point,
competitors turn to the airfield and dive to a known
linear finish gate. There is generally no minimun
finish height so often the gate is crossed under 50
ft but as all competitors are coming in from a fixed
direction towards a small and clear area of land it
eliminates the vast majority of head to head at low
altitude issues and I've never seen congestion at a
control point myself (altough as my own competition
experience is rather limited I won't say it never happens).
As for non comp gliders, everywhere I've been competing
the daily briefing for non-comp pilots always stressed
the comps procedures as well as use of the radio to
ensure separation in launch, landing and finishing.
As long as the finish gate is suitably chosen to be
away from the main landing area and obstacles with
space to land after as well as an easy entry into circuit
for those with the speed to do so it can be both a
safe and an exciting way to finish without the artificial
complications of raised finish lines.
John,
Whilst some of those accidents are attributable
to finish gates, I'd certainly question your thinking
the last three.
Taking the Discus crash for example, in a Discus
(in which I have a reasonable if not spectacular amount
of time), 500' is adequate, if not totally comfortable,
for a decent enough circuit, that crash, as well as
the others, from the reports seem to be the whole 'slightly
low in the circuit leads to a poor turn leading to
a spin in' issue.
Where the blame in that lies is the topic for another
thread but that, like the other last three, does not
seem to be attributable directly to finish gate issues
as surely a pilot just making it over a 500' 1 mile
finish gate would be in exactly the same situation
as someone who has just got a few hundred feet of height
from a competition pullup?
The others seem to be 'insufficient speed, insufficient
time to recover from the spin', afaiks the same situation
as trying to scrabble over a start gate at 450' and
screwing up.
It's been said before but unfortunately you can't legislate
good judgement.
Cheers
Jamie Denton
Mark J. Boyd
Mark J. Boyd
  #62
Old March 14th 05, 08:27 PM
Papa3
My experience is th low finish line is worse in these conditions,
because the pilots are NOT being "funneled" (brought along a small
angle
sector) to a precise point: they arriving_ spread out more or less
along
the line from many different directins, including 180 degrees apart,
with some hooking the gate and doing a very non-standard pattern
entry.
I've even seen 180s after a finish, with the glider landing back into
the oncoming finishers.
Eric Greenwell
Washington State
USA
I'm still on the fence on this one, but here's my "philosophy" on
rules. I think the primary purpose of the rules should be to protect
me from you (the imperial you - not any of the current posters :-), not
to protect me from myself. With that in mind, I feel like mid-air
collision avoidance should be the primary purpose of the finishing
routine, whether it be gate or cylinder. Given my very selfish goal,
which finishing routine does a better job? I have to say that in my
first 15 years of racing using a high speed gate, I really never had
any close calls. I found the situational awareness to be relatively
manageable given good radio ettiquette and a reaonable level of
professionalism among the other competitors. I have a lot less
experience with the cylinder, but my recollection from the few that
I've flown was a slightly increased nervousness about people
approaching from numerous directions, resulting in more slumped
shoulders (ie. trying to make myself feel like a small target).
So, which finishing routine does a better job of facilitating the
avoidance of a midair?
Erik Mann
LS8-18 (P3)
  #63
Old March 14th 05, 11:16 PM
Brian Glick
John
I know you and respect your opinion, but you are wrong on this one. This was
a "relight" accident and the finish cylinder (or lack of one) would have
made no difference in this case. Sorry, but this arguement just does not
hold water this time!
"BB" wrote in message
I know it's a dead horse, but I can't help but point out that this is
exactly the sort of accident that would be a lot less frequent with a
500 foot one mile circle finish. 70-80 kts right over the center of the
airport at 51 feet is about the worst place you can be -- too much to
land straight, too little to do a pattern. 70 knots, 501 feet, one mile
out gives you a lot of time to think about what you're going to do
next. 70 knots, 300 feet, one mile out means you're not going to make
the flying finish at 500 feet, so you must roll. That decision is over,
now use the whole mile to figure out how to land.
Yes, pilots should think ahead to the pattern while also managing the
stress of a tight glide. Yes, they should decide to do a rolling
finish rather than focus entirely on the finishline and then wake up to
the fact they have to land the darn thing. But everyone knows this
advice, it's repeated over and over at the safety meetings, and we
still get a crash like this once every few years -- usually with much
worse results. A lower workload reduces the chances any of us will
screw up.
John Cochrane
BB
  #64
Old March 14th 05, 11:46 PM
Steve Leonard
Uh, Brian. The accident John was referring to was the Practice Day
accident, which was a too low, too slow for a pattern return to the
airport. One that should have become a rolling finish.
Pretty bad when we refer to not just "an accident" at a contest, but
"the first" accident at a contest, isn't it?
Steve Leonard
Brian Glick wrote:
John
This was
have
not
  #65
Old March 16th 05, 04:40 PM
Brian
Hi Andy
I can't believe I missed that thread. Anyway My FSDO will disagree with
your (or the threads) conclusion that a Low pass is Legal. They believe
it can be legal but you must approach in a manner from which a landing
may be possible.
A couple years ago they started letting all the instructors in the area
know that they were very likely to cite pilots for violation of the
FARs when doing low passes over the airport.
Primarily they were targeting many of the High performance homebuilts
we have in the area. Their aurgument was that previous cases had
determined that a fence post would constitute a Man Made
structure(Sorry they didn't tell us the specific case that determined
this) and thus operation with 500 feet of it would be a violation.
Notice that there is an exception for Take off and Landing. Basically
they wanted instructors to start warning these pilots that crossing the
Threshold at 249kts at 20 feet with the gear up was obviously not for
the purpose of Landing and the exception of this rule would not apply
and pilots could be cited for violation of FAR 91.119c
I don't know that they have actually enforced this, they may have just
been trying to reduce the number of Low passes occuring. Since they
were getting fairly regular complaints about the low passes.
Brian
CFIIG/ASEL.
Here is FAR.
=A7 91.119 Minimum safe altitudes: General.
top
Except when necessary for takeoff or landing, no person may operate an
aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency
landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or
settlement, or over any open air assembly of persons, an altitude of
1,000 feet above the highest obstacle within a horizontal radius of
2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the
surface, except over open water or sparsely populated areas. In those
cases, the aircraft may not be operated closer than 500 feet to any
person, vessel, vehicle, or structure.
  #66
Old March 16th 05, 04:45 PM
Brian
Reminds me of a comment I heard a while back from a FAA ATC Safety Rep.
it went something like this.
My Idea of playing it safe is putting another 1/2 mile spacing between
two airplanes. An F16 pilot's Idea of playing it safe is firing a
second Sidewinder in case the 1st misses.
Brian
  #67
Old March 16th 05, 05:02 PM
snoop
Give us the FAR. Thanks!
  #68
Old March 17th 05, 02:36 AM
Kilo Charlie
"Brian" wrote in message
"Primarily they were targeting many of the High performance homebuilts
this) and thus operation with 500 feet of it would be a violation."
Wow....not sure where you are but if this were enforced at any other airport
(including controlled) that I've been at in the past 34 years most of the
nations pilots would have had their tickets revoked. How about a show of
hands......is there anybody out there that has NEVER been in an aircraft
that was less than 500 feet from this definition of structure without the
intention of landing???? OK let's exclude the Volvo owners.
Casey Lenox
KC
Phoenix
  #69
Old March 17th 05, 03:50 AM
Andy Blackburn
Made
that determined
this)
struc·ture ( P ) Pronunciation Key (strkchr) n.
Something made up of a number of parts that are held
or put together in a particular way.
Maybe the fence post was attached to a building?
Thanks for the FAR
9B
2005 Region 7 Contest Paul Remde Soaring 0 August 13th 04 03:48 AM
Survival and Demise Kit; Contest Points Jim Culp Soaring 1 June 21st 04 04:35 AM
USA Double Seater Contest Thomas Knauff Soaring 1 April 13th 04 05:24 PM
30th Annual CCSC Soaring Contest Mario Crosina Soaring 0 March 17th 04 06:31 AM
2003 Air Sailing Contest pre-report synopsis Jim Price Soaring 0 July 10th 03 10:19 PM
