#61
("nrp" wrote)
The Governor of MN just signed us up for 20% alcohol over the next few years. Soon we'll be able to drink the stuff...... Yup. In Minnesota we've been at 10% ethanol blend for many years. 20% is now heading down the pipe, into our tanks. I've rebuilt a few lawn mower carbs because of that darn ethanol. http://www.msra.com/NonOxygenatedFue...st08.16.04.pdf Non-Oxygenated (Ethanol-Free) fuel availability in MN Minnesota Street Rod Association's list http://www.msra.com/ 3 gas stations in St. Paul, MN (300,000 pop.) 3 gas stations in Minneapolis, MN (400,000 pop.) About 50 gas stations throughout the Twin Cities Metro Area (3.5 million people) ALL of the other stations are what we call "outstate." (1 million people) I was down in Iowa last week. There, stations carry both good gas and the ethanol junk - your choice. In Minnesota, in the Twin Cities anyway, 95% of all gas stations sell ONLY the 10% (soon to be 20%) ethanol blend. North Dakota has consumer choice at the pump - like Iowa. In years of driving to Minot, ND (510 miles one way) we've noticed at least 10% improvement in gas mileage with good gas (non-oxygenated) vs. our usual Twin Cities 10% ethanol blend. I think the mileage improvement has been closer to 15%!! ...which is 40-60 miles every 400. Montblack |
#62
"Dave Stadt" writes:
You should be able to find airports that carry mogas that meets the STC requirements. Yes, but none in California. Plus, the gas in CA leaves the refineries already containing alcohol, so the ideas about using gas meant for farm equipment, etc., are non starters. Grumble. -jav |
#63
![]() "Javier Henderson" wrote in message ... "Dave Stadt" writes: You should be able to find airports that carry mogas that meets the STC requirements. Yes, but none in California. Plus, the gas in CA leaves the refineries already containing alcohol, so the ideas about using gas meant for farm equipment, etc., are non starters. Grumble. -jav That sucks. |
#64
nrp wrote:
The Governor of MN just signed us up for 20% alcohol over the next few years. Soon we'll be able to drink the stuff...... There is a range and max power output penalty for use of alcohol since it has only about half the energy density of pure hydrocarbon fuel. It's worse than that, nrp. Alcohol is hygroscopic. It's going to suck all the water out of the air that it can, basically destroying that tightly controlled combustion even there in the cylinder. Someone needs to tell the politicians pushing the farms subsidies that "wet wood don't burn good" -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
#65
![]() "Dave Stadt" wrote in message ... "Javier Henderson" wrote in message ... "Dave Stadt" writes: You should be able to find airports that carry mogas that meets the STC requirements. Yes, but none in California. Plus, the gas in CA leaves the refineries already containing alcohol, so the ideas about using gas meant for farm equipment, etc., are non starters. Grumble. -jav That sucks. So move! |
#66
![]() "Matt Barrow" wrote in message ... "Dave Stadt" wrote in message ... "Javier Henderson" wrote in message ... "Dave Stadt" writes: You should be able to find airports that carry mogas that meets the STC requirements. Yes, but none in California. Plus, the gas in CA leaves the refineries already containing alcohol, so the ideas about using gas meant for farm equipment, etc., are non starters. Grumble. -jav That sucks. So move! Why should I move? I can get alcohol free mogas. I taxi up and they fill my tanks. Price is only a couple of cents higher than the local filling stations. |
#67
In rec.aviation.owning nrp wrote:
: There is a range and max power output penalty for use of alcohol since : it has only about half the energy density of pure hydrocarbon fuel. Actually, it's about 10% less than that of gasoline IIRC. For automotive uses, the compression ratio of the engine can be increased to get some of that back, since the alcohol has a higher octane rating. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
#68
: It might be nice to have EAA and/or Petersen do the same seal test with 1%
: gasahol, 2% gasahol and so on over a short, moderate, and long time to see : the exact problems facing us. Whether we like it or not, gasahol is with us : to stay, at least in California. From what I've read, it's more than just seals in the fuel system. The alcohol can attack aluminum fuel tanks, IIRC. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
#69
#70
alcohol can attack aluminum fuel tanks, IIRC. Anybody had mogas issues with fiberglass wing tanks? I've got fiberglass tip tanks. No problems. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
MoGas Long Term Test: 5000 gallons and counting... | Jay Honeck | Home Built | 82 | May 19th 05 02:49 PM |
