#61
"Antoņio" wrote in message
oups.com... So would you reason that I was not required to "follow the Arrow" on the 2 mile final because the controller was, by implication, causing me to "waive laws" (bust B airspace)? I'm not really sure how many times you have to be told that the instruction to follow the Arrow in no way required you to fly through the Class B airspace. Until you understand that this is the case, any further attempt to enlighten you is likely futile. But even if your mistaken impression that the instruction required you to fly through Class B airspace was correct, the answer to your question would still be "yes, you were not required to 'follow the Arrow'". It's very simple: you say to the controller "unable", you explain why, and then you either negotiate an alternative course of action (if there is time) or you maneuver to avoid whatever is the problem (the Class B airspace in this case). You need to get over your mistaken idea that you handled the situation perfectly, and start learning about what you could have done differently. Pete |
#62
"Jose" wrote in message
m... It's not unreasonable. I've been told to turn off mode C, and if the radio is causing interference (a stuck mike comes to mind) it's a reasonable request. A person with a stuck mic cannot hear anyone tell them to turn off the radio. In any case, my hypothetical situation assumes the radios are working properly. There's no need for you to introduce new elements to the situation. It's just one example of many situations in which an instruction from ATC would be unreasonable, and there would be no penalty for refusing to comply. But if ATC says "follow the Arrow" and the Arrow then proceeds to crash into a mountainside, I don't think you'd be cited for disobeying the controller if you choose not to customize your aircraft the same way. I don't think so either. Pete |
#63
oups.com... Not so Pete... The controller told me to "follow the Arrow" . To do so *safely* (in my opinion) required I extend the downwind leg right into class B. I'm going to repeat this every time you insist on making that FALSE STATEMENT: Extending the downwind leg DID NOT require you to fly through the Class B airspace. Pete |
#64
oups.com... Yes. I believe you may have misunderstood me. I was stating that a clearance through all airspace comes automatically on IFR flight plans and using it as an analolgy to explain my point. I said "no clearance, no entry". You said "Not Not necessarilly [sic] true in other cases--such as while on an IFR flight plan." At least two people pointed out to you that the IFR clearance *is* a clearance (that's why the word "clearance" is used to describe an IFR clearance). If you are IFR and your clearance does not stipulate a route through the Class B airspace, you are still not authorized into the Class B. If you are IFR and your clearance does stipulate a route through the Class B airspace, you ARE authorized into the Class B, and the IFR clearance that so stipulated is the clearance that allowed that. In other words, no clearance, no entry. Being IFR doesn't get you out of having to have a clearance into the Class B. Pete |
#65
ups.com... You mean flight into class B for landing at BFI is not *normally* required. In this particular case I maintain it was for safe separation. Extending the downwind leg DID NOT require you to fly through the Class B airspace. Given the above is true, how do you think AIM 3-2-1d figures in? ... It's not true. Regardless, AIM 3-2-1d serves as a reminder that whatever you thought that the Class D controller's instructions told you to do, you are required to ensure that you meet the requirements for entry into the Class B airspace before doing so. Pete |
#66
![]() Peter Duniho wrote: And how does the absence of "such a provision" indicate that I should deviate from ATC instructions if I am about to enter class Bravo? I was told, "FOLLOW THE ARROW"...so I followed the Arrow. The safe timing of this action demanded that I fly a little futher downwind. You would need to deviate in order to avoid violating 91.131(a)(1). An instruction from ATC is not a free pass to violate the FARs. An instruction from ATC is often a free pass to deviate from the FAR's. I was allowed deviation from a FAR last week in my J-3 when I entered the mode C veil of Seatack. I followed ATC instructions. What more can the FAA ask of me? They can (and do) ask that as pilot in command you take final authority for the safety and legality of your flight. FAR 91.3 Which I did by extending my downwind. You named other outs earlier: A 360, an upwind crossover, a turn upwind to a go around, and other "deviations" which I was not directly told to do. To do these manuvers would have been dangerous, given the situation. First of all, the deviations are purely hypothetical. There was no reason to enter the Class B in this particular instance, so for you to get hung up over alternative methods of avoiding the Class B is a bit disingenuous. They were your offerings Pete. I simply responded to them. Surely by your own extreme solutions to the problem you can see that it was not easy. Secondly, I find it mind-boggling that you would rather fly into airspace protected specifically for the purpose of keeping you away from airliners landing at Sea-Tac airport, than to take the lesser risk and negotiate your way around the Class D airspace. None of the maneuvers I speak of are particularly dangerous, certainly not compared to flying through the final approach of an airliner. I was only about 1/2 mile off the end of the abeam point on the runway. The airspace is tight there and requires a better knowledge of the ground references than my GPS provided. I agree that in the future I should have some other solution to the problem. The mandate to stay out of Class B airspace is not simply regulatory. It is there for a reason: to keep you from being running over by airliners. For you to complain about potential safety hazards when avoiding Class B airspace as a justification for flying through Class B airspace without a clearance is just plain dumb. You think it's dumb to "complain" about the possibility of being maneuvered by ATC to a position that does not provide enough separation for safety just in order to avoid the clipping of a corner of B airspace? I'll take the busted B over a busted ass any day. Yes, I know. I sure hope I never have to follow you into BFI as you decide to do a 360 on the downwind for better spacing ! I'm guessing that if I ever did, you wouldn't even notice. There's a lot more room up there, even at Boeing Field, than you apparently think. I got a buck that says this happens everyday there. In fact, it happened to a friend of mine about 9 years ago in his 210. I think you might be simply positioning here. You should rethink these maneuvers. In my opinion, they do nothing to increase the safety in congested airspace like BFI. You just don't have time to communicate your intentions. You leave the controller with the necessity to call you up and ask, "What are you doing?". I have spent plenty of time in the pattern at Boeing Field. Yes, it's a busy airport. But there is still LOTS of room in the air. I have had several go-arounds caused by a variety of reasons, and there's lots of room above the airport to maneuver safely. Above the airport, yes. Not to the south end though...which is where I was. But I hear you and will consider other options in the future. Keep in mind that what transpired from the time I was at the end of the runway to turning base behind the Arrow (albeit a bit late) was about 30 seconds. Assuming airspeed of 90 knots, that puts you in the Class B airspace only 3/4 mile from the runway end. The only way for that to happen is for you be on a VERY wide downwind. I could have been a bit wide. I don't know the area well enough to say for sure. However, the airspace is close to the end of the runway. You would never have been able to do that this particular day without stepping on others and disrupting the whole flow. The difficulty in reporting your actions to ATC should not cause you fail to take appropriate actions. "Aviate, navigate, communicate". There's a reason the radio is the last item in that list. That formula is non-regulatory and presumes one has the time and ability to communicate. It just doesn't realistically work in all cases. I think I took appropriate actions. ATC obviously thinks it was OK because they didn't ask me to call them. Nobody, to my knowledge, was jepordized by my actions. And finally, I am attempting to refine my thinking process on the matter by laying myself out here for anyone to attack me. What more do you expect? If you are not uncomfortable flying in tight quarters, then you should have no trouble at all flying a downwind that doesn't take you into the Class B. So, which is it? Are you comfortable flying in tight quarters, or was it impossible for you to avoid the Class B while obeying the ATC instruction to extend your downwind? Only one of those two possibilities can be true. Errr...no. There are situations where either/or thinking does not apply to the reality of the situation. I am (both) not uncomfortable flying in tight quarters AND it was not possible without unusual maneuvering for me to avoid getting too close to B. (I am still not sure if I actually busted it.) BTW...ATC never told me to extend my downwind. The downwind was extended by virtue of the fact that the aircraft I was told to follow was way out there. My comment about flying tight quarters is based simply on observed facts. Your "facts" are not my facts in all cases. If you find it condescending (see below), that's your problem. Actually, it's your problem, though I doubt you recognize it as such. I didn't even say that you ARE uncomfortable, just that if you are (and thus explaining why we are even having this thread in the first place), you could seek more training. Ah yes. Sorry, I misread that "if" clause. Your condescension is unwarranted and often characteristic of your posting style. As long as we're criticizing each other for personality defects, you should probably review the five hazardous attitudes. "Anti-authority" in particular. You are so convinced that you have every right to bust the Class B, that you refuse to listen to someone trying to explain to you that there was no reason to bust the Class B in the first place, nor that you have the right to just go around violating the FARs at a whim. Oh dear. Is that what you think I am displaying here? I thought I was asking for clarification of the regs and suggestions from fellow pilots as to their opinions. I often play devils advocate to illicit a lively discussion but "anti authority"? Ah well....perhaps it's just your projection. ;-) Pete, please don't misunderstand me. I value your opinions highly as with others here that I sometimes challenge. I believe a little adversity sometimes brings out the best in us. This topic is a prime example--I have learned a great deal. Watch for the 360 and hammerhead to final in the BFI pattern during coming months. ;-) Antonio |
#67
![]() Bob Gardner wrote: Did your instructor teach you slow flight? Slowing down and hanging out some flaps would have given the Arrow plenty of room without your having to extend your downwind. That's one of the reasons maneuvering at minimum allowable airspeed is taught. Slow flight would have been good had there been time. I was abeam the end of the runway when cleared to follow the Arrow. I was in B airspace (so it seems) around 20 seconds later. BTW, the provision in the 7110.65 requiring controllers to coordinate airspace transits applies to controllers who are providing radar services. Somehow, I don't think that the BFI controller was providing radar services. BFI has radar and is separating me from other traffic, right? That is not technically "radar service"? Bob Gardner |
#68
![]() Peter Duniho wrote: It's not true. Regardless, AIM 3-2-1d serves as a reminder that whatever you thought that the Class D controller's instructions told you to do, you are required to ensure that you meet the requirements for entry into the Class B airspace before doing so. Pete How could I have done that in this case? Antonio |
#69
![]() BTIZ wrote: File what used to be NASA reports.. state what happened.. admit no guilt.. and if the tower did not say "call the tower when landing".. then you may have gotten a pass on this one.. BT Bottom line is I think I got a "pass" because it happens all the time at this airport. It is not even clear whether or not I actually busted the bravo. I just thought it would make for interesting discussion. I will file the 207 just for insurance. Thanks! Antonio |
#70
oups.com... An instruction from ATC is often a free pass to deviate from the FAR's. I was allowed deviation from a FAR last week in my J-3 when I entered the mode C veil of Seatack. No you weren't. You *complied* with the FAR that reads, in part, "Unless otherwise authorized or directed by ATC". That's assuming the J-3 was originally certified with an engine-driven electrical system (I don't recall if that's the case or not). If it wasn't, you *complied* with the part that exempts such aircraft from that regulation. Either way, ATC didn't allow any deviation from any FAR by permitting you to enter the Mode C Veil of Sea-Tac. They can (and do) ask that as pilot in command you take final authority for the safety and legality of your flight. FAR 91.3 Which I did by extending my downwind. If you deem it necessary for the safety of the flight to fly into airspace for which you were not authorized, it's true that you ought to do that as PIC. However, a) you need to declare an emergency to do so (even if it's under your breath, to be reported to ATC later), and b) if the FAA asks you for an explanation, you have to give one. If they don't like your explanation, they may cite you for a violation of the regulations. [...] I was only about 1/2 mile off the end of the abeam point on the runway. The airspace is tight there and requires a better knowledge of the ground references than my GPS provided. I agree that in the future I should have some other solution to the problem. Funny, you didn't mention the use of a GPS earlier. I will take this opportunity to point out that flying in the pattern of an airport with such a complex is a perfect example of when to NOT be relying on a GPS, and to become familiar with the ground references PRIOR to the flight. That said, assuming your GPS was performing correctly, it should have provided you with all the information you required in order to fly the downwind as far as you liked, without touching the Class B airspace. Even assuming a worst-case scenario of 300' off (and GPS is usually much better than that, especially when airborne), the half-mile plus space between the extended centerline and the Class B airspace still leaves you with over 2000' of room between you and any traffic on final. You think it's dumb to "complain" about the possibility of being maneuvered by ATC to a position that does not provide enough separation for safety just in order to avoid the clipping of a corner of B airspace? I'll take the busted B over a busted ass any day. Even though busting the Class B puts you directly in line with the airliners on final approach? A collision is undesirable, whether it happens in Class B or Class D. And just how much separation do you require anyway? There's at least a half-mile between the final approach course for 31L and the Class B airspace. So, you must want more than that. How much more? Yes, I know. I sure hope I never have to follow you into BFI as you decide to do a 360 on the downwind for better spacing ! I'm guessing that if I ever did, you wouldn't even notice. There's a lot more room up there, even at Boeing Field, than you apparently think. I got a buck that says this happens everyday there. In fact, it happened to a friend of mine about 9 years ago in his 210. I'm a bit bewildered at your statement here. I wouldn't be surprised if 360s are used for spacing at KBFI on a daily basis. But when you try to make a claim that it does, you hardly reinforce your assertion that doing so would be dangerous. If it's so dangerous, and it happens so often, why aren't there any crashes? I have spent plenty of time in the pattern at Boeing Field. Yes, it's a busy airport. But there is still LOTS of room in the air. I have had several go-arounds caused by a variety of reasons, and there's lots of room above the airport to maneuver safely. Above the airport, yes. Not to the south end though...which is where I was. The air is just as clear south of the airport. [...] I could have been a bit wide. I don't know the area well enough to say for sure. However, the airspace is close to the end of the runway. I agree the Class B is unusually close at KBFI. But that doesn't mean that a downwind leg, even an extended one, requires flight through the Class B airspace. It just means you need to be on top of your game when you fly there. The difficulty in reporting your actions to ATC should not cause you fail to take appropriate actions. "Aviate, navigate, communicate". There's a reason the radio is the last item in that list. That formula is non-regulatory and presumes one has the time and ability to communicate. No, it doesn't. In fact, it specifically instructs you to prioritize, and to not communicate at all until you've addressed your aviation and navigation. That is, it presumes that one may NOT have the time and ability to communicate. It's true that it's non-regulatory, but it's also true that it's a well-understood mantra, and no pilot has ever been busted for flying the airplane first, and working the radio second. It just doesn't realistically work in all cases. I haven't seen or heard of a situation in which it doesn't work. Nevertheless, even if there is such a situation, this wasn't one of them. I think I took appropriate actions. ATC obviously thinks it was OK because they didn't ask me to call them. It does seem so, yes. Though, you never really told us what "appropriate actions" you took. It sounds as though you didn't really do anything other than just continue to fly your downwind (and presumably turn around and land at some point). Whatever you did, I'd agree it seems that ATC wasn't concerned (other than to make whatever comment they made on the radio, but since you didn't hear that clearly and didn't tell ATC you didn't hear that clearly, we don't really know what that comment was). Nobody, to my knowledge, was jepordized by my actions. It does seem so, yes. Though, you might consider your own pilot certificate in assessing whether anyone was jepoardized. It doesn't sound as though any metal got close to running into any other metal, but flying through the Class B without a clearance isn't good for the safety of that piece of paper you've got (or maybe you have the plastic one). And finally, I am attempting to refine my thinking process on the matter by laying myself out here for anyone to attack me. What more do you expect? I expect for you to acknowledge the information provided, rather than to insist that you already know the answer. In particular, when someone tells you that flying an extended downwind leg there doesn't require you to fly through the Class B airspace, you ought to seriously consider listening to that statement. When a second person says the exact same thing, you might start thinking there might be something to it. No one has attacked you, by the way. But every time you make a false statement, you prompt someone else to correct that false statement. That's how it works around here. Errr...no. There are situations where either/or thinking does not apply to the reality of the situation. I am (both) not uncomfortable flying in tight quarters AND it was not possible without unusual maneuvering for me to avoid getting too close to B. (I am still not sure if I actually busted it.) There you go again, with the false statements. No unusual maneuvering was required for you to avoid the Class B. Or, if you prefer, no maneuvering that would be considered unusual by someone comfortable flying in tight quarters was required. There is a LOT of room, relative to the size of even the largest airplane, between the final approach course for 31L and the Class B airspace. BTW...ATC never told me to extend my downwind. The downwind was extended by virtue of the fact that the aircraft I was told to follow was way out there. Red herring. You were given an instruction that required you to extend your downwind. There's no difference between that and an explicit instruction to extend your downwind. My comment about flying tight quarters is based simply on observed facts. Your "facts" are not my facts in all cases. I'm not sure what you mean by that, but we're not really concerned with "all cases" here. We're concerned with THIS case. Fact #1: there is over a half mile between the final approach course of 31L and the Class B airspace Fact #2: a pilot comfortable flying in tight quarters can easily negotiate a corridor over half a mile wide, using appropriate references (GPS or ground, doesn't matter). Fact #3: a pilot who believes it impossible to fly an extended downwind between the final approach course of 31L at KBFI and the Class B airspace nearby must not be comfortable flying in tight quarters. Where you fall in the above facts, I'll let you say. The conclusion remains however: it is not possible to be both comfortable flying in tight quarters, and yet not be able to extend one's left downwind to 31L at KBFI. The two are mututally exclusive of each other. Pete |
Sports class tasking | [email protected] | Soaring | 12 | April 25th 05 01:32 PM |
Class III vs. Class II medical | G. Sylvester | Piloting | 11 | February 8th 05 06:41 PM |
One Design viability? | Stewart Kissel | Soaring | 41 | December 10th 03 03:27 AM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 09:10 PM |
