Procedure turn required?
Old June 10th 05, 03:34 PM
"Steven P. McNicoll" wrote:
wrote in message ...
A feeder route is part of an IAP, and issued under Part 97 along with the
other segments of the IAP.
Not according to the Pilot/Controller Glossary. That defines the four
segments of an instrument approach procedure as initial, intermediate,
final, and missed. I can't find "feeder route" anywhere in Part 97.
As a matter of definition a feeder route is not a segment of an IAP (but if it
looks like a duck, walks like a duck, and quacks like a duck...). As a matter
of regulation, it is a component of an IAP, which is by procedure design an
evaluated and designed segment, just like the four set forth in the definition.
Further, you can find it on any Part 97-issued Form 8260 -3 or -5 that has a
feeder route and you can find it in TERPs Paragraph 220:
220. FEEDER ROUTES. When the IAF is part of the enroute structure there may be
no need to designate additional routes for aircraft to proceed to the IAF. In
some cases, however, it is necessary to designate feeder routes from the
enroute structure to the IAF. Only those feeder routes which provide an
operational advantage shall be established and published. These should coincide
with the local air traffic flow. The length of the feeder route shall not
exceed the operational service volume of the facilities which provide
navigational guidance unless additional frequency protection is provided.
Enroute airway obstacle clearance criteria shall apply to feeder routes. The
minimum altitude established on feeder routes shall not be less than the
altitude established at the IAF.
  #62
Old June 10th 05, 03:39 PM
Steven P. McNicoll
Filing to WILMA would not be appropriate because, although it's a feeder
fix for this approach, it is short of destination.
He didn't suggest filing to WILMA, he suggested filing WILMA as the last fix
on the route.
  #63
Old June 10th 05, 04:00 PM
Roy Smith
I think the looks like a duck comment is exactly right. If I were a
terpster, I would worry about that stuff. As a pilot, all I need to
worry about is where I'm going next and how low I can be while I'm
going there. If somebody else wants to split hairs about what to call
the segment I'm on, it's no skin off my teeth.
  #64
Old June 10th 05, 04:11 PM
In 1967 when TERPs replaced the former IAP criteria from 1956 (and before) one of
the principles was that the procedures would be simple to understand and fly so
that pilots could safety and with "simplicity" remain within the airspace designed
by the procedures folks.
When you look at some of the missed approach procedures, though, you have to
wonder.
  #65
Old June 10th 05, 04:13 PM
on the route.
That doesn't make sense in that airspace since the SLI VOR is the fix/facility
closest to the airport from that direction.
  #66
Old June 10th 05, 04:45 PM
Steven P. McNicoll
fix/facility
Pilots file lots of routes that don't make sense.
  #67
Old June 10th 05, 04:51 PM
fix/facility
And, in the context of this thread, your point is?
  #68
Old June 10th 05, 04:52 PM
Steven P. McNicoll
if it looks like a duck, walks like a duck, and quacks like a duck...).
As a
matter of regulation, it is a component of an IAP, which is by procedure
design
an evaluated and designed segment, just like the four set forth in the
definition.
What regulation?
a feeder route and you can find it in TERPs Paragraph 220:
may be no need to designate additional routes for aircraft to proceed to
the IAF.
In some cases, however, it is necessary to designate feeder routes from
coincide with the local air traffic flow. The length of the feeder route
shall not
The minimum altitude established on feeder routes shall not be less than
Based on that it appears to be more closely related to enroute airways than
IAPs.
  #69
Old June 10th 05, 04:55 PM
Steven P. McNicoll
That pilots file lots of routes that don't make sense. In the context of
this thread, what point were you trying to make?
  #70
Old June 10th 05, 07:49 PM
That the clearance would be to SLI VOR, so either of the feeder fixes would
have limited, if any, application in a lost comm situation.
Procedure turn required? Yossarian Piloting 85 July 6th 05 08:12 PM
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 11 April 20th 04 02:17 AM
