light twins?
Old August 7th 05, 10:43 PM
Morgans
"Ernest Christley" wrote
You don't listen to or read the work of others, and you like to read
your own writing way to much.
It's called "The world according to Arnaut."
Ain't it grand? chuckle
  #62
Old August 8th 05, 12:01 AM
Richard Lamb
Very impressive, Gordon.
Probably the most understandable description of harmonics and
resonance, and how they can destroy stuff that I've ever seen here.
Thanks
Richard
  #63
Old August 8th 05, 04:35 AM
Bashir
Gordon Arnaut wrote:
So more stiffness equals a
lower resonating frequency.
Do you want to think that one through again, Gordon?
  #64
Old August 8th 05, 04:52 AM
Gordon Arnaut
Thanks for pointing out my typo.
As stiffness increases so does the frequency at which it resonates, as we
see on a taut guitar string, or drum, which increase in pitch as they are
tightened.
Regards,
Gordon.
"Bashir" wrote in message
  #65
Old August 8th 05, 05:00 AM
Gordon Arnaut
Jim,
Yes there is some confusion between a harmonic balancer and damper, but the
device I'm referring to uses an elastomer tuned to a specific frequency to
clip harmonic resonance.
This has nothing to do with balance, which can be addressed in the ways you
mentioned -- counterweights, balance shafts, etc. An engine can make a lot
of vibration and shaking (up and down and side to side) and not have a
problem with torsional resonance.
The opposite is true too -- a very smooth engine can all of a sudden break
its torque shaft from torsional resonance. That's why torsional resonance is
known as the silent killer.
Regards,
Gordon.
"Jim Carriere" wrote in message
For example, most V-8 engines come with a harmonic balancer, even though
they have four power pulses for each crankshaft rotation. That's because
there is enough flex in the crankshaft that the crank can begin to
resonate at some rpm within the operational range.
Actually, V-8s have a harmonic balancer because they would otherwise have
a first order imbalance. The physics explanation is pretty long and
doesn't make a lot of sense anyway, but it's because the crankpins are 90
degrees apart (inline fours don't have this imbalance because the pins are
in pairs 180 degrees apart, but they have second order imbalance
instead... that is what a pair of balance shafts cures) and the mass on
the ends of those crankpins (rods and pistons) flinging around are at
different distances along the crankshaft. Also, the harmonic balancer on
a V-8 is two weights, one on each end of the crankshaft. A lot of people
don't realize there are two weights, not just the one on the front of the
engine.
Harmonic dampers are a different animal. They will smooth out power
pulses on any engine configuration. Harmonic balancers have nothing to do
with power pulses and everything to do with complicated vibration of large
pieces of metal moving back and forth in different directions and
different places.
I think the terms balancer and damper are confused with each other because
they look almost the same- a big part attached to the front of the
crankshaft to make the engine smoother.
  #66
Old August 8th 05, 05:13 AM
Bashir
He can be taught!! Who would have thought it!?
  #67
Old August 8th 05, 06:06 AM
Morgans
Heaven forbid you should have written that what he said was crap! chuckle
  #68
Old August 8th 05, 05:45 PM
Gordon Arnaut
Ernest,
I have read Tracy Crook's piece on torsional resonance, even before you
pointed to it.
A couple of thoughts. First, Tracy has devised a good solid gearbox that has
proven itself in service with a respectable number of flight hours.
He is absolutely correct in pointing out that the crankshaft is a spring
mass, as I have said earlier. So is the propeller, and the gear shaft of the
transmission. Any complex piece of machinery is a combination of a number of
spring masses, each with its own resonant characteristics.
But let's back up a little and try to really understand this. I don't think
my earlier explanation was completely satisfactory.
The key thing to understand first is that any object will vibrate if force
acts on it to displace it in some way. In astrophysics we know that the
biggest objects in the universe vibrate, and even the universe itself
vibrates -- and has left a trace of its vibrations as it expanded after the
big bang.
A guitar string vibrates if you displace it with a pick. An engine vibrates
from power pulses. Even an electric motor vibrates from the power pulses of
its magnets.
But vibration is not resonation. Resonation is when an object vibrates at
its particular resonant frequency, at which point the harmonics (which are
vibrations that are integer multiples of the fundamental frequency; the
second harmonic is twice the frequency of the fundamental; the third is
trhree times, etc.) build on top of one another and lead to ever greater
amplitude of the vibration (the string moves back and forth in an ever-wider
arc until it breaks).
We see this in a guitar string when it breaks unexpectedly while we are
tuning it. As we were turning the tuning knob we just happen to hit the
resonant frequency and the string suddenly hear an increae in volume (and a
much richer, almost howling sound) and the vibration of the string gets
visibly bigger unti it snaps.
But if you just try to break that string by turning the knob tighter while
keeping the string perfectly still, you would be surprised how much force it
would take to snap that string in tension. On thicker strings, like on a
bass, you would not have enough strength in your hand to do it, despite the
help from the mechanical advantage of the gear knob.
It's the same thing with a crankshaft, except that the vibration is a
twisting back and forth of the shaft, rather than a swinging side to side
like on a string or a tuning fork.
That crankshaft is going to be vibrating with every power pulse because each
power pulse exterts a force on the lever arm of the crankpin which causes a
twisting of the shaft. And in the split second after the power pulse
subsides, the shaft will swing back twisting back beyond neutral -- just
like a guitar string when you displace it swings to both sides of its
neutral axis as it vibrates.
So the crankshaft will be flexing and vibrating at all times when the engine
is running. Is this bad? No. This has nothing to do with resonance.
Yet this is where all the confusion comes in. An earlier poster pointed out
that V-8 engines use balancers in order to smooth out imbalances and lessen
vibration and shaking. This is desirable because we would all rather have an
engine or any piece of equipment that vibrates less not more.
But this does nothing to address the problem of resonance.
So what causes the crankshaft to get to the point where it starts
resonating? Well, just like our guitar string it needs to be displaced with
enough force and in the right way -- force applied at just the right number
of times per second, or its frequency. Once this is accomplished, the
crankshaft will begin to resonate. It will literally ring like a bell, with
the harmonic notes all coming out and all of them joining together to cause
the amplitude of the vibration to intensify (the crank will begin to twist
back and forth in a wider and wider arc, just like the guitar string going
berserk.)
At some point, the crank cannot twist anymore and it will break.
Now if we were concerned about avoiding this situation how would we proceed?
Well, we know that an object's resonant frequency is related to its mass. If
we make a bigger crankshaft it will resonate at a lower frequency, hoepfully
below the actual operating rpm of the engine.
But this isn't alway possible. Another approach is to make that shaft
stiffer, which will actually increase the shaft's resonant frequency, but
also has a much more important benefit. It now takes much more force to
displace it, or bend it from its neutral axis.
Think of a very thick bass guitar string that is tightened as tight as you
can get it. Now try to pluck that string. You can't get it to vibrate,
because you don't have enough force in your finger to displace it far enough
from its neutral axis that it will vibrate.
So if you can make the crankshaft stiffer, it will take more force to cause
vibration, perhaps more force than the power pulses of the engine will
produce and then resonance can never set in.
So the engine manufacturers do take this into consideration and design
crankshafts that will not fail from resonance. So what's the problem?
Well the problem is when we go to attach something to the engine. And engine
isn't much good unless it is hooked up to something and doing something
useful -- like driving a propeller.
And that's where things get complicated, because now we are adding another
spring mass to the system. We now have two possible problems, either the
engine can set the propeller into resonance, or the propeller can set the
crankshaft into resonance.
And we haven't even got to the gearbox yet. Just the prop and engine is
enough of a problem that each engine and prop must be tested and certified
as a combination. You can't just bolt on any certified prop any certified
engine.
This is also why we see homebuilt aircraft breaking crankshafts or props.
So now when we add a gearbox too, we have multiplied the possible scenarios
that can go wrong. Both the crankshaft and prop are vibrating springs, with
the gearbox in the middle.
What is required is a design approach similar to the powertrain approach
used in auto industry.
However, very few people in the homebuilding community are trained in the
nuances of this particular discipline (including me). So we have people of
various technical abilities trying to tackle this problem in a bootstrap,
eyball engineering kind of way.
For example, Crook talks in his article about how springs in a clutch plate
do not work satisfactorily becuase they would be tuned for only one
frequency, while the engine oeprates over a wide range.
Yes, this is true if you are concerned about elimintaing the harshness of
everyday vibration. But if you want to stop resonance, then all you need to
do is exactly that -- tune the damping device for that one frequency.
Here again we see the issue of harshness and vibration clouding the issue of
resonance.
In any case, it is not an easy problem and the automakers have a lot fo very
thoruoghly trained people working out drivetrain issues for every new
combination of engine and drivetrain -- and they don't even have a prop at
the other end.
Regards,
Gordon.
"Ernest Christley" wrote in message
.com...
Ernest,
You are right that springs and elastomers do not technically dampen
kinetic energy, they simply store and relase it at a later time (how much
later depends on the frequency at which it is tuned).
However, both springs and elastomers can achieve our objective of
clipping of destructive harmonics if they are tuned to the resonant
frequency of the object that we want to protect from resonance.
You don't listen to or read the work of others, and you like to read your
http://rotaryaviation.com/PSRU%20Zen%20Part%202.html
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
  #69
Old August 8th 05, 08:16 PM
Gordon Arnaut
Just a quick additional note to clarify my point about stiffness.
Stiffness is a restraining force that acts against an excitation force -- as
we see in the taut guitar string. Mass and damping are also restraining
forces.
So it is not just that it takes more force to displace a stiff object enough
to set it to vibrating -- it is technically correct to think of stiffness as
a restraining force.
Also, since we are talking about excitation versus restraint it should be
noted that most discussions of torsional resonance fixate on the engine
power pulses as a source of exciation.
This is quite erroneous because as soon as we add a propeller we have an
object with a very large moment arm and hence inertial mass that can -- and
does -- produce very powerful excitation.
The gearbox itself can also be a source of excitation because it too has
inertia and mass, although far less than a propeller.
Another source of excitation is imbalance. We see this in the
non-counterweighted Lycoming engine in which this imbalance creates enough
of an excitation that, when combined with the excitation of a propeller can
set the crank into resonance, resulting in a broken crank.
It should be added that no piston engine is perfectly balanced. That's why
even a V-8 needs a balancer. On an opposed engine, the opppoosing cylinders
do not balance each other perfectly either because they are not operating on
the same plane. The result is a rocking couple and second order imbalance.
Apparently this is where the rotary has a big advantage because it can be
brought into perfect dynamic balance.
But the important thng to remember is that imbalance is just one of the
excitation forces that can contribute to resonance -- although not usually
in a big way.
Also, it is useful to remember that if you add a gearbox to the engine, the
concern will be with excitations coming from both the engine and prop and
setting a gear shaft into resonance. This is why redrives have such a dismal
record.
Regards,
Gordon.
"Gordon Arnaut" wrote in message
Ernest,
pointed to it.
has proven itself in service with a respectable number of flight hours.
the transmission. Any complex piece of machinery is a combination of a
number of spring masses, each with its own resonant characteristics.
think my earlier explanation was completely satisfactory.
the big bang.
vibrates from power pulses. Even an electric motor vibrates from the power
pulses of its magnets.
ever-wider arc until it breaks).
a much richer, almost howling sound) and the vibration of the string gets
it would take to snap that string in tension. On thicker strings, like on
a bass, you would not have enough strength in your hand to do it, despite
the help from the mechanical advantage of the gear knob.
each power pulse exterts a force on the lever arm of the crankpin which
causes a twisting of the shaft. And in the split second after the power
pulse subsides, the shaft will swing back twisting back beyond neutral --
just like a guitar string when you displace it swings to both sides of its
engine is running. Is this bad? No. This has nothing to do with resonance.
out that V-8 engines use balancers in order to smooth out imbalances and
lessen vibration and shaking. This is desirable because we would all
rather have an engine or any piece of equipment that vibrates less not
more.
with enough force and in the right way -- force applied at just the right
number of times per second, or its frequency. Once this is accomplished,
the crankshaft will begin to resonate. It will literally ring like a bell,
with the harmonic notes all coming out and all of them joining together to
cause the amplitude of the vibration to intensify (the crank will begin to
twist back and forth in a wider and wider arc, just like the guitar string
going berserk.)
proceed? Well, we know that an object's resonant frequency is related to
its mass. If we make a bigger crankshaft it will resonate at a lower
frequency, hoepfully below the actual operating rpm of the engine.
enough from its neutral axis that it will vibrate.
cause vibration, perhaps more force than the power pulses of the engine
will produce and then resonance can never set in.
engine isn't much good unless it is hooked up to something and doing
something useful -- like driving a propeller.
engine.
scenarios that can go wrong. Both the crankshaft and prop are vibrating
springs, with the gearbox in the middle.
plate do not work satisfactorily becuase they would be tuned for only one
to do is exactly that -- tune the damping device for that one frequency.
of resonance.
very thoruoghly trained people working out drivetrain issues for every new
the other end.
Regards,
Gordon.
.com...
Ernest,
much later depends on the frequency at which it is tuned).
  #70
Old August 9th 05, 01:53 AM
Richard Lamb
Well, MY last post on this subject was accused of being pornography...
Some people have NO sense of humor
Richard
Diesel aircraft engines and are the light jets pushing out the twins? Dude Owning 5 October 7th 04 04:14 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 01:07 PM
Light Twins - Again - Why is the insurance so high? Doodybutch Owning 7 February 11th 04 09:13 PM
Light Twins. How soft??? Montblack Owning 19 December 3rd 03 11:38 PM
Light Twins. How soft??? Montblack Piloting 19 December 3rd 03 11:38 PM
