As I write this at 4:50 pm pacific time, there is a Jet
Blue A320 circling with a nose gear problem. It's rotated 90 degrees. The news is carrying live video of the plane, but details aren't fixed. It may be landing at Long Beach or LAX. It was bound for JFK from Burbank so it has several hours of fuel on board. There's talk about dumping fuel or burning it off, but again the reports aren't clear. Jet Blue flight 292. Oh, and the talking heads are really a laugh. "So I take it the nose gear on all big jets can turn?" duh....how do you think they steer? Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Sed quis custodiet ipsos Custodes? |
"Skywise" wrote in message
... As I write this at 4:50 pm pacific time, there is a Jet Blue A320 circling with a nose gear problem. It's rotated 90 degrees. The news is carrying live video of the plane, but details aren't fixed. It may be landing at Long Beach or LAX. It was bound for JFK from Burbank so it has several hours of fuel on board. There's talk about dumping fuel or burning it off, but again the reports aren't clear. Jet Blue flight 292. Oh, and the talking heads are really a laugh. "So I take it the nose gear on all big jets can turn?" duh....how do you think they steer? Brian KABC is streaming it to the web live... |
Jay Beckman wrote:
KABC is streaming it to the web live... Thanks for the heads up, this was a great resource at work. |
One of the talking heads just said they will foam the runway. I
thought that introduced more problems then it solved for a situation like this. My dad said he heard someone on Fox say something about a "soft tail" landing, I wonder if perhaps they meant 'soft field' landing where they hold the nose off the ground as long as possible. Ben Hallert PP-ASEL |
"Ben Hallert" wrote in news:1127347757.850538.311870
@g49g2000cwa.googlegroups.com: One of the talking heads just said they will foam the runway. I thought that introduced more problems then it solved for a situation like this. My dad said he heard someone on Fox say something about a "soft tail" landing, I wonder if perhaps they meant 'soft field' landing where they hold the nose off the ground as long as possible. Ben Hallert PP-ASEL I'm watching ch 7 (KABC) and they're saying 'soft field'. BTW, it appears that they are circling to burn off fuel as the A320 cannot dump fuel. But the setting sun will be becoming a problem as time goes on as the current plan is to land at 25L at LAX, into the setting sun. Oh, and the LAPD has just gone to city wide tactical alert. A bit overkill, I think. It's not a terrorist attack. It's just a plane making a rougher landing than usual. Unless something goes drastically wrong, I think they'll pull through just fine. Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Sed quis custodiet ipsos Custodes? |
Ben Hallert wrote:
One of the talking heads just said they will foam the runway. I thought that introduced more problems then it solved for a situation like this. I just heard on KABC an interview with an official from the LA fire department, Jim Wells, who confirmed that they are not foaming the runways. The radio host must have asked him at least a dozen times, "So you're not going to foam the runway?" Wells started running low on patience, "No, we are NOT foaming the runway." Wells said that they are currently anticipating a landing around 6:05-6:10pm PT. They said they will run firetrucks along with the plane as it lands and foam the plane if necessary. |
Heh...
I cruised some channels... Some of the "Talking Heads" were having a great time with this one! Got so bad on one channel I turned the sound off for a while.... Dave On 21 Sep 2005 17:56:02 -0700, "Bucky" wrote: Ben Hallert wrote: One of the talking heads just said they will foam the runway. I thought that introduced more problems then it solved for a situation like this. I just heard on KABC an interview with an official from the LA fire department, Jim Wells, who confirmed that they are not foaming the runways. The radio host must have asked him at least a dozen times, "So you're not going to foam the runway?" Wells started running low on patience, "No, we are NOT foaming the runway." Wells said that they are currently anticipating a landing around 6:05-6:10pm PT. They said they will run firetrucks along with the plane as it lands and foam the plane if necessary. |
("Dave" wrote)
I cruised some channels... Some of the "Talking Heads" were having a great time with this one! Got so bad on one channel I turned the sound off for a while.... Dave's posts are all over the place on my screen (OE 6.0). His are the only ones that display this way, yet when I "Reply Group" they seem to clean themselves up into a [more readable] fashion (above). His posts look almost like they're 'Aligned Center.' Any thoughts? His end? My end? I'm not getting the sense it's an HTML send problem - it's maybe formatting, or something else instead. Maybe it's a special thing he has for the Tab key? Dave? On one hand you're unique. On the other, I pull my hair out when your posts show up - and I don't have much hair left. :-) Montblack |
Montblack wrote:
Dave's posts are all over the place on my screen (OE 6.0). His are the only ones that display this way, yet when I "Reply Group" they seem to clean themselves up into a [more readable] fashion (above). It's because he's using a tab at the beginning of each paragraph, like he's writing a paper or something. =) Your reader is smart enough to remove the whitespace when quoting it. |
Montblack wrote:
Any thoughts? His end? My end? His end somehow. I get the same thing using Mozilla Thunderbird as a reader. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Yet another alternator problem | Chris Kennedy | Owning | 7 | July 16th 04 04:28 PM |
Nose gear failure | Greg Esres | Owning | 12 | April 20th 04 11:03 PM |
Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 05:29 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Landing gear door operation | Elliot Wilen | Naval Aviation | 11 | July 7th 03 03:47 PM |
