#61
Roy Smith wrote On 12/03/05 08:27,:
wrote: The bean counters want to do away with primary radars, too. But, so far, the security-minded have stopped that planning. What does it mean to "do away with primary radar"? The antennae are co-located and the systems are already built. What money would be saved by turning the primary part of the system off? It's not even like they rotate on different shafts so you can save a little on lubricating the bearings or powering down the motor that makes it go round and round. That disregards maintenence and replacement costs. Anyway, if we turn off the primary radar, we'll only be able to see things that want to be seen. The libertarian in me likes that idea, but I'm enough of a realist to understand that the people intent on blowing things up are probably smart enough to turn their transponders off. In the long run, it means turning off the primary radar (or failing to replace it when it dies), on interior US radar stations, especially that cover uninteresting, open country radar areas. The ones that would stay are the ADIZ radars (which are military anyways), and city radar. That leaves a lot of radar that can be removed. Don't expect anyone to fight for the idea that Montana needs radar to keep terrorists from attacking their cow sheds. |
#62
john smith wrote On 12/03/05 11:52,:
LASER ring gyros are certainly small enough, I don't know how much they cost. If the US military can put them in artillery shells, they should be available for light GA inertial nav systems. Try looking up the price of a 3 axis FOG (Fibre Optic Gyro, the cheapest type of laser gyro). Hint: the US military has a lot of money. |
#63
Roy Smith wrote On 12/03/05 12:09,:
In article , john smith wrote: LASER ring gyros are certainly small enough, I don't know how much they cost. If the US military can put them in artillery shells, they should be available for light GA inertial nav systems. Googling for LRG prices surprisingly came up with mostly a blank, but I did come up with one doc (http://www.armadilloaerospace.com/n....ws?news_id=140) that hints at a "6 figure price" for them. That same doc, however, talks about commercially available Fiber Optic Gyros (which I don't know much about) in the $1500-$2500 price range. There is an old adage, "Sooner or later, anything made from silicon will cost $5", so I can only assume that the days of affordable solid state gyros for GA are not too far off. What do things like the Garmin G-1000 use? Those are non-TSO FOGS. The current crop of "gyros" used on the electronic displays aren't actually gyros at all. They are rate of turn accellerometers. Turns out accellerometers are dirt cheap, that IS a product that can be made (literally) on a silicon chip. They are not as accurate, but some genius figgured out how to tie them to GPS position to correct their long term drift. So, in roundabout answer to this roundabout thread, they rely on GPS, and so negate the original idea of this thread about inertial NAV as a backup to GPS. By the way. Don't expect FOGs to be cheap, or small anytime soon. These are precision wound spools of optical fibre connected to lasers. Turns out there is a minimum "bend radius" for the spool that works out to 3" or so in diameter, which means don't expect to see it show up in a 3" instrument package anytime soon. As for traditional ring gyros, you are now talking precision mirrors set up on a rigid mechanical frame with accuracy that would do a space mission proud. I.e., forgedda 'bout it. |
#64
#65
G Farris wrote On 12/04/05 02:32,:
I am aware of that, and I'm certainly not pretending to be "inventing" something here. Just seems to me that before we went whole-hog GPS we were seeing smart loran and RNAV boxes that could integrate a number of source signals. Then we threw it all away to go GPS. I think we could develop a smart interim solution using a mix of GPS, eLoran (which has come a ong way since we all turned our backs on it) and traditional graound-based nav aids. Get rid of the VOR's? Sure. Do it hastily and without forethought? That would be foolish, in my opinion. GF Because you are talking about using a single, much less reliable ground based signal to back up a system that uses dozens of redundant, much more reliable signals (higher frequency, line of sight that cannot be obscured by mountains). It amazes me that intelligent pilots can regard GPS as if it were one single station on one single frequency. This VOR = GPS thing is all in your mind. Its like saying that one walkie talky equals the entire cell phone system. |
#66
Newps wrote On 12/04/05 08:48,:
john smith wrote: Does LSA require and electrical system? No. I have yet to see a handheld transponder for GA. And you won't. The new system eliminates transponders. There has to be a transmitter of some type installed to broadcast. From: http://www.gisdevelopment.net/techno...s/ma04082c.htm You still will not see it available as a handheld system. It will have to be installed and certified in an aircraft with an approved electrical system. No, ADS-B will be available as a handheld device. I peversely agree. The FAA won't like it, but reality will make it come true, because eventually having one with you while flying an ultralight is going to be a good idea. Hell, someday they are going to put ADS-B transmitters ontop of radio towers. It will happen. |
#67
Thomas Borchert wrote On 12/05/05 04:45,:
G, The Europeans are ready to use every available argument (the threat of the US unilaterally invoking Selective Availability being their favorite) to denigrate GPS, so as to pave the way for their competing system, Galileo. They see a huge market potential in a pay-per-use system, designed to generate windfall profits for the usual group of sweetheart companies, but they are threatened by the free availability of GPS. They have to denigrate it to get funding for their system, then find regulatory means to make GPS receivers illegal. Exactly. Sadly. I'm sure the next step is to get the USA to fund it :-) |
#68
Roy Smith wrote On 12/05/05 07:01,:
G Farris wrote: The Europeans are ready to use every available argument (the threat of the US unilaterally invoking Selective Availability being their favorite) to denigrate GPS, so as to pave the way for their competing system, Galileo. I can't blame them. If I lived outside the US, I would be pretty wary about depending on a navigation system which I had no control over. It's the same battle that happening now with control of the Internet. The "battle for control of the Internet" is far more about China wanting to censor it than any freedom issue. |
#69
G Farris wrote:
I disagree. I think there is a more important problem. If you're flying direct routes and RNAV with GPS as primary(and only random route) source of navigation, in the event of a GPS signal degradation, you have a bit of a balancing act to do to get back to "legacy" navigation. If you're in the middle of the Great Plains that's no issue, but if you're shooting an approach to White Plains it may be. Wouldn't you be in the same situation if you were shooting an ILS approach and the localizer went U/S? Not at all. The missed approach is part of the procedure, and if you've done good you have it all dialled-in, briefed and ready to fly. No transitioning to do. The the missed for a GPS overlay approach uses a ground-based navaid, then you still have it dialed in and ready to go; if the missed for a ground-based-navaid approach uses the same navaid, then you still have a problem. All the best, David |
#70
I can't find the link right now, but there is an all electronic (no
spinning gyro) attitude instrument available for experimental aircraft in the $1200 range. Essentially replaces an AI or TC. Has a yaw indicator and lots of other functionality. It is square but fits in a round hole (no one makes round led screeens). Non - TSO of course. Not sure of the exact technology behind it, but it works and is not any more expensive than a traditional all electric AI. |
