#61
Running the engine too slow at startup. Apparently, the cams in some
engines get lubrication mainly from the oil splashing around inside the case. In some engines, 1000 RPM may not be sufficient for full lubrication after startup. My A&P suggested 1100 - 1200 RPM. Isn't that a stitch? Your A&P says 1000 RPM is too *slow* for proper lubrication. Jim Macklin (and many others) says it may be too *fast* to run your engine before proper lubrication has occurred. Who is right? And my A&P says 1000 RPM or slower, primarily to save your prop on loose rocks but also to ensure long engine life. Argh. Wouldn't you think there would be SOME science to this? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#62
Jay Honeck wrote:
Argh. Wouldn't you think there would be SOME science to this? If there is, it's available from Lycoming or Continental for your engine. Not from "my A&P says...." George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#63
If there is, it's available from Lycoming or Continental for your engine. Not from "my A&P says...." Well, I am blessed to have an A&P who: 1. Doesn't work on little planes cuz he needs the money. 2. Is an award-winning home builder 3. Has 40 years in the business 4. Is an accomplished pilot 5. Has rebuilt over 100 O-540s, including mine. What he says about engines is, in my world, gospel. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#64
"Jay Honeck" wrote in message news:Hxkwf.474673$084.253721@attbi_s22... Isn't that a stitch? Your A&P says 1000 RPM is too *slow* for proper lubrication. Jim Macklin (and many others) says it may be too *fast* to run your engine before proper lubrication has occurred. Who is right? Your O-540 is probably better at oil distribution than my O-235. Your engine is substantially larger and more expensive. They can afford to give it a better oiling system than exists in a smaller, cheaper engine. As for trusting Lycoming to tell us: I believe they have a commitment to safety, but they also make money from parts, like cam shafts. Adding to that, summer is much different than winter oil at startup, not to mention cylinder clearances. On startup, do you want the cylinders to wear out faster, or would you rather protect your cam? You may not be able to have both in an optimum fashion on some engines. Less RPM may help the cylinders, but leave the cam with less lubrication. It makes me wish that all cams had a direct spray oil system, and that there was an electric oil pump that could be used to lubricate the engine prior to startup. Paul Missman |
#65
all cams had a direct spray oil system, and that there was an electric oil pump that could be used to lubricate the engine prior to startup. Paul Missman You can add a pre-oiler, (at least to some aircraft). http://www.aircraftspruce.com/catalo...s/proluber.php I've read of engine modifications for spray nozzles as well but don't have time to find a link right now. ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
#66
In article .com,
"Jay Honeck" wrote: I was told ground runs is one of the worst things you can do to an airplane engine, as it was designed for sustained high RPM operations, not ground run RPMS. You know, I've heard that since Day One of ownership, too, but ya just gotta wonder if it's not yet another "old wive's tale", like so many of these "tried and true" things. How does the engine know the difference between ground runs at, say 2000 RPM (run-up speed on our plane) and an extended descent? Is *that* "bad" for the engine, too? consider the difference in cooling air. -- Bob Noel New NHL? what a joke |
#67
Ground running does not scavenge the vapors since the vent
system depends on airspeed. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jay Honeck" wrote in message oups.com... | I was told ground runs is one of the worst things you can do to an airplane | engine, as it was designed for sustained high RPM operations, not ground | run RPMS. | | You know, I've heard that since Day One of ownership, too, but ya just | gotta wonder if it's not yet another "old wive's tale", like so many of | these "tried and true" things. How does the engine know the | difference between ground runs at, say 2000 RPM (run-up speed on our | plane) and an extended descent? Is *that* "bad" for the engine, too? | | Doesn't running it for 30 minutes on the ground circulate the oil, and | prevent corrosion? Can't you get oil temps up to 150 or better (I | know, 180 is optimal, but...) with a ground run? Isn't that better | than letting it sit and rot till spring? | | I fly too often for this to really matter, but I always wonder if it's | a real issue or not? Kinda like "shock cooling" and "pulling the prop | through" before starting on a cold day... And Marvel Mystery oil, | while we're at it... | | :-) | -- | Jay Honeck | Iowa City, IA | Pathfinder N56993 | www.AlexisParkInn.com | "Your Aviation Destination" | |
#68
: Your bad lobe is one of the cam lobes that operates two lifters, so it,
: or its companion will be the first to go in a marginal lubrication : situation. The lobes depend on oil thrown from the crankshaft cheeks - : some thing that I don't think happens for a couple of minutes after a : cool start - especially with a cold engine. : It isn't a question of how quickly does the oil pump get oil get to the : cam bearings as journal bearings will retain enough oil to allow them : to be starved for a minute or two and oil gets there in a few seconds : anyway. It's quite unfortunate that the regulations make adding an oil accumulator/pre-oiler cost-prohibitive for most. Pushing 60-80psi oil from the last run into the system 30-60 seconds before hitting the starer would help a lot of this. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
#69
Jay Honeck wrote:
Running the engine too slow at startup. Apparently, the cams in some engines get lubrication mainly from the oil splashing around inside the case. In some engines, 1000 RPM may not be sufficient for full lubrication after startup. My A&P suggested 1100 - 1200 RPM. Isn't that a stitch? Your A&P says 1000 RPM is too *slow* for proper lubrication. Jim Macklin (and many others) says it may be too *fast* to run your engine before proper lubrication has occurred. Who is right? And my A&P says 1000 RPM or slower, primarily to save your prop on loose rocks but also to ensure long engine life. Argh. Wouldn't you think there would be SOME science to this? You'd think so, and maybe there is, but if so it hasn't penetrated the pilot community. Most of what you read is superstition, collective wisdom, common sense, anecdotal reports, opinion, experiments run with small sample sizes. Seems the best you can do is to read all the recommendations and try to do the things that make sense to you. It's frustrating. Dave |
#70
Jay Honeck wrote:
You know, I've heard that since Day One of ownership, too, but ya just gotta wonder if it's not yet another "old wive's tale", like so many of these "tried and true" things. How does the engine know the difference between ground runs at, say 2000 RPM (run-up speed on our plane) and an extended descent? Is *that* "bad" for the engine, too? I've wondered that myself. The only big difference that I can think of is that the circulation of cooling air will be different. As far as long descents is concerned, I've seen statements that this is harmful due to excessive cooling and possible plug fouling. Never seen a claim that oil circulation suffers, though. Doesn't running it for 30 minutes on the ground circulate the oil, and prevent corrosion? Can't you get oil temps up to 150 or better (I know, 180 is optimal, but...) with a ground run? Isn't that better than letting it sit and rot till spring? As several others have pointed out, circulation of the oil isn't the problem with the cam lobes. Those are lubricated by splash from the crank. I've never seen any claims that this differs much from splash while in flight, though. What I've read is that you really can't get the oil temperature high enough by running it on the ground. The claim is that ground running adds water and acids to the oil (flying also does this) and never gets the oil hot enough to vaporize these. Crankcase ventilation through the breather is also very poor on the ground; as a result, vapors that do form never leave the crankcase. As another poster suggested, some form of positive crankcase ventilation would probably help that. If the only real issue proves to be the buildup of pollutants in the oil from ground running, then changing the oil after every other run would take care of the problem; however, given a choice between this and simply flying the plane for a few hours, I'd be in the air. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
| Thread Tools | |
| Display Modes | |
| ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 06:20 PM |
| NASA chokes again | Jay Honeck | Piloting | 20 | May 2nd 05 02:43 AM |
| NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 06:18 PM |
| About Acellerated Courses for Private | Dudley Henriques | Piloting | 137 | July 22nd 04 05:21 AM |
| FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 08:44 PM |
