#61
![]() The oil film, when all goes well, prevents actual metal to metal contact. Just like the plain bearings on the crankshaft. I had to have my engine (Lycoming O-235) overhauled last year at less than 1/2 TBO, partially for cam pitting. Prior to my owning it, it hadn't flown too much for the past few years. Now, I'm flying every 2 weeks, at least, if weather permits, and am using Avblend. This additive is supposed to better impregnate the metal, and prevent some of this corrosion. I now have the plane in a hanger, instead of outside in the cold and added moisture. The few things I've heard about causing the problems a Flying too infrequently, with oil seeping off the cam and moisture eating at the exposed surfaces. When flying happens, not getting the oil completely hot, so as to eliminate the moisture from it. Running the engine too slow at startup. Apparently, the cams in some engines get lubrication mainly from the oil splashing around inside the case. In some engines, 1000 RPM may not be sufficient for full lubrication after startup. My A&P suggested 1100 - 1200 RPM. I'm certainly hoping that the steps I'm taking will keep the engine in good shape. I can't afford another overhaul anytime soon. Paul Missman |
#62
"Paul Missman" wrote in message
... .... The few things I've heard about causing the problems a Flying too infrequently, with oil seeping off the cam and moisture eating at the exposed surfaces. When flying happens, not getting the oil completely hot, so as to eliminate the moisture from it. That's one thing that could be changed on aircraft engines that would give a LOT of bang for the buck - positive crankcase ventilation. Huge reduction in unburned hydrocarbons (you may or may not care about that), and a lot less moisture in the crankcase - engines last a lot longer. The straight up auto style PCV valve probably wouldn't be the way to go, though. It won't get you much at higher altitudes where you have the throttle wide open. Running the engine too slow at startup. Apparently, the cams in some engines get lubrication mainly from the oil splashing around inside the case. In some engines, 1000 RPM may not be sufficient for full lubrication after startup. My A&P suggested 1100 - 1200 RPM. Anything's possible. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
#63
David Lesher wrote:
Saw a show w/ a Japanese craftsman making a sword. Two layers of different steels. Pounded it thin; folded it over; pounded... Many layers later, that was the sword... Yep, that's a very old technique. Westerners call it "Damascus steel." George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#64
Jay Honeck wrote:
Some, however, like Ray's engine, do -- and in very peculiar ways. (Just ONE cam lobe went bad?) Why? Once again. When the layer of hardened steel wears through, the rest of the lobe wears *very quickly*. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#65
George Patterson wrote:
David Lesher wrote: Saw a show w/ a Japanese craftsman making a sword. Two layers of different steels. Pounded it thin; folded it over; pounded... Many layers later, that was the sword... Yep, that's a very old technique. Westerners call it "Damascus steel." Got a knife made using that technique. Beautiful grain, sort of like a nice gun stock made with multiple layers of different wood, beautiful when carved. The Monk |
#66
engines get lubrication mainly from the oil splashing around inside the case. In some engines, 1000 RPM may not be sufficient for full lubrication after startup. My A&P suggested 1100 - 1200 RPM. Isn't that a stitch? Your A&P says 1000 RPM is too *slow* for proper lubrication. Jim Macklin (and many others) says it may be too *fast* to run your engine before proper lubrication has occurred. Who is right? And my A&P says 1000 RPM or slower, primarily to save your prop on loose rocks but also to ensure long engine life. Argh. Wouldn't you think there would be SOME science to this? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#67
![]() "Jim Macklin" wrote in message news:Wgcwf.40975$QW2.5751@dukeread08... point and then pull the mixture to shut it down. That should show a slight 25-50 rpm increase just as it shuts down since idle should be a little rich. For my TIO540-S1AD, Lycoming says five rpm, not more than ten. Stan |
#68
![]() "Happy Dog" wrote in message ... I've gone through a couple on one engine and they had those exact symptoms. One AME suggested that the front lobes wear more quickly since the cam is slightly elevated at the front so the oil drains off more quickly. There are as many theories as worn cams, it sometimes seems. Especially when you take your engine to your flight physical! :-) |
#69
Jay Honeck wrote:
Argh. Wouldn't you think there would be SOME science to this? If there is, it's available from Lycoming or Continental for your engine. Not from "my A&P says...." George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#70
I'll buy that, always best to use specific data rather than
a generic answer. It takes a pretty good eye and tach to see 5 rpm. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Stan Prevost" wrote in message ... | | "Jim Macklin" wrote in message | news:Wgcwf.40975$QW2.5751@dukeread08... | point and then pull the mixture to shut it down. That | should show a slight 25-50 rpm increase just as it shuts | down since idle should be a little rich. | | | For my TIO540-S1AD, Lycoming says five rpm, not more than ten. | | Stan | | |
Nasa Icing courses | Jim Burns | Piloting | 96 | February 1st 06 04:16 AM |
Nasa Icing courses | Jim Burns | Owning | 108 | February 1st 06 04:16 AM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 05:18 PM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
