#61
"Jay Honeck" writes:
I would go with a projector, also, but would use a DLP (digital light processor) driven projector. You want at least 2000 contrast, and 2500 lumens, I would think. Um, okay. What's a "digital light processor"? And who makes these projectors? Any idea on cost? I hadn't even considered a projector, as they always seem too dim. For presentation use the flat-panel TVs I've seen are too small; the slides are developed with the idea of showing them on a projector. Also the developer (yeah, including me) always ends up using smaller fonts than they really should on at least a few of the slides, where things weren't fitting otherwise. How bright "bright enough" is depends on how well the room can be darkened, remember. A number of companies make projectors using the "DLP" technology; they're often labeled on the projector. They tend to be brighter than other technologies in the price-range, from what I've seen. (It's a really clever idea, a chip with a bunch of really tiny mirrors that it can tilt.) -- David Dyer-Bennet, , http://www.dd-b.net/dd-b/ RKBA: http://noguns-nomoney.com/ http://www.dd-b.net/carry/ Pics: http://dd-b.lighthunters.net/ http://www.dd-b.net/dd-b/SnapshotAlbum/ Dragaera/Steven Brust: http://dragaera.info/ |
#62
![]() "Matt Whiting" wrote Jay's windowless room is close to a cave so he may be OK. Most of our conference rooms have lots of windows, but even with blinds the cheap projectors weren't very viewable. The ones we have now are quite nice, but I believe that are all in the $5000 range, maybe a little less or maybe a little more. If you are going to convince me, or someone else, to buy or not buy some type of thing, you need to use specifics. What are the contrast and lumens numbers on these "quite nice" units? Are they DLP's, singe or three chip, or are they LED or what? Any other comparisons are meaningless, without such specifications. -- Jim in NC |
#63
Dan Luke wrote:
"Jay Honeck" wrote: I'm considering installing a big-screen plasma (or LCD) TV in our meeting room at the inn, for use during presentations, etc. After almost a year of shopping and comparing, I got a 50" Panasonic plasma because it had the sharpest, highest contrast picture of any I saw. When Consumer Reports top-rated it, that sealed the deal. Hi Def is awesome. CR reported that burn-in is no longer a serious problem with plasmas, given reasonable care. At the rate display technology is advancing, I don't expect to keep it more than 5 years, anyway. I'll take it when you are done with it to save you having to cart it off to the landfill! :-) I'm still using a 20 year old CRT as one on of my TVs. Matt |
#64
Morgans wrote:
"Matt Whiting" wrote Jay's windowless room is close to a cave so he may be OK. Most of our conference rooms have lots of windows, but even with blinds the cheap projectors weren't very viewable. The ones we have now are quite nice, but I believe that are all in the $5000 range, maybe a little less or maybe a little more. If you are going to convince me, or someone else, to buy or not buy some type of thing, you need to use specifics. I'm not trying to convince you. I'm offering Jay some food for thought in response to his OP. What are the contrast and lumens numbers on these "quite nice" units? Are they DLP's, singe or three chip, or are they LED or what? The numbers are only a very small part of the equation and vary some much from maker to maker as to be largely meaningless. Also, few manufacturers report contrast using the ANSI standard which is much more realistic than the so-called on/off ratio. Unless you plan to view only all white or all black images, this is a pretty useless spec. The ANSI spec requires the projector to show both black and white simultaneously as can be the case with real images. Many projectors don't switch well from all black to all white and thus can do really well in on/off tests and miserably against the ANSI test. Any other comparisons are meaningless, without such specifications. And they are just as meaningless with the specifications as the specifications are largely meaningless. However, feel free to buy based on the manufacturers published specs if you like. It won't hurt my feelings. Here are some fairly good projectors if you look at the HD high-res ones at the top of the list. Note that the specs vary widely, yet the overall ratings aren't all that different in many cases. http://www.projectorcentral.com/home...projectors.htm |
#65
![]() "Matt Whiting" wrote: CR reported that burn-in is no longer a serious problem with plasmas, given reasonable care. At the rate display technology is advancing, I don't expect to keep it more than 5 years, anyway. I'll take it when you are done with it to save you having to cart it off to the landfill! :-) Nice try. I'll probably sell it to the same guy who's getting my 36" Toshiba CRT TV. I'm still using a 20 year old CRT as one on of my TVs. After watching the NFL and the Olympics on plasma HD, I'd hate to go back to SD. HD can spoil you quickly. Some people say the improvement is like going from B&W to color TV. I wouldn't go that far, but I will say it's a huge improvement, and the nice thing is that you don't need satellite or cable to get it from the networks in most places. -- Dan C172RG at BFM |
#66
Dan Luke wrote:
After watching the NFL and the Olympics on plasma HD, I'd hate to go back to SD. HD can spoil you quickly. Some people say the improvement is like going from B&W to color TV. I wouldn't go that far, but I will say it's a huge improvement, and the nice thing is that you don't need satellite or cable to get it from the networks in most places. That's for sure. I watched the SB at a friend's house and they had just bought a new Sony rear projection HDTV with 1080i. I think it is 52" in size, but I'm not 100% sure on that. What a difference compared to the old CRT set they had on the other side of the room. Matt |
#67
Jay Honeck wrote:
I'm considering installing a big-screen plasma (or LCD) TV in our meeting room at the inn, for use during presentations, etc. Here's one screen review that is fairly thorough and not based on the marketing specs provided by most manufacturers. http://www.audioholics.com/productre...Review_01.html Matt |
#68
from B&W to color TV. Looking at HD (1080), for the first time I can say as a filmmaker that a TV transfer captures what I shot. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#69
![]() "Matt Whiting" wrote: After watching the NFL and the Olympics on plasma HD, I'd hate to go back to SD. HD can spoil you quickly. Some people say the improvement is like going from B&W to color TV. I wouldn't go that far, but I will say it's a huge improvement, and the nice thing is that you don't need satellite or cable to get it from the networks in most places. That's for sure. I watched the SB at a friend's house and they had just bought a new Sony rear projection HDTV with 1080i. I think it is 52" in size, but I'm not 100% sure on that. What a difference compared to the old CRT set they had on the other side of the room. The SB was on ABC, so it was 720p. There's not a *lot* of apparent difference, but to me the 1080i that CBS, NBC and PBS broadcast looks superior. -- Dan C172RG at BFM |
#70
![]() Dan Luke wrote: The SB was on ABC, so it was 720p. There's not a *lot* of apparent difference, but to me the 1080i that CBS, NBC and PBS broadcast looks superior. Really? Watching the NFL HD games on Directv this year I liked the Fox broadcasts better. The ESPN games on Sunday nights were better than the CBS version also. |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
Winching: Steel vs. Plasma | Bob Johnson | Soaring | 10 | August 12th 03 05:41 PM |
