Descending through a thin icing layer
Old December 22nd 03, 03:18 AM
Judah
Exactly.
"Matthew S. Whiting" wrote in
Steven P. McNicoll wrote:
"Judah" wrote in message
Why declare an Emergency when all you really want to do is request
assistance?
Why not declare an emergency? What better way is there to get maximum
assistance than to declare an emergency?
If you need maximum assistance, I agree. If all you need is a quick
altitude change to get out of icing conditions, why declare an
emergency? Now, if I ask for a change and the answer is "standby",
then I will declare an emergency as I now need more assistance than was
offered.
Matt
  #62
Old December 22nd 03, 03:38 AM
Steven P. McNicoll
Do you declare an emergency every time you need a Vector?
No, but I certainly don't consider that a need for assistance. Do you?
I don't think it's appropriate to declare an emergency if there isn't
one.
Nor do I.
  #63
Old December 22nd 03, 03:50 PM
Dave Butler
Matthew S. Whiting wrote:
That's why I don't get myself into a situation where I'm running out of
fuel! :-) There's just no excuse for it unless, as I mentioned
earlier, it is due to a leak or something else out of your control and
that didn't get noticed quickly enough.
Hmmm. So, I'm confused. Is there an excuse, or is there no excuse?
Remove SHIRT to reply directly.
  #64
Old December 22nd 03, 04:01 PM
Michael
"Wyatt Emmerich" wrote
I would think a well trained IFR pilot could descend through 2,000 feet of
below freezing visible moisture far more safely than a VFR pilot through
non-freezing visble moisture.
I don't agreee at all.
A VFR pilot still has had 3 hours of instrument training, and ought to
have no problem at all mnaintaining wings level as he descends through
a layer for 5 minutes. Unless he screws up hideously, he ought to be
able to complete the descent safely 100% of the time.
Icing is unpredictable.
I would think in most case, the descent would just pick up a little light
ice and not affect the flight much at all.
Yes, in most cases there will only be a little ice. In some cases, it
will be a lot - and at that point, the plane will fall out of the sky
and no amount of training will help.
Michael
  #65
Old December 22nd 03, 05:22 PM
Ron Natalie
"Michael" wrote in message om...
Perhaps. If you know you are going to need to fly instruments, you can usually
handle a straight descent ok. (at least for a short time). I suspect the major
killer is the tendency to continue to look out the window into the abyss rather
than hunkering down and getting on the instruments. Then you're safe until
the leans set in.
  #66
Old December 22nd 03, 09:26 PM
Matthew S. Whiting
"Matthew S. Whiting" wrote in message
emergency?
A simple altitude change is not a request for assistance.
I guess it depends on how you define assistance.
Matt
  #67
Old December 22nd 03, 09:28 PM
Matthew S. Whiting
of fuel! :-) There's just no excuse for it unless, as I mentioned
In most cases, there is no excuse. However, there are things that can
happen that are beyond the pilots control.
Matt
  #68
Old December 23rd 03, 12:55 AM
Roger Halstead
On Mon, 22 Dec 2003 12:22:44 -0500, "Ron Natalie"
the leans set in.
Those leans are bad enough even when you are current and rated. :-))
Possibly... IF the pilot has recently had some hood time, but I think
you will find a lot of rated instrument pilots can be uncomfortable
with the idea of being "on the gauges" for 5 minutes if they haven't
had any real, or simulated instrument time in a couple of years.
In the above scenario, IF the pilot has the plane trimmed for straight
and level, then reduces the power for a straight and level descent AND
believes the gauges, AND makes no more than the necessary inputs to
keep the wings level he, or she *probably* would make it, but I'd not
want to wager more than pocket change. There are just too many things
to go wrong.
The 3 hours is minimal and without any recurrent training doesn't come
any where near preparing the pilot for real instrument conditions.
Just ask any instrument student with 3 hours of hood time how they are
doing. As it's recent, they should handle straight ahead climbs and
descents, but three hours some years back is not exactly comforting.
I have the rating, I haven't flown much in the last couple of years,
and I'm not IFR current. I am getting ready to go take a competency
check. The point is, prior to starting on the competency check, I'd
have been extremely uncomfortable with the idea of 5 minutes on the
gauges. I'd be confident I could do it, but I'd still be
uncomfortable and I have quite a few hours in actual. I had near 10
and many approaches down to minimums prior to taking the check ride.
I was far more proficient the first time I went into actual on my own
than I was just a few weeks ago, maybe even now.
I'd say a pilot who only has the 3 hours required for the PPL with no
recent hood time is a long way of being assured of completing a 5
minute descent in IMC 100% of the time.
(N833R, S# CD-2 Worlds oldest Debonair?)
www.rogerhalstead.com
Return address modified due to dumb virus checkers
  #69
Old December 23rd 03, 06:32 AM
Judah
"Steven P. McNicoll" wrote in
ink.net:
No? What is it then?
You need a vector in order to get your nose pointed in the right direction.
Maybe you are lost. Maybe you are disoriented. Maybe all your charts blew
out the window. Maybe your VORs failed.
If you didn't need assistance, you would have pointed the nose where it
belongs all by yourself... If you didn't need assistance, I would assume
you wouldn't have asked for a vector.
one.
Nor do I.
  #70
Old December 23rd 03, 10:01 PM
Steven P. McNicoll
It's a heading issued to an aircraft to provide navigational guidance by
radar.
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
Supercooled Water - More on Icing O. Sami Saydjari Instrument Flight Rules 50 December 11th 03 01:20 PM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
