#61
Student pilot does not need the tailwheel endorsement for
solo, student pilots are exempt from 61.31 because they are covered by 61.87. However a rated pilot, whether they have category and class, will require the 61.31 endorsement for solo. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Peter Duniho" wrote in message ... | "T o d d P a t t i s t" wrote in message | ... | 61.31(d) (2) is the catchall for training when a "student" | already has another rating and it "authorizes someone other | than the holder of a Student Pilot certificate to have solo | privileges in an aircraft for which they are not otherwise | qualified (rated, endorsements, etc)?" | | Actually, it's 61.31(d)(3), but close enough. ![]() some reason I just | wasn't seeing it. 61.31(d)(2) applies when the pilot is being supervised | while receiving training. | | [...] | Note the"or" in the middle. Personally, I think the correct | procedure is to make all the required signoffs before solo. | | I'm still not sure. Being shown the regulation that allows solo | endorsements for non-student pilots was helpful, but it still doesn't | address the question about whether the 61.31(i) endorsement is required for | solo in a tailwheel aircraft (for example). | | Furthermore, now I'm a bit confused as to why the solo flight | privilege/requirements section in 61.87 is needed, given that 61.31(d)(3) | exists. Not that I've ever held any misconception that the FARs are always | consistent and non-redundant, but still. It seems like a general-purpose | regulation that covers all people, regardless of what pilot certificate they | hold, would be sufficient. And 61.31(d)(3) seems to cover this to some | extent (to be more complete, a one-size-fits-all regulation would carry the | additional training requirements that would not have been covered by | whatever pilot certificate is already held, if any). | | Anyway, the bottom line here is that I'm still not seeing the resolution to | the ambiguity about whether the 61.31(i) endorsement is required for solo | flight (by a student pilot or otherwise). | | Pete | | |
#62
"Jim Macklin" wrote in message
news:s1g3g.8050$ZW3.5047@dukeread04... Student pilot does not need the tailwheel endorsement for solo, student pilots are exempt from 61.31 because they are covered by 61.87. Nothing in 61.87 exempts a student pilot from the requirements of 61.31(i) (or any other portion of 61.31, for that matter). Pete |
#63
But 61.31 exempts student pilot certificate holders.
A student pilot gets all the training and endorsements required by 61.31 as part of the 61.87 required training... (i) Additional training required for operating tailwheel airplanes. (1) Except as provided in paragraph (i)(2) of this section, no person may act as pilot in command of a tailwheel airplane unless that person has received and logged flight training from an authorized instructor in a tailwheel airplane and received an endorsement in the person's logbook from an authorized instructor who found the person proficient in the operation of a tailwheel airplane. The flight training must include at least the following maneuvers and procedures: (i) Normal and crosswind takeoffs and landings; (ii) Wheel landings (unless the manufacturer has recommended against such landings); and (iii) Go-around procedures. (2) The training and endorsement required by paragraph (i)(1) of this section is not required if the person logged pilot-in-command time in a tailwheel airplane before April 15, 1991. A pilot who has never flown and received training in a tailwheel aircraft does not have a solo endorsement for such an aircraft. A student pilot getting pre-solo train does. Making another, distinct 61.31 endorsement for a pilot who has soloed [with all the training logged and endorsed] is redundant. Making the 61.31 tailwheel [or complex] for a Student Pilot is just a belt and suspenders, it makes it easier for a later review. I have come to this slightly altered opinion while reading on this thread. If there was a tailwheel, complex, high performance and pressurized airplane that a student pilot might take initial training for solo and did solo, no further endorsement would be required by 61.31 for any of those types. But there is no law that says you cannot make a redundant endorsement as clarification. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Peter Duniho" wrote in message ... | "Jim Macklin" wrote in message | news:s1g3g.8050$ZW3.5047@dukeread04... | Student pilot does not need the tailwheel endorsement for | solo, student pilots are exempt from 61.31 because they are | covered by 61.87. | | Nothing in 61.87 exempts a student pilot from the requirements of 61.31(i) | (or any other portion of 61.31, for that matter). | | Pete | | |
#64
news ![]() But 61.31 exempts student pilot certificate holders. We have come full circle. The only person who has stated an opinion (so far) on that question is Bob Moore, and he claims that the 61.31(i) requirement is not a "rating limitation", and thus is not subject to 61.31(k). A student pilot gets all the training and endorsements required by 61.31 as part of the 61.87 required training... But the student pilot does NOT get the endorsement unless the instructor writes it. In particular, my understanding is that to meet the legal requirements for a given FAR requiring an endorsement, the endorsement must refer to that FAR. For example "so-and-so has been given the necessary training for FAR 61.31(i) and has been found qualified to operate tailwheel aircraft" (made up wording...didn't bother to look up the FAA recommended verbiage). Just because some other endorsement necessarily includes the training required by a given endorsement, I don't see any FAR that tells us that other endorsement satisfies the legal requirements of the given endorsement. 61.87 doesn't tell us that you don't need 61.31(i), and 61.31(i) doesn't tell us that 61.87 allows you to skip 61.31(i). Nor does any other portion of 61.31 tell us that 61.87 allows you to skip 61.31(i), and depending on your intepretation of "rating limitation" even 61.31(k) doesn't tell us that 61.31(i) can be ignored for student pilots. Thus, we're left with a regulation with no exceptions (61.31(i)), and which must be referenced specifically in any endorsement intended to satisfy that requirement. [...] A pilot who has never flown and received training in a tailwheel aircraft does not have a solo endorsement for such an aircraft. A student pilot getting pre-solo train does. Making another, distinct 61.31 endorsement for a pilot who has soloed [with all the training logged and endorsed] is redundant. Agreed. But there's nothing in the FARs that tells us that "redundant" implies legality. Knowing that a second endorsement (or a more complex single endorsement, referencing two different regulations) is redundant doesn't answer the question regarding whether doing that is legally required or not. [...] If there was a tailwheel, complex, high performance and pressurized airplane that a student pilot might take initial training for solo and did solo, no further endorsement would be required by 61.31 for any of those types. That claim is based on the same logic you use to claim no need for the 61.31(i) endorsement for tailwheel aircraft. If your logic is correct, then the above claim is correct as well. But we have yet to establish that the redundant endorsement is not required. But there is no law that says you cannot make a redundant endorsement as clarification. That is definitely true. ![]() Pete |
#65
![]() "Jim Macklin" wrote in message news:s1g3g.8050$ZW3.5047@dukeread04... Student pilot does not need the tailwheel endorsement for solo, student pilots are exempt from 61.31 because they are covered by 61.87. However a rated pilot, whether they have category and class, will require the 61.31 endorsement for solo. -- James H. Macklin ATP,CFI,A&P -- except for the grandfather clause... |
#66
I logged PIC in a 7KCAB before 1974 and in a complex and
high performance about the same time. I guess that's why I don't think about those dates much. Besides they are clearly printed. ".Blueskies." wrote in message . net... | | "Jim Macklin" wrote in message news:s1g3g.8050$ZW3.5047@dukeread04... | Student pilot does not need the tailwheel endorsement for | solo, student pilots are exempt from 61.31 because they are | covered by 61.87. However a rated pilot, whether they have | category and class, will require the 61.31 endorsement for | solo. | | | | -- | James H. Macklin | ATP,CFI,A&P | | -- | | | except for the grandfather clause... | | |
Tailwheel units on ebay | Victor Bravo | Home Built | 1 | July 24th 05 09:47 AM |
Tailwheel Crosswind Landing | Piloting | 32 | December 6th 04 02:42 AM | |
Advice on flying Pitts with Haigh Locking Tailwheel | Ditch | Home Built | 19 | January 4th 04 10:18 PM |
Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 01:48 PM |
