#61
"John Harper" writes:
My understanding is that the only difference between APP and NAV modes is whether the GS coupling is enabled. If the GS and dest waypoint happen to be in much the same direction you could get a long way down... Your understanding is incorrect. One of the differences between NAV and APR mode is how aggressive the a/p will be to keep the needle centered. The GS capture is not armed unless you have a localizer frequency channeled in (ie, tuned in a nav radio, and the a/p is coupled to that radio), among other things. -jav |
#62
well, whats the requirements for filing /G
Hankal wrote: because you cannot go direct with a hand held GPS Why not? I hardly ever file direct and when I do, ATC will amend the clearance. However I often hear ATC tell me to go direct. In my IFR flight plan I specify that I have a VFR GPS on board. Hank |
#63
On Fri, 18 Jun 2004 16:01:50 -0700, Jeff wrote:
because you cannot go direct with a hand held GPS, You can only file /G with an IFR certified GPS Where does it say that you have to file /G in order to go direct? Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#64
![]() "Jeff" wrote in message ... well, whats the requirements for filing /G IFR approved terminal/enroute or approach approved GPS. |
#65
![]() "Robert M. Gary" wrote: No one wants to, but you can't control everything. The reason airways are so common out West is because they include all the turns around restricted airspace and busy class B airports. If you didn't use airways, you'd have to read off 5 different turn points (for GPS direct). There are also those pesky mountains that need avoiding out west. |
#66
I tried to fly under the hood relying on just the Garmin 196 artificial
panel. It's doable, but there were pretty big deviations and I had to struggle. In real IFR in an emergency. . .I wouldn't want to be in that situation. However, it is a nice reinforcer that helps me feel more confident about my instruments in IMC. "Robert M. Gary" wrote in message om... "Julian Scarfe" wrote in message news:nKRBc.1345$I43.1315@newsfe6-win... "Robert M. Gary" wrote in message om... Some of the differing perspective in this thread are due to flying in environments with different demands. I fly in an environment in which the requirement is almost always to fly direct towards a waypoint rather than track a centerline, and which is sufficiently busy that making significant turns to make aggressive radial intercepts is going to raise some eyebrows at ATC. You fly in an environment in which the choice is to follow the airway centerlines or hit rock. All that said, airways on Garmins would be a nice feature. Well, I ordered the unit and am pretty excited about getting it. Sportys said they should have some in this week to ship. I'm really excited about putting on the hood and seeing if I can maintain the blue side up using their turn-coordinator display. I think that could be a HUGE IFR backup. It will also be cool to take the unit out when you get to your destination and use it to find your hotel. -Robert |
#67
"Wyatt Emmerich" wrote: I tried to fly under the hood relying on just the Garmin 196 artificial panel. It's doable, but there were pretty big deviations and I had to struggle. In real IFR in an emergency. . .I wouldn't want to be in that situation. However, it is a nice reinforcer that helps me feel more confident about my instruments in IMC. I've tried that experiment once (actually, my student was flying; I was just looking out the window and kibbitzing). I put us into some unusual attitudes, and he did the recoveries. He did best if he completely ignored the GPS pitch information and just used rudder inputs to achieve zero rate of turn, relying on the elevator trim to take care of pitch. The result was pretty ugly, but survivable. When he was trying to control attitude with the synthetic AI and ASI, we just got into larger and larger pitch oscillations and eventually I had to take control. |
#68
GPS gives no "pitch" information. None. Karl "Roy Smith" wrote in message ... In article , "Wyatt Emmerich" wrote: I tried to fly under the hood relying on just the Garmin 196 artificial panel. It's doable, but there were pretty big deviations and I had to struggle. In real IFR in an emergency. . .I wouldn't want to be in that situation. However, it is a nice reinforcer that helps me feel more confident about my instruments in IMC. I've tried that experiment once (actually, my student was flying; I was just looking out the window and kibbitzing). I put us into some unusual attitudes, and he did the recoveries. He did best if he completely ignored the GPS pitch information and just used rudder inputs to achieve zero rate of turn, relying on the elevator trim to take care of pitch. The result was pretty ugly, but survivable. When he was trying to control attitude with the synthetic AI and ASI, we just got into larger and larger pitch oscillations and eventually I had to take control. |
#69
"kage" wrote:
GPS gives no "pitch" information. None. Have you looked at the 196? http://www.garmin.com/products/gpsmap196/ No, it does not directly display pitch in the sense of a picture of a synthetic AI, but it does display airspeed, altitude, and vertical rate. The same sources of pitch information you have flying partial panel. My point was that if you use the synthetic airspeed (which, of course, is really groundspeed), altitude, and vertical rate and try to fly it like you would partial panel with the pitot-static instruments, you end up getting into trouble. |
#70
how are you going to get to your destination if filing direct?
Ron Rosenfeld wrote: On Fri, 18 Jun 2004 16:01:50 -0700, Jeff wrote: because you cannot go direct with a hand held GPS, You can only file /G with an IFR certified GPS Where does it say that you have to file /G in order to go direct? Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Marske Flying Wing discussion Group | mat Redsell | Home Built | 0 | September 19th 04 01:58 PM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flying Wing Design workshop in july 04 | mat Redsell | Home Built | 1 | May 5th 04 01:53 PM |
restarting instrument flying | Matthew S. Whiting | Instrument Flight Rules | 13 | November 21st 03 01:04 PM |
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan | David Megginson | Instrument Flight Rules | 0 | July 9th 03 03:04 PM |
