Missing flight plans
Old August 6th 06, 05:01 PM posted to rec.aviation.piloting
Mark Hansen
Default Missing flight plans
On 08/05/06 08:45, Anno v. Heimburg wrote:
Mark Hansen wrote:
So, you're answer is "no". Got it. Thanks,
I thought I responded to this yesterday, but I didn't see it so I'm
trying again...
Actually, had you invested 5 minutes, you would have found:
"10-2-5. EMERGENCY SITUATIONS
Consider that an aircraft emergency exists and inform the RCC or ARTCC and
alert the appropriate DF facility when:
b. There is unexpected loss of radar contact and radio communications with
any IFR or VFR aircraft.
http://www.faa.gov/ATPubs/ATC/Chp10/atc1002.html#10-2-5
Anno.
The assertion I was questioning was with regard to loss of communications
only, not communications *and* radar. Your quote above seems to cover loss
of both communications *and* radar.
What am I missing?
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
  #62
Old August 6th 06, 07:18 PM posted to rec.aviation.piloting
Anno v. Heimburg
trying again...
FWIW, I see both of them.
Your post that started this subthread went like this:
| Actually, ATC is not required to maintain communications with you, and
| if you suddenly disappear, they may assume you just went off-frequency and
| shut off your transponder (or had a power failure, etc.). I don't see why
| they would begin a search and rescue in this case.
.... which, as I read it, actually did imply a loss of both radar and com
contact ("you just went off-frequency *and* shut off your transponder",
emphasis added). You seem to have changed your point from "suddenly
disappering" to "loss of only com", and I seem to have missed that
transition.
Actually, it would make no sense to assume an emergency if only comm contact
is lost. They still have you on the radar, so you didn't crash, and you
simply might have gone off-frequeny or, at worst, gone NORDO.
  #63
Old August 6th 06, 07:38 PM posted to rec.aviation.piloting,rec.aviation.owning
Emily[_1_]
Michelle wrote:
In any case, let's hear it from the real pros (the people that get paid to
fly): How often do you conduct a flight without a flight plan?
The people who get paid to fly generally are required to fly IFR, so of
course they file flight plans. That argument makes no sense.
  #64
Old August 7th 06, 04:34 AM posted to rec.aviation.piloting
Mark Hansen
On 08/06/06 11:18, Anno v. Heimburg wrote:
trying again...
transition.
I was responding to Newps' assertion:
Yes, if the loss of comm or radar was unexpected.
Look back up the thread... It was about 5 or 6 posts up.
is lost.
That was the point I was trying to make. Sorry it wasn't clear.
Sacramento, CA
  #65
Old August 7th 06, 05:39 AM posted to rec.aviation.piloting
Jim Carter[_1_]
-----Original Message-----
Posted At: Thursday, August 03, 2006 6:49 PM
Posted To: rec.aviation.piloting
Conversation: Missing flight plans
Subject: Missing flight plans
Jim Carter wrote:
Three weeks ago, on a Saturday morning we had a plan on file, opened
with Jonesboro Radio and went trucking off merrily across the
countryside. We arrived at our destination about 2.5 later and
called to
cancel - the plan was never opened. Kind of scary...
VFR or IFR?
VFR - Unless something has changed, isn't an IFR plan is automagically
opened when you are turned over to departure or upon your first airborne
check-in with ATC?
  #66
Old August 7th 06, 02:13 PM posted to rec.aviation.piloting,rec.aviation.owning
Gig 601XL Builder
"Mark Hansen" wrote in message
On 08/04/06 16:33, Newps wrote:
Mark Hansen wrote:
Just to clarify, what I mean is can you show the regulation which states
that ATC is required to begin search and rescue operations if they lose
radio contact with an airplane that was on flight following.
Absolutely. Knock yourself out.
http://www.faa.gov/ATPubs/ATC/index.htm
I think B will be of interest.
NOTE-
1. USAF facilities are only required to notify the ARTCC.
2. The requirement to alert DF facilities may be deleted if radar contact
will be maintained throughout the duration of the emergency.
a. An emergency is declared by either:
1. The pilot.
2. Facility personnel.
3. Officials responsible for the operation of the aircraft.
c. Reports indicate it has made a forced landing, is about to do so, or its
operating efficiency is so impaired that a forced landing will be necessary.
d. Reports indicate the crew has abandoned the aircraft or is about to do
so.
e. An emergency radar beacon response is received.
NOTE-
EN ROUTE. During Stage A operation, Code 7700 causes EMRG to blink in field
E of the data block.
f. Intercept or escort aircraft services are required.
g. The need for ground rescue appears likely.
h. An Emergency Locator Transmitter (ELT) signal is heard or reported.
REFERENCE-
FAAO 7110.65, Providing Assistance, Para 10-1-3.
FAAO 7110.65, Emergency Locator Transmitter (ELT) Signals, Para 10-2-10.
  #67
Old August 7th 06, 03:07 PM posted to rec.aviation.piloting,rec.aviation.owning
Mark Hansen
But the assertion I was questioning was with regard to the loss of radio
communications only. Not coms *and* radar. Paragraph 'B' you quote (below)
is for the loss of *both* comms *and* radar contact.
NOTE-
1. The pilot.
so.
NOTE-
REFERENCE-
Sacramento, CA
  #68
Old August 7th 06, 05:56 PM posted to rec.aviation.piloting,rec.aviation.owning
Kyler Laird
Mark Hansen writes:
and if you suddenly disappear, they may assume you just went off-
frequency and shut off your transponder (or had a power failure,
etc.). I don't see why they would begin a search and rescue in
this case.
And yet they do. What's up with that?
--kyler
  #69
Old August 7th 06, 11:45 PM posted to rec.aviation.piloting,rec.aviation.owning
Emily[_1_]
Kyler Laird wrote:
Mark Hansen writes:
this case.
And yet they do.
Not always.
  #70
Old August 8th 06, 06:58 AM posted to rec.aviation.piloting,rec.aviation.owning
Anno v. Heimburg
I think I'm having a déjà-vu. Check Msg-Id
and Mark's answer to it.
But I'm glad I'm not the only one who got lost in the course of this
conversation.
Anno.
DUATS & Canadian Flight Plans Andrew Sarangan Piloting 2 November 7th 05 08:51 PM
Third Military-Civil MAC Jan. 18, 2005 Larry Dighera Piloting 37 February 14th 05 03:21 PM
Aerial PHotography Flights 'Required' to File Flight Plans C J Campbell Piloting 15 December 6th 04 02:17 PM
