#61
"Wayne Paul" wrote in message
... "Bret Ludwig" wrote in message ups.com... Wayne Paul wrote: "Bret Ludwig" wrote in message oups.com... As I pointed out, there is more to an airplane than an engine. Indeed, there are airplanes without engines. We call them sailplanes. Yes but they need towing up by an airplane that does. Bert, Here is a picture of a homebuilt Schreder HP-16T being launched using 1,500 feet of rope hooked to a pickup truck. http://www.soaridaho.com/Schreder/HP...P/N16VP_6b.jpg Local area pilots have used this technique at the Nampa, ID and Ontario, OR airports as well as from the Alvord Desert dry lake. Almost all soaring in the US is done by aero tow. Winch, vehicle and other methods are not very popular in the US but more so in Europe. Winch operation are becoming more popular in the US as fuel and insurance cost continue to escalate. I always just assumed that terrain and cost were the determining factors and that aero tow was mainly used in flat terrain. I would expect that with hills and a little wind the less costly methods would be more popular--unless the launch point was in the bottom of a valley. (This is a subject in which I lack experience, but would like to know much more.) Peter |
#62
![]() pbc76049 (removethis) wrote: wrote in message ups.com... Let's not forget that the articles that prompted this thread were about how to build a plane with at least the same performance and safety as many kit planes, but for much less money. NO.... INCORRECT........... Lets go back and READ. The thread started out talking about inexpensive wood sources and how sometimes good stuff can be had at box stores like Home Depot. RS Hoover specifically referenced his past writings on wood selection in post one of this thread. It had NOTHING to do with performance, just the use of lo buck wood. SOMEBODY morphed this into a design circular argument, but getting back on point isn't on some folks agenda. How does buying your own wood, instead of buying the wood as part of a kit, change the performance of the plane? -- FF |
#63
![]() Here is what a Honda engine can do in an airplane: http://www.firewall.ca/cam100.htm Hope this helps J.P. He has NO IDEA whether or not Honda car engines would be good or bad for airplanes. The hardcore DIY converters seem to be much more interested in the Suzuki/Geo engines, but that doesn't mean the Hondas would be bad. I have no idea what Honda engines weigh, which since they have a superior reliability record even in markets like Germany where people run them WOT for a long time (and since they are used as outboard powerheads at power settings equal or higher than in the cars, again with apparently superb reliability) would probably be the main factor. Of course, most any car engine is going to outperform a Lycoming today in terms of engine life at WOT. The Lycoming is a 1930s farm tractor engine built using WWI split crankcase, bolt on cylinder technology and belongs, really, in a museum. If it were really so great it would find many other uses besides aircraft. The military used them in generators and lifeboats and found they were cantankerous and troublesome and sensibly got rid of them. If only they had reefaged them instead of selling them surplus they would have done Experimental aviation a great favor. But I still wonder if the CVCC combustion system would be good for an airplane engine. The CVCC was a low intensity (vis-a-vis Ford PROCO, for example) stratified charge system designed primarily for emissions compliance without using catalytic converters, which were very expensive to maufacture and required unleaded gas which sold at a premium back then. (I'm old enough to remember the days of "punching" catalysts and filler restrictors to burn leaded gas at considerable savings-and satisfaction of F'ing the EPA, which we hated.) Since aircraft engines are not emissions controlled and unleaded gas is a lot cheaper than avgas, the advantage is nonexistent. CVCC was pretty troublesome, to be honest, and there were a fair number of people who converted their CVCC Hondas to the Canadian non-CVCC head and carb at some point in the car's lifecycle, particularly in areas where the cars didn't rust but which were outside emissions inspection areas-of course, most garages couldn't tell the difference anyway. |
#64
![]() Here is what a Honda engine can do in an airplane: http://www.firewall.ca/cam100.htm Hope this helps J.P. I can offer no opinion regarding the longevity at comparable power loadings. But, they do seem to be honest about the weight comparison. Peter |
#65
On 16 Aug 2006 10:43:03 -0700, "Bret Ludwig"
wrote: Roger wrote: airplane is quite a misnomer. Which is the reason why, IMHO, one should not recommend that a homebuilder use an engine that has never, or almost never flown successfully. If the homebuilder is a genuine gearhead, they'll already have their own ideas, if not, they ought to avoid breaking new ground unless or until they become one. If you aren't a "gearhead" why the hell are you thinking about BUILDING AN AIRPLANE???? It's cheaper?? It isn't. Cheaper? Are you kidding? By the time I finish the G-III (If I ever do) I'll have more than twice the price of the Deb in it and that is going with a used engine and prop. In other words you could have bought a T-6 or an L-39 when you started and they would now be worth much more than the G-III (I assume by G-III you do not mean what averyone else I know means by a G-III-a large Grumman with two turbofans used to haul VIPs and train Shuttle Any one except those that build their own airplanes. :-)) Actually I could have purchased a relatively low time, very nice L-39 with a brand new (spare) engine still in the can for what I paid for the Deb or what I have in the G-III. The T-6s were about double that price back then. As for wood I'd think, which means I don't know for sure, that pallets and shipping containers which may look rough, probably have better wood in them than the stuff we purchase to put into homes now days. The crate my G-III came in is far better wood than I can find at any of the local lumberyards except the one that mills the stuff when you order it. There is a *slight* difference in price.:-)) I should have kept the Ash tree that died in the front yard. It was out by the power lines so the power company came out, trimmed it and left me with a 20 foot tallt, stump about 2' across at the base and over a foot at the top, that must have weighed well over a ton. Man but that was some dense stuff. OTOH it's a crime to even ship, or move dead Ash from one location to another around here. (courtesy of the "Emerald Ash Borer") Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com pilots on approaches.) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#66
On Tue, 15 Aug 2006 13:03:51 -0600, "Wayne Paul"
wrote: "Bret Ludwig" wrote in message roups.com... As I pointed out, there is more to an airplane than an engine. Indeed, there are airplanes without engines. We call them sailplanes. Yes but they need towing up by an airplane that does. Bert, Here is a picture of a homebuilt Schreder HP-16T being launched using 1,500 feet of rope hooked to a pickup truck. http://www.soaridaho.com/Schreder/HP...P/N16VP_6b.jpg Good Lord, but that is one BIG photo at full resolution but it doesn't show the truck . :-)) Not too many years ago (less than 10, maybe 5) they had a sail plane operation over at Mt Pleasant MI (MOP). No tow plane and apparently not much money so they used a pickup truck, rope, and pulley arrangement for launch. The pulley was anchored down toward the departure end of the runway. This left the pickup going West while the sail plane went east. It really shortens the amount of runway needed. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Local area pilots have used this technique at the Nampa, ID and Ontario, OR airports as well as from the Alvord Desert dry lake. Wayne HP-14 N990 "6F" Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#67
This brings to mind several things about building on the cheap.
A couple years ago one of the locals who is not a pilot, but was interested in building an airplane decided to build an Emeraud. The project was a prime example of "building on the cheap". The builder has been in poor health most of his life and has only worked at a few non demanding odd jobs so he had little money. He scrounged, for just about everything and eventually ended up with a good looking airplane. He some where he found an APU with a good 125 HP engine ... Cheap! He did a very nice job of construction and I think you could probably find examples of just about everything Bob said in the original post. However when he got to the engine he didn't have the money for it even if it was cheap. So at this point he took on a partner with two things in mind. One was money for the engine and the other was a pilot who could take him for rides in his airplane. Welll... best laid plans... I've mentioned this airplane before. It's the one where the new partner had only been checked out in, I believe it was a two seat Cessna tail dragger. The Emeraud with 125 HP was a different animal. They were doing taxi tests when for some reason instead of easing in the power the new partner firewalled it. The thing went ballistic with the nose coming up higher and higher. He panicked and pulled the power instead of shoving the nose down. So what goes straight up will pretty much come straight down. Fortunately there was a slight cross wind. Very slight as it was almost calm, but it was enough. The wing had enough lift to bring the nose back up and it impacted just to the side of the runway. It hit hard enough to drive the wheels (with tires) into the ground far enough for the wing the hit the ground. The only damage to this "Flying on the Cheap", wood airplane was the gear and struts ripped off the main spar, a foot long vertical crack in the bottom fiberglass cowl, and two sets of teeth marks in the glare shield. Well, the prop was kinda short which meant the engine had to be rebuilt ... again, but the point is this was one of the "stick built", scrounged parts, "Flying on the Cheap" airplanes and it came out of the crash far better than you could have expected from a Cessna or Piper. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Wanted: VFR Safety Pilot near Milwaukee, WI - Cheap flying for you | Paul Folbrecht | Instrument Flight Rules | 9 | September 16th 04 03:25 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
the thrill of flying interview is here! | Dudley Henriques | Piloting | 0 | October 21st 03 07:41 PM |
