#61
![]() "Kyler Laird" wrote in message ... The Today Show this morning had a spot where an NTSB spokesperson said "during the takeoff roll the flight crew noted that the lights were out on the runway" then the voice over breaks in with "but the crew never applied the brakes or radioed the tower. Instead the captain called out 'rotate' telling the first officer to pull up at the appropriate speed." Was the tower active or was that comment from out of nowhere? It's a full-time tower. If it was active...well, was the plane really cleared for takeoff onto the wrong runway? No, it was cleared for takeoff on the right runway, the flight crew attempted takeoff on the wrong runway. |
#62
![]() "Ross Richardson" wrote in message ... Morgans wrote: "Ross Richardson" wrote Ross, check your settings. Is it possible that you are not posting with plain text? Did I do something wrong? I unclicked "send in HTML". My computer forgot who I was a week ago Monday and I have been resetting everything back. Some net etiquette that I was unaware of? Dunno. It was in plain text, this time. Carry on! g -- Jim in NC |
#63
"Steven P. McNicoll" writes:
If it was active...well, was the plane really cleared for takeoff onto the wrong runway? No, it was cleared for takeoff on the right runway, the flight crew attempted takeoff on the wrong runway. So...how'd it go? Ground cleared the plane to taxi to the correct runway, observed the plane go to the wrong runway, then tower cleared the plane to depart the right runway, and observed it pull onto the wrong runway. Anything like that? I hope I'm missing something obvious. Was there dense fog involved? Lots of other traffic? --kyler |
#64
![]() "Kyler Laird" wrote in message ... So...how'd it go? Ground cleared the plane to taxi to the correct runway, observed the plane go to the wrong runway, then tower cleared the plane to depart the right runway, and observed it pull onto the wrong runway. Anything like that? Probably not. The runways are not far apart. You have to taxi past the departure end of runway 26, the wrong runway, to reach the departure end of runway 22, the right runway. I believe there was just one controller in the tower. I hope I'm missing something obvious. Was there dense fog involved? Lots of other traffic? The weather observation taken about 13 minutes prior showed six miles visibility. I don't know if there was other traffic, but probably not a lot on an early weekend morning. |
#65
Depending on the tower location, the angle might not allow
seeing the error, it is even possible the end of the runway could be hidden behind a building. The controller has many duties, watching an airplane taxi is not the highest priority, getting the hand-off to Center, possible radio contact with other airplanes, many things could be required. Just looked at the airport diagram, the tower is located with a clear view of runway 22 and 26 , if there are no uncharted builds or trees. Still in the dark, lights alone do not necessarily allow determination of enough details to over come the expectation that they were on 22. "Steven P. McNicoll" wrote in message k.net... | | "Kyler Laird" wrote in message | ... | | So...how'd it go? Ground cleared the plane to taxi to the correct | runway, observed the plane go to the wrong runway, then tower cleared | the plane to depart the right runway, and observed it pull onto the | wrong runway. Anything like that? | | | Probably not. The runways are not far apart. You have to taxi past the | departure end of runway 26, the wrong runway, to reach the departure end of | runway 22, the right runway. I believe there was just one controller in the | tower. | | | | I hope I'm missing something obvious. Was there dense fog involved? | Lots of other traffic? | | | The weather observation taken about 13 minutes prior showed six miles | visibility. I don't know if there was other traffic, but probably not a lot | on an early weekend morning. | | |
#66
![]() Kyler Laird wrote: So...how'd it go? Ground cleared the plane to taxi to the correct runway, observed the plane go to the wrong runway, then tower cleared the plane to depart the right runway, and observed it pull onto the wrong runway. Anything like that? Nope. One guy in the tower. The FAA has already admitted that they broke their own rules by having only one controller staffed when the policy requires a minimum of two at all times, at all facilities. They will probably hang the tower manager as a scapegoat. |
#67
"Newps" wrote in message
... Nope. One guy in the tower. The FAA has already admitted that they broke their own rules by having only one controller staffed when the policy requires a minimum of two at all times, at all facilities. They will probably hang the tower manager as a scapegoat. Yeah, I saw that. It wasn't clear to me the policy violation had anything to do with the accident though. As the news explained it, the policy was to have a radar controller in addition to the tower controller. They also say that the tower controller was distracted doing a "traffic count". AFAIK, having a radar controller on duty wouldn't have affected that. Or is a traffic count something that the radar controller would have done? Pete |
#68
![]() "Jim Macklin" wrote in message Just looked at the airport diagram, the tower is located with a clear view of runway 22 and 26 , if there are no uncharted builds or trees. The tower, end of 22, and end of 26 are pretty much in line. I think a misposition might not be immediately obvious to the tower without a second, closer look. Also, my sense is that even when the takeoff roll had started, the angles are such that the roll might have to progress a certain distance before a discrepency would become obvious to the tower, if they were looking. |
#69
Yep, that is what I said, just because you can see, doesn't
mean you know what it is. "John Gaquin" wrote in message . .. | | "Jim Macklin" wrote in message | | Just looked at the airport diagram, the tower is located | with a clear view of runway 22 and 26 , if there are no | uncharted builds or trees. | | The tower, end of 22, and end of 26 are pretty much in line. I think a | misposition might not be immediately obvious to the tower without a second, | closer look. Also, my sense is that even when the takeoff roll had started, | the angles are such that the roll might have to progress a certain distance | before a discrepency would become obvious to the tower, if they were | looking. | | |
#70
On Tue, 29 Aug 2006 20:56:10 -0600, Newps wrote:
Nope. One guy in the tower. The FAA has already admitted that they broke their own rules by having only one controller staffed when the policy requires a minimum of two at all times, at all facilities. They will probably hang the tower manager as a scapegoat. Nawh, it'll be the PIC as always... Maybe a couple of other contributing factors, but in the end, the PIC will take the hit... As far as the FAA is concerned, it all boils down to something like, "Well, you didn't *have* to fly that day"... sick-grin |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Pilot claims no blame in July crash | Mortimer Schnerd, RN | Piloting | 48 | March 15th 06 09:00 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Doubts raised in jet crash | Dave Butler | Piloting | 8 | July 26th 05 01:25 AM |
Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 05:58 PM |
