![]() "Mxsmanic" wrote in message ... Emily writes: Really? Can you cite some statistics? I'd be very interested in reading them. Just look through accident and incident reports. Radio communication is one of the weak links in the aviation safety chain. If you're going to make the claim, point to a viable source of information. Without providing data, it is just your opinion. I have read thousands of NTSB reports and don't remember a single one where the technological limitation inherent in AM radio was a significant cause of the accident. -- Transpose mxsmanic and gmail to reach me by e-mail. KB |
Mxsmanic wrote:
Emily writes: Really? Can you cite some statistics? I'd be very interested in reading them. Just look through accident and incident reports. Radio communication is one of the weak links in the aviation safety chain. Has it ever been listed as a probable cause by the NTSB? |
![]() "Emily" wrote in message . .. Mxsmanic wrote: Emily writes: Really? Can you cite some statistics? I'd be very interested in reading them. Just look through accident and incident reports. Radio communication is one of the weak links in the aviation safety chain. Has it ever been listed as a probable cause by the NTSB? I have read thousands of NTSB reports and cannot remember one. Could be a little CRS in there but not much. |
![]() "Mxsmanic" wrote in message ... Emily writes: Really? Can you cite some statistics? I'd be very interested in reading them. Just look through accident and incident reports. Radio communication is one of the weak links in the aviation safety chain. -- Transpose mxsmanic and gmail to reach me by e-mail. I read NTSB reports every day for years. I cannot remember communications being anything more than down in the noise level as far as an accident cause and it certainly is not a leading cause of accidents. |
![]() "Mxsmanic" wrote in message ....that improper and misunderstood radio communication is a leading cause of accidents, Cite, please. ... I can barely understand what I hear on the radio. I suspect the reasons for this relate more to the environmental effects and quality of the speakers, etc., than to the nature of AM transmissions. |
On Sat, 2 Sep 2006 12:02:26 -0400, "John Gaquin"
wrote: "Mxsmanic" wrote in message ....that improper and misunderstood radio communication is a leading cause of accidents, Cite, please. ... I can barely understand what I hear on the radio. I suspect the reasons for this relate more to the environmental effects and quality of the speakers, etc., than to the nature of AM transmissions. The previous comment re capture effect of FM is valid. i.e. the strongest signal wins. This is desireable for broadcast radio but not aviation. With FM the signal remains much clearer until the point where it suddenly becomes unreadable when itl becomes weak. With AM is that readability gradually reduces as the signal gets weaker. If you open the squelch you can often still read AM when FM would be unreadable. The audio bandwidth for acceptable communication is 3KHz. When modulating an AM transmitter you have two sidebands. One up to -3KHz the other up to +3KHz so transmitted bandwidth is 6KHz. With an FM transmitter the bandwidth will still be 6KHz plus the deviation of the system. In addition the sidebands theoretically extend to infinity but they become rapidly weaker. To get the best signal to noise ratio with FM you need higher deviation. If you try increase the number of FM frequencies you need to reduce the deviation. That in turn would reduce its effectivness. As for the original comments I would suggest there's something wrong if AM is not clear. Could be poor hearing, inadequate headset, turning up the volume causing overload of either headset or receiver audio. Ignition or alternator interference distorting the received signal, poor transmitter, poor microphone, poor microphone technique. Sorry but the problem is NOT AM! |
Mxsmanic wrote:
Perhaps this is a naive question, but: Why don't voice radio communications for aviation use FM radio instead of AM radio? I realize there's substantial inertia in the installed base of AM equipment, but surely one could allocate some new frequencies to FM and use them in parallel for some years to ease the transition. If one were to mandate a replacement technology, it would be far far more effective to use the packet-based mechanisms that digital cellular phone technology and 802.11 wireless Ethernet (aka WiFi) rely on. Both these technologies turn over the job of transmission collision resolution to chip logic and take humans out of the loop. And it is possible to put audio over WiFi using Voice over IP (VoIP) technology. Such a system would be incredibly flexible. If one had, say, ten planes in the air and they all started to talk to ATC at once, a packet-based system would make it possible to do any of the following: 1) Clearly deliver only one of the voice signals to the controller and provide a visual display that indicated 9 other planes had attempted to speak also. It could even provide audio or visual feedback to the other 9 pilots that their transmissions were not delivered - or it could automatically sequence the delivery of the transmissions to the controller if the transmissions were not too lengthy. 2) If multiple controllers were available, the audio from several of the planes could be routed to multiple controllers with no impact on audio fidelity as far as the controllers or pilots are concerned. 3) Once you go packetized audio, you can put all sorts of useful stuff in the packets for presentation to the other end - such as aircraft number, the location and velocity vector from the aircraft's GPS or altimeter/DG/airspeed indicator, and so on. A pilot could key the mike and make a request without needing to ID themselves or their position - that information would be extracted from the audio packet's header and automatically presented on either a simple display to the controller or mapped to a fancy map display. The technical issues have been pretty much solved and commoditized in both the WiFi VoIP and digital cellular realms. It is my humble opinion that the radio technology currently being used for aviation communications is now less reliable and useful than even that used in home WiFi networks. Maybe someday the FAA and/or ICAO will consider replacing analog radios with a more capable digital system.... |
Jim Logajan writes:
details snipped Maybe someday the FAA and/or ICAO will consider replacing analog radios with a more capable digital system.... All very interesting, but one of the criteria that any new system would have to satisfy is that it would have to work in parallel with the existing system. Adding features to the new system that are not available in the old system would create dangerous differences between the two. Seeing fancy displays in the ATC or tower for the lucky digital users won't help deal with traffic from old AM users, and it might even confuse things enough to cause problems. A highly advanced solution would require replacing everything at once, which isn't going to happen. A simpler solution that just provides better quality audio could coexist with older systems without a problem. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Jim Logajan writes: details snipped Maybe someday the FAA and/or ICAO will consider replacing analog radios with a more capable digital system.... All very interesting, but one of the criteria that any new system would have to satisfy is that it would have to work in parallel with the existing system. Adding features to the new system that are not available in the old system would create dangerous differences between the two. Seeing fancy displays in the ATC or tower for the lucky digital users won't help deal with traffic from old AM users, and it might even confuse things enough to cause problems. A highly advanced solution would require replacing everything at once, which isn't going to happen. A simpler solution that just provides better quality audio could coexist with older systems without a problem. Analog AM and FM are fundamentally incompatible with each other. Analog AM and digital encoding over spread-spectrum are fundamentally incompatible with each other. You asked why AM is being used and not FM and all I'm pointing out is that if you are willing to consider any new system that is incompatible with an older system (like FM replacing AM), you may as well do it with something more advanced and capable, like digital packets over spread spectrum (which could be considered a relative to FM). One does _not_ need to implement any of the fancier capabilities that I mentioned. I stated them only as what could be easily done once the capability is in place. Analog cell phones are being replaced with digital cell phones, so I fully expect the same co-existence can be done with a changeover from analog aviation radio to digital radio. There would be no need to replace everything at once and I'm not sure why you think that would need to be the case. |
On Sat, 02 Sep 2006 21:06:47 -0000, Jim Logajan
wrote in : Analog cell phones are being replaced with digital cell phones, so I fully expect the same co-existence can be done with a changeover from analog aviation radio to digital radio. They operate on different frequency bands, so that is not a good analogy unless you can get the FCC to commit to allocating frequency spectrum for aviation use. There would be no need to replace everything at once and I'm not sure why you think that would need to be the case. Because it is unlikely the FCC will agree to allocate additional frequency spectrum for the proposed new communications system. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
AirCraft Radio Communications | [email protected] | Rotorcraft | 0 | November 13th 03 12:48 AM |
