Based on what people are saying in this discussion, it sounds as though a
pilot of a light twin has much to lose, and nothing to gain, vis-a-vis a high-performance single. So what is the point of a light twin, other than building hours to qualify for a "real" multiengine aircraft? |
![]() Mark wrote: Based on what people are saying in this discussion, it sounds as though a pilot of a light twin has much to lose, and nothing to gain, vis-a-vis a high-performance single. So what is the point of a light twin, other than building hours to qualify for a "real" multiengine aircraft? The case against light twin piston aircraft is perhaps a little overstated, but not by much. The harsh truth is that even at best the pilot workload in a light twin is a lot heavier than in a single, and there is no copilot to help. Since many pilots really do not fly all that much it is difficult to stay current in a twin, which makes the workload all that more difficult to manage. Add a few problems such as turbulence in IMC, equipment failure, or an engine failure, and the pilot can become real busy real fast. Then he better be very alert and sharp. But: if he is very alert and sharp, and maybe has somebody with him to handle a few of the lighter chores, then some light twins will provide a little more time before the plane is forced to land (a notorious few will not). This can mean all the difference in the world if you are flying at night or IMC. Additionally, the light twin usually is a little faster (which is one of the things that adds to the pilot workload -- a fast single has the same problem). This comes at a huge cost in fuel consumption, of course, but if money is no object the light twin will get you there sooner. It is difficult to determine how much of the bad accident record in light twins is really due to the second engine or just the environment they are flown in. The accident record in piston airplanes generally trends worse as the plane gets faster and as it used more for IFR and night operations anyway. Light twins are also more likely to have anti-ice systems, which puts the pilot into another dangerous environment. Typically these systems are not sufficient for operating for more than short periods of time in icing conditions, but it is real easy for a pilot to mis-judge the extent of the icing. Then again, the additional complexity of fuel systems have bitten more than a few pilots, too. Once you get into turbo-props you start flying above the weather (unless you are flying some non-pressurized turbo-prop) and have much more reliable engines. This eliminates a lot of the problems found in piston aircraft. |
![]() "cjcampbell" wrote in message ps.com... Once you get into turbo-props you start flying above the weather (unless you are flying some non-pressurized turbo-prop) and have much more reliable engines. This eliminates a lot of the problems found in piston aircraft. And, the vast majority of turbo-props are flown by professional pilots with regular training. Karl "Curator" N185KG |
![]() karl gruber wrote: "cjcampbell" wrote in message ps.com... Once you get into turbo-props you start flying above the weather (unless you are flying some non-pressurized turbo-prop) and have much more reliable engines. This eliminates a lot of the problems found in piston aircraft. And, the vast majority of turbo-props are flown by professional pilots with regular training. Exactly. Not too many bozos out there buzzing their girlfriend's house in a turboprop. |
The light twin costs more to buy and insure. It burn more
fuel for the same speed. It also can operate with redundancy on more than just engine issues. There are usually two of everything, so IFR is more comfortable. When properly flown, by a properly trained pilot, it is safer. A poorly trained pilot, who just got the quickie crash course and who rarely gets recurrent training in multiengine procedures, who doesn't carefully flight plan, will have problems that the competent pilot will not have. Train and twins are a lot of fun to fly. Over deserts and oceans, a twin is a LOT more fun since you won't have to swim as far or get as much sand in your shoes. "Mark" wrote in message ... | Based on what people are saying in this discussion, it sounds as though a | pilot of a light twin has much to lose, and nothing to gain, vis-a-vis a | high-performance single. | | So what is the point of a light twin, other than building hours to qualify | for a "real" multiengine aircraft? | | |
Good GAWD...I show 275 posts (and that starts with a RE
![]() should have taken a single paragraph, or two with expansion on the reason. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger (K8RI)" wrote in message ... Good GAWD...I show 275 posts (and that starts with a RE ![]() should have taken a single paragraph, or two with expansion on the reason. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I know. he (that needs not be mentioned by name) is a plague descending upon us. I wonder how many worthwhile members have left us, now. I don't see many of the regulars around here, lately. -- Jim in NC |
On 10/21/06 11:01, Morgans wrote:
"Roger (K8RI)" wrote in message ... Good GAWD...I show 275 posts (and that starts with a RE ![]() should have taken a single paragraph, or two with expansion on the reason. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I know. he (that needs not be mentioned by name) is a plague descending upon us. I wonder how many worthwhile members have left us, now. I don't see many of the regulars around here, lately. Well, it could be that 90% of the activity is due to the troll's threads, and most have (wisely, IMHO) decided not to respond to him further? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "Mark Hansen" wrote Well, it could be that 90% of the activity is due to the troll's threads, and most have (wisely, IMHO) decided not to respond to him further? Could be. I have an idea! Lets all stop responding to him, and when he goes away, we can see how many left! Well, at least I tried. Missed it by ... that much? g -- Jim in NC |
![]() "Morgans" wrote in message ... "Roger (K8RI)" wrote in message ... Good GAWD...I show 275 posts (and that starts with a RE ![]() should have taken a single paragraph, or two with expansion on the reason. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I know. he (that needs not be mentioned by name) is a plague descending upon us. I wonder how many worthwhile members have left us, now. I don't see many of the regulars around here, lately. -- Jim in NC In my opinion this character is perhaps one of the best if not THE best I've ever encountered on Usenet. He or she or whatever it is has redefined the definition of trolling as far as I'm concerned. Absolutely all the parameters have been met and in most cases exceeded; the gauntlet has been picked up by some; totally ignored by others; gambits have been accepted and carried to extreme ends by those engaging; the group has been effectively split from within; an absolute must to define the success of the effort. I'm actually quite satisfied with my early decision made when he/she engaged me on another forum not engage this person. Its been interesting watching him/her work this and other groups at the same time. In fact, its been one of the best experiences I've encountered since entering Usenet many years ago. I love to watch someone work who really knows what they are doing, and this character has been fun to watch. I believe now that some in the groups are finally catching on to what's been happening and joining those of us who have chosen simply to ignore the whole thing. Those arguing among themselves about him/her/it/whatever, have in my opinion simply been fodder for the cannon. :-)) VERY interesting........and it has been VERY entertaining!!!! :-))))))))))))))))))))))))))))))))))))))))))))) Dudley Henriques |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Home Built Aircraft - Alternative Engines - Geo/Suzuki | OtisWinslow | Home Built | 1 | October 12th 05 02:55 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines | Otis Willie | Military Aviation | 0 | October 29th 03 03:31 AM |
