#61
Actually both the Mooney and Bo are far easier to slow down even with
the tendency to float by the Mooney and they have roughly 30% less wing loading than the SR-22. Having owned both, I disagree. The Cirrus was easier to slow down than my 'C' model Mooney. The only reason my 'M' model Mooney is easier to slow down than the SR-22 is due to the speed brakes. --- Ken Reed M20M, N9124X -- Ken Reed M20M, N9124X |
#62
On Mon, 30 Oct 2006 10:57:50 -0500, "Happy Dog"
wrote: "Jose" Which would be redefining "circuits". So the flights don't "all involve an equal number of takeoffs and landings". How so? Is there an accumulation of aircraft in the sky (or on the ground) when one does circuits? When I do them, the number of takeoffs does in fact equal the number of landings. I just do more of them. But every takeoff and landing isn't a separate flight. To me and I believe the FAA defines a flight as the time between take off and landing, two circuits with touch and goes equals two flights although you only make the one entry in the log book. m Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#63
On Mon, 30 Oct 2006 15:18:38 -0800, "Peter Duniho"
wrote: "Matt Whiting" wrote in message ... It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'm sure that is the case. Then again, if a chute equipped airplane has the same accident rate as a traditional design, I think one must question the value of having the chute and its associated cost and weight. Given that the types of accidents that the parachute is intended to address are exceedingly rare even in non-equipped airplanes, I would find it VERY surprising if the overall accident rate was noticeably affected by the presence of the parachute. I think that the type of event the parachute is intended for would likely be an accident in a non-chute-equipped airplane, as well. Hence the accident rate *shouldn't* be different... but there hopefully would be an advantage in the fatality rate. The fact is that the pilot of a parachute-equipped aircraft has one option more than the pilot of one that doesn't have a chute. Whether one is willing to trade *having* that option for increased useful load, more cabin space, or even improved low-speed handling characteristics is just another example of the kinds of decisions an airplane buyer must make. I don't fault a pilot choosing to opt for an airplane with a chute, any more than I would fault one for selecting a plane with retractable gear. It's their money. The chute *does* work; it *can* lower the plane to the ground with less than life-threatening injuries to the occupants. People buy it for peace of mind, few, if any, expect they'll ever actually have to use it. Ron Wanttaja |
#64
off and landing, two circuits with touch and goes equals two flights although you only make the one entry in the log book. As far as the FAA is concerned, you can pick just about any takeoff and any (subsequent) landing and call it a flight. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#65
than the pilot of one that doesn't have a chute. All things being equal, this is the case. But in the Cirrus, all things aren't equal. You lose the option of standard spin recovery in exchange for the chute. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#66
On Tue, 31 Oct 2006 05:13:40 GMT, Jose wrote:
The fact is that the pilot of a parachute-equipped aircraft has one option more than the pilot of one that doesn't have a chute. All things being equal, this is the case. But in the Cirrus, all things aren't equal. You lose the option of standard spin recovery in exchange for the chute. Nope. Just not a spin recovery capability proven in certification. For all any of us know, a standard recovery will work, especially if initiated early. If it *doesn't* though, the pilot does have another option. After all, nothing guarantees that a Cessna 182 will recover from a spin, either. Yes, it's certified to do so *under particular conditions*. Depart from those conditions... with a CG aft of the limits, with the airfoils coated with ice...and there's a good probability that the Cessna won't recover. The argument about spin certification assumes that Bonanzas, 182, Mooneys, etc. regularly ENTER and RECOVER from undesired spins. Not just stalls, but *spins*. I haven't heard that that is the case. Though a lot of those certified-spinning airplanes are lost in stall/spin accidents. Heck, I've done it...accidentally spun an airplane. Carrying my first passenger after getting my Private, no less. But this was a Citabria, not a Centurion. Ron Wanttaja |
#67
Jose wrote:
The fact is that the pilot of a parachute-equipped aircraft has one option more than the pilot of one that doesn't have a chute. All things being equal, this is the case. But in the Cirrus, all things aren't equal. You lose the option of standard spin recovery in exchange for the chute. It is true that the options aren't equal, but the human _survival_ odds actually favor the Cirrus than the spin-recoverable plane. Given the same pilot in either plane, there are theoretically more spin accident scenarios where the pilot in the Cirrus can come out alive than in the non-chute- equipped plane. This assumes of course that spin-recoverable plane requires a higher altitude to recover than successful BRS deployment and that the pilot in both cases executes the correct recovery sequence in time. Theoretically, as far as I can tell, there should be a higher probability of wrecked Cirrus planes relative to spin-recoverable planes _but_ a lower probability of fatalities relative to the spin-recoverable planes. Avweb has an article on the recent Cirrus accidents in its latest "issue": http://www.avweb.com/eletter/archive.../733-full.html Here's an article that discusses the motivation for the chute and why Cirrus considers the use of CAPS superior to spin recovery: http://www.cirrusdesign.com/chutehappens/qa/index.html |
#68
"Jose" wrote in message
To me and I believe the FAA defines a flight as the time between take off and landing, two circuits with touch and goes equals two flights although you only make the one entry in the log book. As far as the FAA is concerned, you can pick just about any takeoff and any (subsequent) landing and call it a flight. (First person comments not directed at the above poster.) Or not. Absent culpability, nobody cares. The original poster made some claim to the effect that hours on Cessnas are similar to hours on Cirruses when it comes to comparing accident stats. They aren't. If it was cheaper to own a Cirrus than anything else, almost anyone would own one. I put a bunch of expensive avionics and a parachute, in an ultralight mostly because I could afford to. With only a couple adorable exceptions, fellow pilots all whined about my choices. Who cares? Did you buy a new Cirrus instead of an old pressurized twin? Did you get PPL on the way up and then lose interest and get a jet and a crew? Nobody else's business. When there's a consensus among filthy rich hobby pilots, I'll be grateful. moo |
#69
Jose,
You lose the option of standard spin recovery in exchange for the chute. Here we go again. You lose certification of recovery from spins by "standard" methods. -- Thomas Borchert (EDDH) |
#70
On Mon, 30 Oct 2006 20:48:19 -0800, Ron Wanttaja
wrote: I think that the type of event the parachute is intended for would likely be an accident in a non-chute-equipped airplane, as well. Hence the accident rate *shouldn't* be different... but there hopefully would be an advantage in the fatality rate. The second part ought to be true, but not the first. The Cirrus should have *more* accidents, because isn't every deployment an accident? I mean, aren't all Cirrus PLFs (I've been waiting since Fort Bragg to use that acronym!) going to damage the airplane? Some or many of those accidents would have been avoided without the parachute, since the pilot would make an emergency landing, hopefully without damage to the airplane. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Trip report: Cirrus SR-22 demo flight | Jose | Piloting | 13 | September 22nd 06 11:08 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
